CorkSport.com is MAZDA PERFORMANCE!
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 16 to 30 of 69
Thread: Flashing cel
  1. #16
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,242
    Yea, don't start throwing money at it until you know what exactly is wrong.
    I'm pretty sure both an injector and coil could have an instant and complete failure.
    I'm pretty sure the coil swap is easier to do than swapping injectors.
    There's wiring and connections for both the coils and injectors that you can inspect.
    Your injector could be stuck open.
    The Diagram Dude
  2. #17
    Registered Member NaturalFlavored's Avatar
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    602
    I switched the coils around and the light is taking forever to come back. I cleared the light twice and it came back quickly, this time sheet switching the coils it still runs horrible but no light.
    Ok light came back it jumped. It's the coil pack, I'm going to buy another one and have them warranty it. Haha
  3. #18
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,242
    Cool !!
    A free and easy fix.
  4. #19
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    602
    Haha yeah, this coil pack is only 7 months old and been on the car for 4 months. So they're going to change it for me one way or another.
  5. #20
    Registered Member STudMUffin1177's Avatar
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham
    Posts
    321
    Nice man
  6. #21
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    602
    New coil in, flashing cel came back. So what causes a coil to burn out?
  7. #22
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    380
    Do you have a scan tool? What cylinder is misfiring?
    Diagnosis is key before spending money. There's plenty of parts to swap around. Only swap 1 part at a time! Find out what cylinder is misfiring. clear the codes. Swap plugs with the cylinder next to it. IF the problem follows the spark plug, then replace the plug. If the misfire stays on the same cylinder, then clear the codes again and swap the coils. IF the problem moves to the other cylinder, then replace the coil. if not, then coils are fine. clear the codes again, pull the fuel rail loose and swap injectors between the problem cylinder and another cylinder. clear codes and run it until it misfires. see if the problem follows the injector or not.
    If you are burning up coils, then it many times it's a spark plug that can cause coils to burn out. If the plug has too much resistance, or the gap is too large (worn plugs) then it requires the coil to produce more kv to jump the plug gap, shortening the life of the coil.
  8. #23
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    602
    Yes I know. That has been discussed already. I diagnosed it to the coil. But now I put a new coil on and same issue.
  9. #24
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham
    Posts
    321
    It's still cylinder 3? Maybe check your plug wires, sometimes the metal insert gets knocked loose even though it feels like it's on there. Sometimes you can push it down enough to seat, I had to get new wires in my case
  10. #25
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    602
    Ok. I'll switch the cables between 3 and 4 and see if it helps. But since it went back into limp mode did it fry the coil again?
  11. #26
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    380
    How long did it run good when you replaced the coil? Minutes? Hours? Days?
  12. #27
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    602
    Minutes
  13. #28
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    380
    I don't think it was the coil then, i'd bet that was just a coincidence. Time to look elsewhere. If it ran for a couple days before misfiring again, possibly a coil. But a new coil frying within minutes is unlikely. That's really not even enough time for it to warm up.
    Run the car and let it misfire for a few minutes. Then immediately pull the spark plug out and inspect. See if the spark plug is wet? Dry?
    I'm suspecting an injector has or is failing. I know how some like to say these coils go bad left and right but I sold my car with 270k miles on it, still all of the original coils and wires and I never had a problem with them so I'm still not completely sold that the coils are junk...
  14. #29
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    602
    Well i switched the coils and it jumped from 3 to 4. And I did the 626 valve cover swap so I'm running protege coils. It was running fine for 5 months before this happened.
    I swapped plugs and wires still the same coil. I put it new coil same problem. So I'm wondering what's making the coil go bad.
  15. #30
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,242
    Quote Originally Posted by NaturalFlavored View Post
    I think your coils are crap.
    I think you should go with Hitachi coils.
    A lot of guys have had a lot of problems with coils. Including being bad right out of the box.
    Quality coils are worth the money.
Similar Threads
  1. Power Loss, Check Engine Light Flashing, Traction Control Flashing. Help.
    By SPARKS7595 in forum Mazda3 Engine & Transmission
    Last Post: 05-04-2015, 05:02 PM
  2. Flashing CEL, please help.
    By brett02 in forum Protege5
    Last Post: 08-30-2009, 01:41 PM
  3. CEL is flashing!!
    By ride0012 in forum Mazdaspeed Protege
    Last Post: 06-28-2009, 08:03 PM
  4. Flashing
    By Protege73 in forum Mazdaspeed Protege
    Last Post: 03-16-2005, 03:39 AM
  5. About Flashing
    Last Post: 01-21-2005, 12:24 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
