In Memory of Member 1338
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 46 to 60 of 69
Thread: Flashing cel
  1. #46
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,229
    Higher quality coils can produce a stronger spark and the insulation around the coil is of better quality so you don't throw the spark to the valve cover or short out internally.
    The Diagram Dude
  2. #47
    Registered Member NaturalFlavored's Avatar
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    599
    Well do you think running different spark plugs have anything to do with it? Since I only changed out the coils could having different plugs play a role?
  3. #48
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,229
    I think that's quite possible but the coils should be able to deal with it regardless.
  4. #49
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,229
    It looks like you're using the plugs for the 1.6 L engine.
    It would probably be smart to put in a plug recommended for the 1.8 or 2 L engine regardless.
    But you were using those plugs for 5 months with no problems right ?
  5. #50
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    599
    Correct because I read that those were the plugs for the fsze. It was making good power of it still throws the code I'll have it checked for compression.
  6. #51
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,229
    We're in summer now.
    Coils like to fail when they're really hot.
  7. #52
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    599
    Well within minutes I don't think so. It failed before I left my apartments and it was only 80
  8. #53
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,229
    Well you have to wait until your new injector is installed anyway, so see what results you get with that.
    All I'm really trying to say is that if you end up having to get new coils again, go with OEM.
  9. #54
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    599
    If I do then I'm just going to swap back to protege5
  10. #55
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    599
    https://photos.app.goo.gl/pWhT8nWLb2u3pvRB9
    https://photos.app.goo.gl/JpKkkdvwR6iRhFeQA
    This is the spark plug and the cylinder look like I got pictures to show you how it looked. I'm swapping in the new injector now.
  11. #56
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,229
    If you have a fouled cylinder you can get carbon build up in your combustion chamber.
    This is a piston from my parts car that was burning a lot of oil.
    If there's a lot of built up crap in the combustion chamber you reduce the volume and increase the pressure then you need more KV to pop a spark through a spark plug.
    PS.. That spark plug looks fine.
  12. #57
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,229
    If the center of the picture is the top of your piston then it looks fouled.
  13. #58
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    599
    It probably is. This is cylinder 4
    https://photos.app.goo.gl/DGSrfyXfdtxTy9Tt7
  14. #59
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,229
    These are my piston rings...
    Notice how there's no expansion of the oil ring.
    Our engines have great compression but the oil rings get siezed and let a butt load of oil past them.
  15. #60
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    599
    So what your telling me is that I'm shit out of luck.
Similar Threads
  1. Power Loss, Check Engine Light Flashing, Traction Control Flashing. Help.
    By SPARKS7595 in forum Mazda3 Engine & Transmission
    Last Post: 05-04-2015, 05:02 PM
  2. Flashing CEL, please help.
    By brett02 in forum Protege5
    Last Post: 08-30-2009, 01:41 PM
  3. CEL is flashing!!
    By ride0012 in forum Mazdaspeed Protege
    Last Post: 06-28-2009, 08:03 PM
  4. Flashing
    By Protege73 in forum Mazdaspeed Protege
    Last Post: 03-16-2005, 03:39 AM
  5. About Flashing
    Last Post: 01-21-2005, 12:24 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
