Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Did you have the rocker issue recall work done? Post your experience here
  1. #1
    Registered Member
    2018 CX-5 Sport
    Join Date
    Dec 2018
    Location
    NJ
    Posts
    439
    If you had the recall work done for the rocker arm concern, post your experience here. I think it will benefit others to hear about your experience with getting the recall work done, for example how long it took. If you notice anything different about your car after the work, for example if your MPG changed or you hear any new noises, put that in your post too. I haven't had the work done yet because my dealer is still waiting for the part used to do the reprogramming.
  2. #2
    Work in Progress sm1ke's Avatar
    Donated: $25
    2018 Mazda CX-9 Signature
    Join Date
    Dec 2016
    Location
    MB, Canada
    Posts
    1,484
    I would also urge those to post whether or not the dealer checked to see if the rocker arm fell off (likely not as it isn't specified in the recall). I would also suggest those who had the recall done to safely perform the following test on an unoccupied open road:
    Start the car and put it in "manual" mode. Accelerate to 2nd or 3rd gear, then rev up to 5000-5500 RPM and hold it there for 10 seconds, then come to a complete stop.
    If the rocker arm has fallen off, the test should force the car into limp mode, which means you can take the car back to the dealer for the appropriate repair.
  3. #3
    Banned Chris_Top_Her's Avatar
    Donated: $45
    CX Moderator
    '15 CX-5 Miata GT AWD w/Tech 2.5L
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,170
    Quote Originally Posted by sm1ke View Post
    I don't know.. 5500 in 3rd gear might be too fast for some
  4. #4
    Registered Member erhayes's Avatar
    Donated: $10
    Mazda CX-5 FWD Touring
    Join Date
    Jan 2007
    Location
    Cape Coral, FL.
    Posts
    2,822
    If one cylinder is not firing due to a closed valve, wouldn't it give a CEL? In addition: I certainly can tell if my 4 cyl engine is running on only 3 cyl. I see little value in running up RPM to find out if a lifter is not functioning-sounds like a foolish endeavor that may even cause harm. Ed
  5. #5
    Registered Member
    2013 Mazda CX-5 Sport FWD Auto
    Join Date
    Oct 2012
    Location
    FL
    Posts
    306
    It might give a CEL if you do what sm1ke suggests. It*s essentially one valve not opening up, always closed if the rocker arm fell off. You don*t know there*s an issue until you push the engine and the lack of the valve opening rears it*s head. Definitely not a case of running 3 out of the 4 cylinders. It is one cylinder lacking one of the four valves opening when it needs to.
    Do it on open road and you*ll be fine. Restarting the car seemed to get it out of limp mode per the CD thread.
  6. #6
    Structural Member shadonoz's Avatar
    Donated: $5
    2017 CX-5 GT AWD Tech
    Join Date
    Oct 2017
    Location
    State of Jefferson - southern Oregon
    Posts
    2,053
    Quote Originally Posted by erhayes View Post
    If the engine is ok, running it like that won't hurt it a bit, might even be good for it.
    But if the engine is already broken, it won't additionally hurt it , and then at least you'll know it, CEL or not.
    I've suggested that everyone with an affected engine do this test, before AND after the recall, so that they won't be caught unawares.
  7. #7
    Registered Member
    2018 CX-5 Sport
    Join Date
    Dec 2018
    Location
    NJ
    Posts
    439
    I wouldn't race it if the car is in the break in period. Looking at the valve train is the best because revving the engine may not prove anything other than it didn't go into limp mode on that specific drive. For example Go Hawks revved his car up other times and it didn't go into limp mode right?
  8. #8
    Registered Member
    cx5 gt +pp 2018
    Join Date
    Dec 2018
    Location
    arizona
    Posts
    266
    Only pcm was updated.
    There was some confusion initially as they mentioned recall is not 'public' yet not until August (no idea why).
    In and out in 30 mins.
    Seems battery was disconnected before the work.
    No visible or audible changes, in noises or mpg or power after the update.
    Noticed the recall work done (dealer visit) does not show yet in car history menu in mymazda or carfax.
  9. #9
    Registered Member
    2018 Cx-5 grand touring w/prem. pkg.
    Join Date
    Sep 2018
    Location
    n. central FL
    Posts
    16
    We had recall done Friday 7/5 with 2,805 miles. I was 2 hours before it was done. They also did the android auto update and there free full circle service inspection. I put the car in manual 1st gear and drove @ 5200 rpms for approximately 7 seconds. Car is running fine at this point.
  10. #10
    Donated: $10
    Join Date
    Jan 2007
    Location
    Cape Coral, FL.
    Posts
    2,822
    The "mymazda" update is only done on some sort of scheduled. I've waited for up to 10 days before the update was added. Ed
  11. #11
    Registered Member
    '18 CX-5 | '18 M6
    Join Date
    Jul 2019
    Posts
    4
    I'll be under the assumption that a simple rev and hold at 5k rpm will prove nothing. The rocker arm that's falling off is intended to open the second intake valve on one cylinder. It's been said that the engine runs great even on one valve, so a specific set of events must occur to really upset the air/fuel ratio.
