Page 1 of 2 12 LastLast
Results 1 to 15 of 24
Thread: Cheap oil filter end-cap wrench set that has one that fits the Thailand filer
  1. #1
    Registered Member
    2018 CX-5 Sport
    Join Date
    Dec 2018
    Location
    NJ
    Posts
    440
    I just bought a Harbor Freight oil filter wrench set for $6.15 using a 20% coupon, $7.69 without a 20% coupon. The smallest one is a perfect fit for the Mazda Thailand oil filter, I checked the fit. An end-cap style wrench is easiest to use in tight quarters.
    https://www.harborfreight.com/end-ca...ece-63707.html
  2. #2
    Registered Member
    2018 CX 5 Touring AWD
    Join Date
    Dec 2018
    Location
    NV
    Posts
    22
    I use something like this which I already had. https://www.channellock.com/product/480/
    Filter was very tight from factory.
  3. #3
    Registered Member
    2019 Mazda CX-5 Signature
    Join Date
    May 2019
    Location
    Belleair Beach, Florida
    Posts
    35
    Quote Originally Posted by MyFirstMazda View Post
    Smallest meaning (65 & 68 mm) x 14 flutes? I already have too many filter end-caps and don't want more if I don't need them. I was hoping the one I used for my 2008 CX9 would work. But I thought it was larger than 68mm. Since I have a couple months before my oil-change, I'll buy the filter well before and see what fits.
  4. #4
    Registered Member
    2018 CX-5 Sport
    Join Date
    Dec 2018
    Location
    NJ
    Posts
    440
    Quote Originally Posted by St1ngy View Post
    Yes, the 65 & 68 with 14 flutes. I did not use an end cap style wrench for my first change, and the filter was slightly fatter, was the Japan filter. I did not have an end cap wrench at the time, I used a small strap style wrench. So I don't know if it is a fit for the Japan filter or not. I think the end cap style wrench is the best way for the small access area that is why I was looking for an end style wrench and found the Harbor Freight set that had one.
  5. #5
    Registered Member
    2018 AWD GT Premium Red/Black
    Join Date
    Feb 2017
    Location
    WA
    Posts
    670
    Is it the 65 or the 68 portion that fits the Thailand filter? Here's a 65 and 67 for $3.50, in case you don't want to buy a kit with several bonus sizes:
    https://www.amazon.com/OEMTOOLS-2540...CDQ3FCENBJVX2D
  6. #6
    Registered Member CX-5um's Avatar
    13' CX-5 and 16' Mazda6 both Touring w/Tech/Bose
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    3,140
    Due to using different size filters (various OEM types and 57002 WIX) along with coming across dealer-tightened filters...I find this style the best and last oil filter removal tool for my usage.
    https://www.homedepot.com/p/TEKTON-1...E&gclsrc=aw.ds
    Got mine at Walmart or Harbor Freight. Can't remember.
  7. #7
    Resident barbarian ColoradoDriver's Avatar
    Donated: $5
    2014 CX-5 Touring AWD
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    5,021
    Quote Originally Posted by CX-5um View Post
    I have those, bought at Walmart I think. Work great and adjust and fits to any filter I've had be it the Mexico, Thailand, or Wix filter.
    2014 CX-5 Touring AWD 2.5L | Jet Black Mica - 83k miles
    01/2013 build | 4/20/2013 delivery
  8. #8
    Registered Member
    2018 CX-5 Sport
    Join Date
    Dec 2018
    Location
    NJ
    Posts
    440
    Quote Originally Posted by murky View Post
    65. The beauty is that it is a confirmed fit. Who knows if that one on Amazon will fit.
  9. #9
    Registered Member
    92 MX-3; 18 CX-5
    Join Date
    Jan 2019
    Location
    MN
    Posts
    48
    Sorry guys but the best oil filter wrench is this universal ratcheting type . It has the same advantage as the oil filter end cap: it will fit in a tight spot.
    Unfortunately, the end cap filter wrench is nearly useless if the filter is much more than hand tight. The ratcheting type in the link above will simply get tighter on the filter with more torque that you put on your attached ratchet handle. And you only need to buy one of these to use with every canister style filter. If you haven't already wasted your money on the cap style then get one like this. It is the only filter wrench you need - unless you have a car with cartridge style filters that use a standard socket.
  10. #10
    Registered Member
    Join Date
    Feb 2017
    Location
    WA
    Posts
    670
    Quote Originally Posted by davmac View Post
    Yeah, I think I just came to the same conclusion, got this one: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Several cars, plus mowers and tractor. I don't like looking for tools - especially amongst ones that look similar.
  11. #11
    Registered Member
    2018 CX-5 Sport
    Join Date
    Dec 2018
    Location
    NJ
    Posts
    440
    I have that very one. It is a pita because you have to hold it against the filter to get it to grip. The HF one can easily loosen a filter that is a lot tighter than hand tight.
  12. #12
    Registered Member
    2018 CX-5 Sport
    Join Date
    Dec 2018
    Location
    NJ
    Posts
    440
    I have that one too. That one does work, but not as easily as the end HF end cap wrench. You do have a point about not wanting too many different oil wrenches. I have collected quite a few with the different mowers, hydraulic units and cars.
  13. #13
    Banned Chris_Top_Her's Avatar
    Donated: $45
    CX Moderator
    '15 CX-5 Miata GT AWD w/Tech 2.5L
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,173
    Bought a green one from Walmart for ~$10 never looked back
  14. #14
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,789
    Arrow Cheap oil filter end-cap wrench set that has one that fits the Thailand filer
    The price is good but the only useful size could be the smallest cap oil filter wrench, 65 & 68 mm x 14 flutes as the modern oil filters if they're still in old metal canister type (most new engines are switching to catridage type for environmental reason) are usually getting smaller in size. Then for Mazda SkyActiv-G or T, getting a 65 & 68 mm x 14 flutes is less useful than the one murky mentioned with size 65 & 67 mm x 14 flutes.
  15. #15
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,789
    I ordered a "Genuine" Mazda Oil Filter Wrench A255 for $10.20 from Med Center Mazda along with oil change kits a while ago but it ended up exactly the same as CTA Tools A255 Cap-Type Oil Filter Wrench! The size of CTA A255 cap wrench is 65 & 67 mm with 14 flutes. It fits Mazda OEM Japanese oil filter perfectly on 67 mm and OEM Thai oil filter on 65 mm size.
Similar Threads
  1. mazda 2 1.3 gasoline oil filter in thailand
    By Taoqun Teenyen in forum Mazda2 Lounge
    Last Post: 03-01-2019, 02:15 AM
  2. Oil Filter Wrench
    By Koz60 in forum CX-5 Lounge
    Last Post: 01-21-2016, 02:33 PM
  3. Oil filter wrench
    By erhayes in forum CX-5 Engine & Transmission
    Last Post: 09-03-2014, 03:24 PM
  4. Filter Cap Wrench
    Last Post: 12-08-2013, 09:17 AM
  5. Oil Filter Wrench ?
    By erhayes in forum Mazda CX-7
    Last Post: 12-09-2011, 12:14 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
