Made in USA and Free Shipping on all orders shipped inside the US.
Page 1 of 5 123 ... LastLast
Results 1 to 15 of 69
Thread: Flashing cel
  1. #1
    Registered Member NaturalFlavored's Avatar
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    599
    Flashing cel
    So now my car just had a check engine light come on and it drives like shit and sounds like shit.
    I checked and I don't see any broken lines.
  2. #2
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,232
    That's engine misfire.
    It's the only code that flashes the CEL. Then your car goes into limp mode.
    If you still have a pre-cat you can wreck it in seconds.
    Headers don't have a pre-cat and need the non-fouler mod.
    The Diagram Dude
  3. #3
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,232
    A code reader will tell you whether you have a random mis-fire(P0300) or cylinder specific (P0301- P0304).
    Many people here have found that the misfire was caused by coils.
    If I were you, I'd start with a new set of ignition coils. They are notoriuos for giving us grief.
  4. #4
    Registered Member STudMUffin1177's Avatar
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham
    Posts
    320
    Only time my pro5 threw a code was a random misfire, new coil packs and cleared the code. Been fine since, id also check out your plug wires. The girlfriends kia optima ruined the plugs and wires when the coils went out
  5. #5
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    599
    I did the Mazda 626 swap so I'll check those. I bought everything new. It went into limp mode when I was on the freeway.
  6. #6
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,232
    If you've got a header and no pre-cat then it's not an emergency and you've got some time to figure it out.
    If your CEL is now on all the time (no longer flashing) it means that limp mode is working and has stopped the mis-fire but you'll need to fix it to get out of limp mode.
  7. #7
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    599
    Cylinder three misfire. The plugs wires and coil are all new from February. So what should I look for?
  8. #8
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,232
    I'd pull that plug and take a look at it.
    Maybe run the car in the dark and look for sparks around the plugs wires and coils.
  9. #9
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham
    Posts
    320
    Plug wire might've just gotten knocked loose
  10. #10
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    599
    Spark plug smelt like gas and was black.
  11. #11
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,232
    Sounds like it's not firing.
    I'm guessing bad coil ??
    Do you have 4 coils now or still two ?
    Check the plug wire for cracks.
    You can mist some water around the wire, coil and plug and check for sparks.
    Inspect the sparkplug boot for signs of sparking.
    It could also be a partially clogged injector.
  12. #12
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    599
    I switched plugs and wires around and still cylinder 3
  13. #13
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,232
    So you cleared the code first and it came back again as cylinder 3 ??
    That's sounding like injector.
    Try swapping coils too, just to help make sure.
  14. #14
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,232
  15. #15
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    599
    Ok I'll try some more tomorrow before I buy any parts. I have the coil swap so I'm going to need more time.
Similar Threads
  1. Power Loss, Check Engine Light Flashing, Traction Control Flashing. Help.
    By SPARKS7595 in forum Mazda3 Engine & Transmission
    Last Post: 05-04-2015, 05:02 PM
  2. Flashing CEL, please help.
    By brett02 in forum Protege5
    Last Post: 08-30-2009, 01:41 PM
  3. CEL is flashing!!
    By ride0012 in forum Mazdaspeed Protege
    Last Post: 06-28-2009, 08:03 PM
  4. Flashing
    By Protege73 in forum Mazdaspeed Protege
    Last Post: 03-16-2005, 03:39 AM
  5. About Flashing
    Last Post: 01-21-2005, 12:24 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
