Results 1 to 3 of 3
Thread: Problems removing brake booster... help please.
  1. #1
    Registered Member
    2010 Mazda CX9 AWD
    Join Date
    Jul 2019
    Location
    Lancaster PA
    Posts
    1
    Hello Everyone,
    I'm trying to replace the brake booster, but it's getting stuck on the pipes that go to the heater core through the firewall. Do I need to separate the booster from the master cylinder before I try to remove the booster? The master cylinder won't separate easily from the booster. I removed the two bolts that secure the brake master cylinder to the booster, but the cylinder is stuck to the booster. Any tips or trick would be GREATLY appreciated.
    Thank you,
    Max
    2010 CX9 AWD
  2. #2
    Registered Member
    Join Date
    May 2012
    Location
    NY
    Posts
    136
    I have not done the job and I'm only commenting based on past experience. There has to be some kind of connection to the push-rod to deal with as well. I don't know how this is done in the CX-9 but I suspect that there is another connection related to this that is causing the issue. I'm pretty sure you need to decouple the booster from the master cylinder to complete this job.
  3. #3
    Registered Member
    2008 CX-9 Grand Touring
    Join Date
    Jun 2015
    Location
    Nashville, TN
    Posts
    22
    Did you get it completed - I am ordering a new brake booster and master cylinder today and plan on tackling job this week. Any tips?
Similar Threads
  1. brake booster
    By Tzar177 in forum Protege5
    Last Post: 02-09-2010, 03:16 PM
  2. Help w/ Brake booster
    By Noel in forum Mazdaspeed Protege
    Last Post: 07-14-2008, 07:47 PM
  3. Brake Booster
    By Kymerik in forum Mazda6 Wheels, Tires, Brakes & Suspension
    Last Post: 03-19-2008, 12:50 PM
  4. MBC off of Brake Booster?
    By Toolfreak387 in forum Mazdaspeed Protege
    Last Post: 02-23-2006, 11:13 AM
  5. Brake Booster
    By mazdaspeed75 in forum Mazdaspeed Protege
    Last Post: 04-05-2004, 10:29 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
