Compare auto reliability with reliable results at TrueDelta.com!
Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Thread: ABS Research, Mazdaspeed LSD Compatibility
  1. #16
    Registered Member
    lolmsp
    Join Date
    Mar 2007
    Location
    757
    Posts
    5,242
    this might not answer your question but will prolly be helpful. you will like Segment #2: LSD and 5th Gear Parts
    https://www.mazdas247.com/forum/show...-5th-Gear-Swap
    03 MSP, 03 P5
  2. #17
    Comp Engineering Student Riot_Polizei's Avatar
    2002 Mazda Protege5
    Join Date
    Jan 2018
    Location
    Colorado
    Posts
    479
    Oh yeah, pressing on the speedo gear really is the only solution. Major PITA of a job, and honestly, influenced my decision to not bother with a MSP transmission for the time being.
    Instead, I decided to mostly focus on these ABS speed sensors. If I can find a way to get speed readings without all that ABS equipment, then hot damn we're in business! It's largely a proof-of-concept kind of project.
    But really, that doesn't address the issue of OEM LSDs before revision 3. Unless you know for sure the transmission has a Revision 3 LSD in it, then you're going to have to open the transmission sooner or later.
    2002 Mazda Protege5
    ■ Sunburst Yellow ■ Black Rear Valence ■ Injen Cold Air Intake ■ Racing Beat Catback Exhaust ■ Moog Front Endlinks
    ■ Megan Racing Rear Strut Tower Bar ■ Racing Beat Rear Sway Bar ■ Mazda6 Front Big Brakes ■ Foglight Deletes
    ■ OBX 4-1 Headers ■ MP3 ECU ■ VTCS-less Intake Manifold ■ Mishimoto Aluminum Racing Radiator + Fan Shroud
    ■ AWR Trailing Arms
    ______________________________
Similar Threads
  1. 2003 Mazdaspeed Transmission replacement compatibility
    By elielc1 in forum Mazdaspeed Protege
    Last Post: 03-10-2012, 03:44 PM
  2. Research....Research....for a new or used 5...
    By wheelgarage in forum Mazda5 General
    Last Post: 01-05-2010, 03:06 PM
  3. Mazda 6 Research to Buy
    By drock02 in forum Mazda6 General
    Last Post: 03-28-2007, 05:50 AM
  4. little tire research
    By tsunami in forum Mazda3 Wheels, Tires, Brakes & Suspension
    Last Post: 02-17-2006, 04:29 PM
  5. did some research, but...
    By bizzy420 in forum Mazda6 General
    Last Post: 01-07-2005, 11:45 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
