Results 1 to 4 of 4
Thread: 2010 cx9 valve cover seals
  1. #1
    Registered Member
    Join Date
    Jun 2019
    Posts
    4
    Ok, had to do the water pump because the bearings went out. Thought the engine would be toast but it turned out just fine. I've got an oil leak though and figured out that its coming from the seals around the vvt solenoids. They're new, they just don't seem tight enough. Anyone else experience this? All the seals look the same, are there two smaller than the spark plug tube seals?
  2. #2
    Registered Member
    Join Date
    Jun 2019
    Posts
    4
    I answered my own question. When I did the valve covers, I noticed I tore one, trying to get over the spark plug tube. Don't know what I was thinking, I didn't check to see if it would fit the VCT. I thought they were the same as a spark plug tube seals. I've emailed felpro gaskets to let them know what happened, because they really should have those separated, or at least some instructions, so people know.
  3. #3
    Biggie T Skinny helbigtw's Avatar
    CX-3, CX-5 & CX-9 Moderator
    08 CX-9 GT Fwd, Bose/Nav, BSM,Compass/Homelink, Pwr Lift,Tow
    Join Date
    Feb 2011
    Location
    Pittsburgh, PA
    Posts
    2,121
    Good to know. I am currently playing the water pump Russian roulette game on my 2008. Was going to do it this year but too much going on and will try for next year. Where on the motor did you notice the issue with the seal leak?
  4. #4
    Registered Member
    2008 Mazda CX-9 Touring FWD . 2014 CX-5 GT FWD
    Join Date
    Dec 2007
    Location
    Chicago
    Posts
    169
    Quote Originally Posted by helbigtw View Post
    FYI, I provided a picture of the leak location around the VVT solenoid at the end of step #56 in the instructions found here:
    https://www.dropbox.com/sh/yjma0fz8e...Water+Pump.pdf
    The yellow is the fluorescent dye I used to spot the leak.
Similar Threads
  1. Valve Seals!
    By MP3DG in forum Mazdaspeed Protege
    Last Post: 09-05-2013, 10:26 PM
  2. 2004 Valve Cover Gasket and Plug Tube Seals
    By tomk17 in forum Mazda3 General
    Last Post: 06-27-2011, 10:51 PM
  3. Valve Seals?
    By fathergene in forum Protege5
    Last Post: 02-04-2011, 01:04 AM
  4. Valve Seals
    By Redcallen in forum Mazdaspeed Protege
    Last Post: 11-25-2010, 05:37 AM
  5. Valve Seals
    Last Post: 09-23-2010, 05:38 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
