Compare auto reliability with reliable results at TrueDelta.com!
Results 1 to 9 of 9
Thread: Caliper piston won't retract fully
  1. #1
    Registered Member alienator064's Avatar
    '02 Protege5
    Join Date
    Jul 2019
    Location
    Illinois
    Posts
    2
    So replacing pads and rotors and my rear passenger brake piston can't be pushed in all the way to fit the new pads. It's not seized because I can pump the brakes and see the piston move further out and push it back in until a point where it just won't go back in anymore. The piston sticks out about 4mm past the boot.
    Anybody else have this issue? Any ideas?
  2. #2
    Registered Member NaturalFlavored's Avatar
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    577
    This has been discussed. But I would take it apart and rebuild it if you don't want to buy a new one.
    It definitely needs to be rebuilt because it's not operating correctly so it's up to you.
  3. #3
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,099
    Quote Originally Posted by alienator064 View Post
    I could be rusted or you didn't back off the adjuster screw enough.
    The Diagram Dude
  4. #4
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    577
    PCB but all I did was push the Piston back in when I did my brakes, so it could be rust. But I only pushed Piston back in then put in pads. Then pumped them and was good to go.
  5. #5
    2008.5 MGM MS3 rsvinylgraphics's Avatar
    Donated: $5
    Join Date
    Oct 2009
    Location
    Indiana
    Posts
    1,161
    did you take the cap off of the master cylinder?
  6. #6
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,099
    Quote Originally Posted by NaturalFlavored View Post
    The rears aren't supposed to work that way.
    Was your P-brake working properly ??
    I had to turn the piston to get it to thread back in.
    There's these parts inside which aren't included in the rebuild kit.
    You can't put a new seal on a sloppy worn out part.
  7. #7
    '02 Protege5
    Join Date
    Jul 2019
    Location
    Illinois
    Posts
    2
    Quote Originally Posted by pcb View Post
    Didn't know there was an adjustment screw haha. Maybe I should've done more research on protege brakes before doing this work. Hopefully this thread will help people in the future from making a dumb oversight. Oh well, just another learning experience I guess.
  8. #8
    Registered Member o.g.sk8er's Avatar
    Join Date
    Jul 2002
    Location
    los angeles, ca
    Posts
    1,589
    I have always used the adjustment screw to retract the caliper on the rear brakes. One time, the only time I ever brought my car in for the rear brakes, was the also the last time. My calipers were in perfect working order. I was going to the track the next day and thought I'd let a very reputable company (rhymes with Cry-Joint) do my rear pads as I didnt have time to do it myself.
    They compressed the piston so much, it blew the seals. Then they call me and tell me I have a defective caliper. I asked if the used the adjustment screw. They said there isnt one and I need to buy a new caliper. I missed the race and lost my entry money as well.
    The rear adjustment screw is the proper way to retract the piston in order to get the pads in there correctly.
    02 Protege 5
    Suspension:
    BC Coilovers; AWR endlinks; GT Spec front 4 point ladder bar; GT Spec rear V-Brace; GT Spec reinforcement panel; GT Spec rear strut bar; AWR trailing arms; Modded factory rear sway bar.
    Performance:
    MP3 ECU (not flashed); Unorthodox Underdrive Pulley; JDM MS flywheel (16lbs);
    K&N drop in panel filter < the absolute Worst thing I ever did.
    1sty Grounding Kit; TB Coolant Bypass Mod; 03 MSP Rear Axleback; Resonator Delete.
    Interior:
    Kartboy Short Shifter with Kartboy Bushings; DGM CF Gauge Bezel; DGM CF passenger side dash cover; Wink 5 Panel Mirror; Baton style Shiftknob; 4 inch shifter extension; Red Accent Lights; Super Bright LED's in the Gauge Cluster.
    https://www.youtube.com/user/ogsk8ermocc/videos
  9. #9
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,099
    When I first got my car (and before joining this site) I took my car in for pads and rotors all around.
    I was quoted $250 but it ended up being $740 because "both my rear calipers were seized".
    It cost me $500 extra because they didn't know about the adjuster screw.
    I do all my own work now.
    Here's a link to the factory service manual.
    http://www.floptical.net/mazda/
    Here's a link to my brake thread where I took apart my rear caliper.
    (the pictures got reposted at the end after Photobucket shut me down)
    https://www.mazdas247.com/forum/show...ion&highlight=
Similar Threads
  1. Rear caliper piston won't retract
    By SgurrDearg in forum Mazda6 Wheels, Tires, Brakes & Suspension
    Last Post: 06-26-2016, 08:04 AM
  2. Cannot retract rear caliper piston far enough
    By MaydayDown_Joey in forum Protege5
    Last Post: 02-12-2016, 08:52 PM
  3. Replies: 2
    Last Post: 03-04-2011, 08:52 PM
  4. caliper piston
    By mazdanoob in forum Mazda6 Wheels, Tires, Brakes & Suspension
    Last Post: 08-29-2008, 11:21 AM
  5. Retract caliper piston
    By benbike in forum Mazdaspeed Protege
    Last Post: 01-12-2006, 08:10 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
