Results 1 to 13 of 13
Thread: I have a few questions, fluid FL22, mileage and water pump
  1. #1
    Registered Member
    Mazda cx-9 2008
    Join Date
    Jun 2019
    Posts
    13
    Welcome. I am new to the forum. I have a few questions.
    1-Does cx-9 have to have FL22 fluid? Can I give Prestone?
    2-mileage is 175 thousand miles and do I have to replace the water pump? The fluid does not disappear, the oil also has a good condition.
    3- What is the engine's lifetime?
    4-of course, I have already repaired the transfer box and will now often exchange the oil.
    I read the forum but I am asking for a specific answer in my topic.
  2. #2
    Registered Member
    Mazda CX-9 Grand Touring 2016
    Join Date
    Sep 2016
    Location
    Washington, the state
    Posts
    532
    1--Ah...Prestone makes 15 different coolant formulations. https://www.prestone.com/products?ca...ductAntifreeze They claim that their AF6300 "Honda/Nissan" product is also suitable for Mazda engines.
  3. #3
    Registered Member
    2012 Mazda CX-9 Grand Touring FWD
    Join Date
    Aug 2012
    Location
    Houston, TX
    Posts
    79
    For me the Mazda coolant is cheap insurance. Have you seen what is involved with changing the water pump? Why take a risk with different coolant?
  4. #4
    Registered Member
    Mazda cx-9 2008
    Join Date
    Jun 2019
    Posts
    13
    Right. When I exchange liquid, it's the original mazda.Thanks
  5. #5
    Biggie T Skinny helbigtw's Avatar
    CX-3, CX-5 & CX-9 Moderator
    08 CX-9 GT Fwd, Bose/Nav, BSM,Compass/Homelink, Pwr Lift,Tow
    Join Date
    Feb 2011
    Location
    Pittsburgh, PA
    Posts
    2,127
    Along those lines, I'm at 102,000 miles 2008. May drain and fill original coolant this year. Thoughts? Is changing fluid a good idea or could it trigger the dreaded water pump explosion?
  6. #6
    Registered Member Z-Thrizzle's Avatar
    Mazda CX-9, BMW MZ3 Roadster
    Join Date
    Nov 2011
    Location
    Dallas, TX
    Posts
    89
    I agree with sticking with specified fluid. I was able to find FL22 either at autozone or orielly. If the engine was well maintained it can probably go 250k without needing major repairs.
    For an engine's health you can compare mpg, get leak-down test and or compression test done.
    Though I would start by monitoring the mpg and getting an oil analysis done. https://www.blackstone-labs.net/bsto...))/signin.aspx
  7. #7
    Registered Member
    Join Date
    Sep 2016
    Location
    Posts
    532
    Antifreeze life is more time related than mileage related. 11 years on the same juice is risky. Do a complete flush and renew. If the current stuff looks dirty, use a cooling system cleaning product according to the label directions. The corrosion inhibitors in the coolant become depleted with age.
  8. #8
    Join Date
    Feb 2011
    Location
    Pittsburgh, PA
    Posts
    2,127
    Well I still haven't flushed the coolant yet. May do that this week/weekend. Just worried about the water pump...disturbing whats in there now, putting new fluid in and then water pump seal decides to give way...
  9. #9
    Registered Member
    Mazda cx-9 2008
    Join Date
    Jun 2019
    Posts
    13
    You are afraid that the pump seal will be damaged by the new fluid?
  10. #10
    Join Date
    Feb 2011
    Location
    Pittsburgh, PA
    Posts
    2,127
    Yes. Similar to changing atf fluid on a transmission on the fritz where the gunk is removed and the disturbance of sludge causes failure. Wonder if that principle can be applied to a water pump...
  11. #11
    Registered Member
    2019 Mazda CX-9 Signature, Machine Grey Metallic
    Join Date
    Oct 2010
    Location
    Home
    Posts
    356
    Quote Originally Posted by helbigtw View Post
    This actually happened to our 2010 CX-9 where I had the transmission fluid flushed. Shortly thereafter, the transmission started to vibrate the vehicle at higher gears and eventually resulted in the transmission being replaced at, luckily, 55K miles and was covered by the powertrain warranty.
    Needless to say, I understand your concern.
  12. #12
    Registered Member
    Join Date
    Oct 2013
    Location
    trois-rivieres
    Posts
    67
    I also decided not to swap the coolant, i am just waiting for the car to die on it's own and figure i will be getting the water pump failure long before the acid coolant can cause any sort of damage to something else. 2007 with 200k miles, don't know if the coolant was changed by previous owner though
  13. #13
    Registered Member
    mazda cx-9, lux
    Join Date
    Jan 2012
    Location
    fla
    Posts
    7
    my waterpump died at 80k. lucky for me that it never overheated. 2400ish for a replacement.
Similar Threads
  1. how long does water pump, belts, radiator hoses, fuel pump lasts?
    By CX5BC in forum CX-5 Engine & Transmission
    Last Post: 09-12-2017, 03:35 PM
  2. Water pump!!!!
    By MAZDAROGER in forum CX-9 Engine & Transmission
    Last Post: 04-24-2017, 04:02 AM
  3. Bad water pump?
    By Hon2bmw in forum Protege5
    Last Post: 07-29-2013, 03:15 PM
  4. Water Pump
    By FreshPrince in forum Mazda Protege
    Last Post: 11-30-2004, 03:05 AM
  5. timing belt and water pump questions....
    By throthaduece in forum Mazda Protege
    Last Post: 05-21-2004, 07:53 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
