CorkSport.com is MAZDA PERFORMANCE!
Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 34
Thread: KMiata SCCA Solo XP swap
  1. #16
    High Speed Low Drag aMaff's Avatar
    muffled screams
    Protege5 & Protege FS Moderator
    1992 Miata / 2003 Pathfinder
    Join Date
    Sep 2005
    Location
    Lilburn, Ga
    Posts
    18,807
    I've got the oil pump swapped. RSX TypeS pump (compare it to the stock TSX monstrosity in my previous post):
    KMiata's billet oil pump housing to work with their oil pickup (to go over the steering rack). The stock TypeS pump pickup sticks straight back, which would go through the steering rack:
    Once I get the seal & gasket set in, I'll crack into the honda bond (needed for the 'oil squirter plug" bolt) and get the oil pan, water pump housing and timing covers back on. I'll need to grab a buddy this weekend to hold a wrench so I can torque the 50 degree intake pulley (vs the stock TSX 25 degree VVT pulley) onto the cam.
    ~Andrew
    Atlanta Region SCCA
    114 DP
  2. #17
    No words bazooka joe's Avatar
    Donated: $40
    Miata & NEMOC Moderator
    2016 Miata Club, 2004 MSM, 2014 CX5 Touring, Honda 1976 XL 175
    Join Date
    Oct 2002
    Location
    wbee ma to NC 2016 Jinba ittai
    Posts
    21,351
    Keeping coming....
  3. #18
    muffled screams
    Join Date
    Sep 2005
    Location
    Lilburn, Ga
    Posts
    18,807
    Steering rack's ready to go (minus a couple zip ties to secure the boots).
    New inner tie rods, new R Package outer tie rods, and my home-brew steering limiters.
  4. #19
    muffled screams
    Join Date
    Sep 2005
    Location
    Lilburn, Ga
    Posts
    18,807
    I thought I was done with the rack, until I had one of those "oh shit, you dumbass" realizations while drifting off to sleep last night.
    There is a shoulder on the new style Inner Tie Rod locking washers that goes on the OD of the rack, vs the old style washers that sat on the OD of the tie rod's threads.
    I realized the rack limiters I made are a really snug fit on the rack, and might not clear the washer. I pulled the boots off and turned the rack through its full range of motion and sure enough, I'd managed to reduce the total travel by another 1/4 turn or so (1/8" per side, give or take).
    I threw it in the lathe and put a counter-bore in it to clear the washer on 1 side, but still ride nice and snug on the rack:
    Much mo' better.
    Of course, taking those staked on washers off broke the areas that were staked, so I clocked them 90 degrees and had 2 fresh areas on the shoulder to put new stakes in. Those plus red loctite (again... removing the inner tie rods wasn't fun) should be good to go now.
  5. #20
    muffled screams
    Join Date
    Sep 2005
    Location
    Lilburn, Ga
    Posts
    18,807
    Not KMiata content as much as XP content, but these are currently being CNC'd
  6. #21
    muffled screams
    Join Date
    Sep 2005
    Location
    Lilburn, Ga
    Posts
    18,807
    Picked up the Nine Lives Racing Big Wang this morning. Still waiting on the 2nd elements to come back in stock, but once they do that'll go on as well
  7. #22
    muffled screams
    Join Date
    Sep 2005
    Location
    Lilburn, Ga
    Posts
    18,807
    Finally starting to move in the right direction of putting stuff ONTO the motor vs taking stuff off. Water pump housing and oil pan are on.
  8. #23
    Donated: $40
    Join Date
    Oct 2002
    Location
    Posts
    21,351
    Cool build for sure!
  9. #24
    MOTM July 2015 chiefmg's Avatar
    '81 RX-7 GS, '00 Miata SE, '16 Camaro (wife's), '15 CX-5 GT AWD
    Join Date
    Oct 2005
    Location
    N KY
    Posts
    2,021
    What is the purpose of the drain plug on the high side of the oil pan? Loving everything so far.
  10. #25
    muffled screams
    Join Date
    Sep 2005
    Location
    Lilburn, Ga
    Posts
    18,807
    Sort of like a diff or trans fill where the top plug is essentially the 'high water mark'. With the aftermarket pan, the stock dipstick doesn't really mean much anymore, so that's the 'full' mark.
  11. #26
    muffled screams
    Join Date
    Sep 2005
    Location
    Lilburn, Ga
    Posts
    18,807
    Back to the engine: got the oiling & timing system buttoned up for the time being. It looks pretty scabby on the outside (despite my best efforts to clean it...this engine needs a hot tank BADLY), but it's clean of oil and grease, and all the important bits were cleaned up and installed with new seals and O-rings where needed (VTC actuator, VTEC solenoid, the 'blanking' (?) plate on the intake side, Crank sensor, etc). The VTEC gasket was absolutely boogered, for example.
    On to the shiny cooling parts next.
  12. #27
    muffled screams
    Join Date
    Sep 2005
    Location
    Lilburn, Ga
    Posts
    18,807
    Finished the Wang install. Trimmed the trunk and got everything bolted back together. About all I need to do is grab some touch-up paint and clean up the bits I hat to cut to clear the uprights.
    I gave this no chance of actually working while cutting, but pulling the straps tight kept the trunk nice and rigid:
    To fully open the trunk, 2 bolts have to come out, but I was pretty sure that'd be the case before I started on this:
    Boom:
  13. #28
    Donated: $40
    Join Date
    Oct 2002
    Location
    Posts
    21,351
    Nice work!
  14. #29
    muffled screams
    Join Date
    Sep 2005
    Location
    Lilburn, Ga
    Posts
    18,807
    Took the mandatory park-bench shot:
    Then did some very important race car arts & crafts:
  15. #30
    muffled screams
    Join Date
    Sep 2005
    Location
    Lilburn, Ga
    Posts
    18,807
    With an incredible Chasing the Dragon Hillclimb in the books: It begins.
Similar Threads
  1. SCCA Solo in Mississippi
    By bighoopty in forum Pics & Builds
    Last Post: 03-07-2010, 11:39 AM
  2. SCCA Solo II event on the 19th.
    By ls six in forum Global
    Last Post: 03-30-2009, 12:46 PM
  3. 2009 SCCA Solo Rules
    By fatti03msp in forum Pics & Builds
    Last Post: 01-31-2009, 06:24 PM
  4. Mazdas247 @ SCCA Solo II Nationals
    By xelderx in forum Pics & Builds
    Last Post: 10-16-2007, 04:17 PM
  5. SCCA Solo Nationals News
    By JDuncan in forum Pics & Builds
    Last Post: 10-06-2006, 07:45 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
