Compare auto reliability with reliable results at TrueDelta.com!
Page 5 of 5 FirstFirst ... 345
Results 61 to 69 of 69
Thread: Flashing cel
  1. #61
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,233
    That does look a lot cleaner but I don't see the top of the piston in the picture.
    The Diagram Dude
  2. #62
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,233
    Quote Originally Posted by NaturalFlavored View Post
    So what your telling me is that I'm shit out of luck.
    No !! Not at all !!
    Get the proper plugs and good coils and fix your leaky injector and you'll be rolling again !@
  3. #63
    Registered Member STudMUffin1177's Avatar
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham
    Posts
    320
    Running half a can of seafoam in the crankcase and half a can in a full tank will clear a bunch of the top layer carbon deposits. Might free up your oil rings if there's any tension left in them.
  4. #64
    Registered Member NaturalFlavored's Avatar
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    599
    Ok put new coil on and new injector. Now I have a random misfire. P0300. So now what because this is annoying the fuck out of me.
  5. #65
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,233
    That sucks and I'm kinda stumped.
    The P0300 has more possible causes too.
  6. #66
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    599
    Yeah I'm ready to just get rid of the car. I'm done putting money into it when I'm just going to sell it.
  7. #67
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    599
    Cleared the code made sure everything was tight and it drives fine now. So no idea hopefully it stays off while I sell it.
  8. #68
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,233
    Well, that's good news.
    You may have had a couple of slightly fouled cylinders that just needed to clear themselves out.
    That fouled cylinder you posted a picture of should clean itself up with some good clean combustion.
  9. #69
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    374
    Just pull the bulb out of the check engine light lol. Or, I know guys that used to wire the check engine light bulb in with the battery light bulb. that way when you turn the key on, engine off, the CEL would turn on like normal. but no more pesky CEL.
    so what ended up being the fix? hopefully it stays fixed!
Similar Threads
  1. Power Loss, Check Engine Light Flashing, Traction Control Flashing. Help.
    By SPARKS7595 in forum Mazda3 Engine & Transmission
    Last Post: 05-04-2015, 05:02 PM
  2. Flashing CEL, please help.
    By brett02 in forum Protege5
    Last Post: 08-30-2009, 01:41 PM
  3. CEL is flashing!!
    By ride0012 in forum Mazdaspeed Protege
    Last Post: 06-28-2009, 08:03 PM
  4. Flashing
    By Protege73 in forum Mazdaspeed Protege
    Last Post: 03-16-2005, 03:39 AM
  5. About Flashing
    Last Post: 01-21-2005, 12:24 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
