CorkSport.com is MAZDA PERFORMANCE!
Results 1 to 6 of 6
Thread: 2002 mazda protoge manual transmission problems?
  1. #1
    Registered Member
    Join Date
    Jul 2019
    Posts
    3
    The other day I was hard shifting my protoge. My manual transmission ended up sticking in 4th gear. When I put car in neutral it was in gear. When I put the car in 1st, 2nd, 5th the car feels like it is in gear with the e brake on. It will not move no matter how much gas I use. When i put the car in reverse it wants to drive forward but with e brake feeling again. When the car is in 3rd 4th and neutral I can drive forward but feels like in 4th gear. Clutch works and let's the transmission free. When the car is being driven there is an audible clunk clunk clunk coming from transmission, mitotic area. Not sure if its clutch, transmission, or shifting linkage. Please help me guys. Much appreciated. My car is a 2.0 L
  2. #2
    Wiggity-Wack-O-Tack njaremka's Avatar
    Donated: $0.61
    2011 MX5 GT
    Join Date
    Nov 2001
    Location
    Glastonbury, CT
    Posts
    6,905
    Sounds like something in the linkage broke. Need to get under the car and check it out.
    Nik
    2012 Mini S Clubman
    Previous:
    2011 Black MX-5 GT
    2001 Black Mica Protege ES 2.0
  3. #3
    Registered Member
    Join Date
    Jul 2019
    Posts
    3
    Mazda protoge transmission
    Quote Originally Posted by Rederik12 View Post
  4. #4
    Registered Member
    Join Date
    Jul 2019
    Posts
    3
    So I drained the manual transmission fluid and there is metal flakes in it. Is this caused from clutch or transmission going bad?
  5. #5
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,333
    The clutch is dry and sealed from the transmission.
    The metal is from your transmission.
    The Diagram Dude
  6. #6
    Registered Member
    2003 mazda protege lx
    Join Date
    Jul 2010
    Location
    Maui, HI
    Posts
    68
    A little late to the thread but my 2002 protege5 recently did the same exact thing, stuck in 4th. I'm guessing it's a problem with the shift forks. As there was a negligent amount of metal flakes and it still ran fine. No noises or anything.
    Wish I could confidently say what the problem is but I have no clue. I can tell you it's an internal problem and will be easier to replace it than fix it.
Similar Threads
  1. 1998 Mazda Protoge Free Repair Manual Download
    By Panmike in forum Mazda Protege
    Last Post: 04-03-2013, 10:48 AM
  2. 2002 mazda protege transmission problems??
    By MYSTYLEMYVISION in forum Protege5
    Last Post: 10-27-2011, 06:54 PM
  3. Brakes for 2002 Mazda Protoge LX 2.0
    By ilovenaanbread in forum Mazda Protege
    Last Post: 11-27-2008, 06:54 PM
  4. Replies: 2
    Last Post: 06-15-2005, 12:53 PM
  5. How to on - Mazda Protoge 2002 lx
    By MazdaTech95 in forum Protege5
    Last Post: 08-24-2004, 08:42 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
