Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
Thread: Coasting
  1. #16
    Registered Member
    2019 Cx-5 sport
    Join Date
    Apr 2019
    Posts
    48
    I have complained about this premature deceleration also........ , still can't get used
    to it...... 500 miles on engine....
    Coast to light , and you can feel the engine pull the speed down , especially from
    20mph to 10mph...... then at 10mph it releases or switches gears and then it'll
    coast properly ......... , it doesn't do it if I'm in sport mode...... so , it must be
    a gearing problem........ someone on another thread said to check the trans fluid
    it might be low......... but what a hassle it is to do that !
  2. #17
    Registered Member
    2017 CX-5 GT AWD
    Join Date
    Feb 2017
    Location
    NYC
    Posts
    233
    If you want total coasting, then you may choose to put it in neutral so it's just the wheels rolling.
    The drawbacks: probably lower mpg when coasting because the the engine must keep itself spinning/idle, and if you need power (hopefully not in an emergency), there is a delay as you must shift back into drive.
  3. #18
    Registered Member CX-5um's Avatar
    13' CX-5 and 16' Mazda6 both Touring w/Tech/Bose
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    3,125
    Quote Originally Posted by joemazdacx5 View Post
    500 miles........your engine isn't even broken in yet bro. Wait until after 2 oil changes later. Improved engine response and better mpgs.
  4. #19
    Registered Member
    2019 Cx-5 sport
    Join Date
    Apr 2019
    Posts
    48
    2 oil changes.......... well that'll be 2 years............
    Just not used to the drag on the cx5 from 20-10mph......... should be in 2 years though........
  5. #20
    Registered Member
    2019 CX5 Touring/Preferred Pkg
    Join Date
    May 2019
    Posts
    18
    Coasting on my 2019 definitely isnít what Iím used to coming from a small sedan with a CVT transmission.
    It really does feel like the transmissions downshifts immediately, slowing down too much in a short period of time. I usually coast to get to the speed I want and give some gas while trying to keep the mpg needle above 40MPG.
  6. #21
    Registered Member erhayes's Avatar
    Donated: $10
    Mazda CX-5 FWD Touring
    Join Date
    Jan 2007
    Location
    Cape Coral, FL.
    Posts
    2,821
    The transmission is programed to down-shift when going down a hill or coasting to a stop. I'm not sure of the algorithm though. Ed
  7. #22
    Registered Member
    Join Date
    Jun 2012
    Location
    Swellvue, WA
    Posts
    34
    Most new cars these days have some prediction software that tries to sense if the driver needs engine braking when going downhill to save the brakes from excess wear and overheating. I think they look at how the throttle/brakes have been used and possibly the incline. On my VW, it will more/less freewheel down a hill, until I touch the brakes, then it will start to downshift/engine-brake from this point forward as long as I don't touch the throttle.
    If it bothers you, I'd experiment with how you're using the brakes/throttle on various inclines and see if you can "fool" it into letting things go more.
    - Mark
  8. #23
    Registered Member
    Join Date
    May 2019
    Posts
    18
    What I am able to do is predict how much traffic will slow on the highway by looking at the cars in front of the car immediately in front of me and their brake lights. Iíll let off the gas and let it coast. In city driving, if itís a red or yellow, Iíll slowly creep up while aiming for that 40MPG sweet spot. I had an CVT Civic before the CX5 and boy was the MPGs great on that car.
Similar Threads
  1. No coasting in 2017 AWD GT?
    By probuilders1 in forum CX-5 Lounge
    Last Post: 09-15-2017, 12:35 PM
  2. Grinding noise when coasting
    By JackieSteinmetz in forum CX-9 Lounge
    Last Post: 09-05-2011, 12:59 PM
  3. coasting in neutral ?
    By johngalt929 in forum Mazda5 Lounge
    Last Post: 04-05-2010, 10:04 PM
  4. 95 Protege bucking when coasting, please help
    By MightyMazda2 in forum Mazda Protege
    Last Post: 05-06-2009, 09:50 AM
  5. Vibration & Rattle from clutch...when coasting above 60 MPH
    By csman22 in forum Mazdaspeed Protege
    Last Post: 12-29-2003, 03:41 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
