In Memory of Member 1338
Results 1 to 4 of 4
Thread: timing cover removal
  1. #1
    Registered Member
    Join Date
    Jul 2019
    Posts
    2
    I just replaced my valve cover gasket and I'm worried about oil leaking past through where the cams are. There is an oily mess everywhere from the leaky gasket before, but the timing belt looked good and didn't have any oil on it. I just want to be able to look in there and make sure the problem is fixed.
    Is it possible to remove the upper timing cover without first taking off the valve cover?
    Looks like it will come off by removing the four bolts and moving it sideways. But no one ever mentions doing this and I'm wondering if there's something that prevents you.
    Edit: It's an '02, sorry.
  2. #2
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,236
    I did a Timing belt change on my P5 (2 L engine) and a lot of stuff has to come off to get to the cover and its bolts.
    You may however be able to reach some of the accessible bolts (or screws,.. I forget) to be able to bend the cover enough to see in there.
    Did you apply RTV silicone to the gasket where you're supposed to ??
    If you didn't apply silicone you should remove the valve cover and put some in there.
    The Diagram Dude
  3. #3
    Registered Member
    Join Date
    Jul 2019
    Posts
    2
    Yes, I used the rtv but I didn't do the best job with that part. Ended up just smearing a bit on and moved it around with my finger. It was a mess to work with. I also didn't wait 24 hours before I drove it around. I only waited an hour and torqued all the bolts.
  4. #4
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,236
    You should probably be good.
    But if you can't see in there it's hard to see a leak.
    There's not much oil preasure up there. It just sort of splashes around.
    But apparently if your T-belt is "contaminated", you're supposed to replace it.
Similar Threads
  1. Replies: 12
    Last Post: 11-20-2014, 01:57 PM
  2. WTB Timing belt cover
    By SIBalla23 in forum Completed Transactions
    Last Post: 01-17-2011, 11:25 PM
  3. Timing Belt removal - Crankshafted
    By KGM323 in forum Mazda Protege
    Last Post: 08-08-2010, 11:16 PM
  4. WTB Timing cover(s)
    By u812many73 in forum Completed Transactions
    Last Post: 02-16-2010, 02:58 AM
  5. Timing cover
    By junya1985 in forum Completed Transactions
    Last Post: 08-17-2008, 08:55 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
