2019 cx-5 rear windshield fluid nozzle pattern
Hi, I just installed Aukey dual cam and noticed that the rear fluid is just running down. I don't remember if it was spreading or not since I never used it before (2000 miles). When I run usb cable to the rear window, I used the channel where the fluid runs to the nozzle. It doesn't look like there is any blockage. But, I just want know what the pattern should be. Thanks,
I guess you could try if one of the front fan jets would work.
  • Washer nozzle.pdf
  • Washer nozzle rear.pdf