    A severe lean condition might only occur under specific circumstances such as above 4k rpm AND full throttle for an extended period of time (ie, while accelerating hard in a higher gear while passing traffic, this is where we'd be expecting maximum airflow). Most engine mgmt systems filter hysteresis (ignoring brief anomalies of data) until they reach a set threshold over a specified period of time. Similar to TPMS where low tire pressure needs to be observed for X amount of miles or time before throwing a warning light.
    However, this is all conjecture because it would appear that no one here knows how the engine mgmt system is programmed. I won't presume my CX5 is normal unless it's visually inspected...which l doubt will happen, so we'll just have to take Mazda's word for it.
  12. #12
    Registered Member
    2018 CX-5 Sport
    Join Date
    Dec 2018
    Location
    NJ
    Posts
    439
    I am going to try and consolidate the results here:
    7/11/2019, 12:29 AM silverboy
    Hey guys, I had the Recall #3719F software fixed yesterday done on my 2019 CX5. It took about 45 minutes. Anyone else had the fix done? I noticed that the CX5 is not as much fun to drive anymore as it was before the fix. Also, I noticed that at take off, if I give a lot of gas, there's a huge delay before the vehicle responds. It feels almost like a turbo lag, however my CX5 has no turbo. It sucks because the vehicle always felt like fun to drive it.
    7/10/2019, 10:03 PM joemazdacx5
    well, had my cx5 pcm software updated for the 'fix' today. took about 20 minutes. the mechanic that did the flash said version he is using now is 13.06. he said increase oil pressure to keep rocker arm in place plus the timing was off and this new pcm fixed that also. I asked by how much oil pressure was increased? could it cause oil leaks in future ? he said mazda headquarters don't tell him stuff like that. I asked if this new pcm just masks the problem? he said no, and if the rocker arm falls off that you'll know it because the timing will be off and you could hear it. So, sorry , not that mechanical , and best I could do. Oh also , no to removing the valve cover to check it it's already fallen off. guess he could hear it if it did.
    7/4/2019 4:14PM mazdaftw
    I had mines completed yesterday along with an oil change/tire rotation. Took about an hour. I revved the crap of it and took it up to 95mph for a split second. Everything seems fine.
    07-04-2019, 12:51 AM #384 cz5gt
    just a quick note. After the pcm update it seems reset are both of the average mpg counters to 0, the homelink setup for an already set garage opener and some of the settings in the infotainment, more precisely the active street sign recognition is back to default (on). at least on my car. by the way, the second recall for the bad weld part (unrelated to the rocker arm recall) seems gone from carfax. May be as somebody mentioned it was a mistake.
    07-03-2019, 01:39 PM #373
    cz5gt
    Got mine done as well. Took about 15 mins for the update. Yes, they are not checking anything else as the recall instructions are only for pcm update.
    07-03-2019, 11:02 AM #372
    LAMike240
    I*m at the dealer now for 20k service and they are also updating the software per the recall. He said it only takes 15 minutes, so I*ll assume they are not checking for a dropped rocker. I did do the tests, 5-6k rpm 60 and below, and at speeds up to 80. No issues.
  13. #13
    Registered Member
    Join Date
    Jul 2019
    Posts
    2
    just had my CX-5 done. Called Mazda, the guy after putting me on hold said the patch is called version PAJ3-188K2-H. When i got to the dealer, the actual file that got downloaded was PX42-18881-C. the IDS version on the machine was IDS-113.06
    My trips (A & B) both also got reset. Didn't notice any difference to performance. ACtually took it to a different dealer to confirm, (they didn't know i went elsewhere first) they said they downloaded it, but the trips didn't get reset, so my assumption is if you already had it on the computer it didn't write over. We'll see...
  14. #14
    Registered Member
    Join Date
    Jun 2019
    Posts
    16
    Quote Originally Posted by CXDUDE77 View Post
    Ours reset the trip computer as well.
  15. #15
    Registered Member
    2018 CX-5 Sport
    Join Date
    Dec 2018
    Location
    NJ
    Posts
    439
    They supposed to put a sticker under the hood after the work is done. Maybe the 2nd dealer saw it.
Similar Threads
  1. ipod issue. anyone else experience?
    By ssmitty85 in forum Mazda6 Infotainment
    Last Post: 08-09-2013, 06:36 PM
  2. Tire Reviews - Post your experience
    By wannabe in forum Mazdaspeed6
    Last Post: 01-25-2012, 12:26 PM
  3. Replies: 5
    Last Post: 02-28-2011, 04:05 PM
  4. Replies: 13
    Last Post: 07-27-2009, 08:21 PM
  5. gas cap issue is now finally a recall
    By TheMAN in forum Mazda CX-7
    Last Post: 01-12-2007, 11:59 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
