Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: Wheel weight Qs and how if affects mpg?
  1. #1
    Registered Member
    Join Date
    Jun 2019
    Posts
    26
    1. Does anyone know weight of stock touring 17 wheels?
    2. Anyone know weight of the 19 pizza wheels?
    3. Anyone switched from one of the above to the other? And how did it affect gas mileage?
    Have the 17s on our new touring awd , and out of the gate mpg seems pretty damn good (28 mpg on drive home from dealer) . Not a big fan of the look and would like to upgrade to the pizzas or something aftermarket & clean-looking (almost an oxymoron), but dont want to sacrifice fuel economy to do so. Thanks for any input
  2. #2
    Registered Member
    Mazda CX-5 GT
    Join Date
    Jun 2017
    Location
    OH
    Posts
    170
    I measured my 19 pizza's at 31lbs.
  3. #3
    Registered Member
    Join Date
    Jun 2019
    Posts
    26
    Quote Originally Posted by SweetPete View Post
    Whoa...thats pretty heavy for a 19 wheel. Thanks for posting
  4. #4
    Work in Progress sm1ke's Avatar
    Donated: $25
    2018 Mazda CX-9 Signature
    Join Date
    Dec 2016
    Location
    MB, Canada
    Posts
    1,386
    There are plenty of clean looking aftermarket wheels that are cheaper and a little bit lighter than the OEM 19s. Try wheels from Niche (Misano, Vosso) or Rotiform (WGR, KPS, FLG).
    Rotiform also makes the SPF, which looks similar to the pizza wheel design. Their 19x8.5 +38 wheel weighs in at 26lbs and has a load rating of 1600 lbs. Also, the FLG wheel I listed above apparently weighs 16 lbs per wheel, according to their website. If that's accurate (and that's a big IF), I would opt for the FLG wheels. You'd get much better mileage with 16 lb wheels all around. But I think it's just a typo, as it's a cast monoblock wheel just like the other wheels I mentioned.
  5. #5
    Registered Member
    Join Date
    Jun 2019
    Posts
    26
    Thanks...Ive been looking at rotiform wheels among others, but most are still pretty heavy in the cast series. Would prefer to be around the 20-22 lb range for an 18 or 19 wheel.
    My favorite style Ive come across so far is the Axis FL01 as a real clean 5-spoke wheel (havent figured out posting pics) but it is on the heavy side at 26 lbs for a 19 wheel. What id really like to find is a set of mazdaspeed 6 forged split 5-spoke 18s, which I believe are make by Rays and weigh less that 20 lbs each
  6. #6
    Registered Member
    2017 CX5 GT AWD Premium
    Join Date
    Dec 2017
    Location
    Ventura County, CA
    Posts
    237
    Quote Originally Posted by Stickygreen View Post
    My OEM's pizzas with factory Toyos (with 900 miles on them) weighed 66.3 pounds. My 20" TSW Sprints with BFG 245/45 gForce Comp 2 tires weigh 59.4 pounds.
  7. #7
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,719
    Arrow Wheel weight Qs and how if affects mpg?
    Quote Originally Posted by wrxray View Post
    OE Toyo A36 tire weights 29 lbs. So the OE 19" pizza wheel should be ~37 lbs?
  8. #8
    Registered Member
    Mazda CX-5 GT
    Join Date
    Jun 2017
    Location
    OH
    Posts
    170
    Whoa...that*s pretty heavy for a 19* wheel. Thanks for posting
    FWIW - I replaced my pizzas with 20" wheels that weigh 27.1 lbs each.
  9. #9
    Donated: $25
    Join Date
    Dec 2016
    Location
    MB, Canada
    Posts
    1,386
    Quote Originally Posted by yrwei52 View Post
    Sounds about right. The OEM 20" rims on the CX-9 weigh 39.5 lbs each. I replaced them with 22" rims that weigh 36 lbs each.
  10. #10
    Registered Member concept's Avatar
    2014 Mazda3 S GT auto, 2008 MX5 6-speed
    Join Date
    Mar 2009
    Location
    San Diego
    Posts
    1,558
    1. Does anyone know weight of stock touring 17* wheels?
    2. Anyone know weight of the 19* pizza wheels?
    Have the 17*s on our new touring awd , and out of the gate mpg seems pretty damn good (28 mpg on drive home from dealer) . Not a big fan of the look and would like to upgrade to the pizzas or something aftermarket & clean-looking (almost an oxymoron), but don*t want to sacrifice fuel economy to do so. Thanks for any input
    You can get Flow One Race Spec and OZ wheels that are 20-22 lbs each in 19" X 8.5" size through tirerack. Forged wheels can be quite a bit lighter but at much higher cost.
    2014 3S GT, Deep Crystal Blue, Eibach Pro-Kit, Enkei PF01s, Koni Sports, Pirelli P ZERO ALL SEASON PLUS tires, 225/45/18
    2008 MX-5 Touring (Mazdaspeed CAI, HIDs, Progress/Koni Sports/Racing Beat sways, SST Magnaflow muffler and tips)
  11. #11
    Registered Member lowincash's Avatar
    2017 CX-5 GT w/ Premium Pkg.
    Join Date
    Jun 2013
    Location
    Los Angeles
    Posts
    622
    I'm not sure how much my 20's weigh but I definitely feel a difference compared to stock pizza wheels and tires. I'm currently on 20X9 wheels with 235/45r20 tires which overall diameter is a tad smaller than the stock 225/55r19. Car feels lighter on its feet and mpg is pretty much same or a tad better than when I had stock wheels. I never had the chance to compare and measure actual weight between both tho :/
  12. #12
    Registered Member
    Join Date
    Jun 2019
    Posts
    26
    For ride quality and tire prices, would probably want to stick with 17 or max 18 wheels. At this point looking into Enkei pf05 or maybe the even lighter rpf1s. Got a bit of time to figure it out until these stock Yokos wear out
  13. #13
    Registered Member
    Join Date
    Dec 2017
    Location
    Ventura County, CA
    Posts
    237
    Quote Originally Posted by lowincash View Post
    100% agree...ours is definitely more responsive with the lighter wheel/tire combo. Handles much better as well.
  14. #14
    Registered Member CX-5um's Avatar
    13' CX-5 and 16' Mazda6 both Touring w/Tech/Bose
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    3,077
    For ride quality and tire prices, would probably want to stick with 17* or max 18* wheels. At this point looking into Enkei pf05 or maybe the even lighter rpf1*s. Got a bit of time to figure it out until these stock Yokos wear out
    Although not a CX-5...I swapped my OEM 19's from my MAzda6 which are similar size/weight as the OEM CX-5 19's. Installed Enkei TS-10 18 x8.5 with 35 offset. Wheels are about 20-21lbs each.
    Damn.
    Improved braking, engine response, handling, looks, and easier to clean. The #1 mod you guys should be saving for any car imho is lighter quality wheels.
    http://enkei.com/video-enkei-ts-10-m...eries-weighed/
  15. #15
    Resident barbarian ColoradoDriver's Avatar
    Donated: $5
    2014 CX-5 Touring AWD
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    4,879
    Is that a lemon tree behind your car?
    2014 CX-5 Touring AWD 2.5L | Jet Black Mica - 82k miles
    01/2013 build | 4/20/2013 delivery
Similar Threads
  1. wheel weight
    By cruton5 in forum Mazdaspeed Protege
    Last Post: 05-18-2010, 01:39 AM
  2. wheel weight
    By Bret2002 in forum Protege5
    Last Post: 03-10-2009, 01:40 PM
  3. wheel weight anyone?
    By DiS in forum Mazda Protege
    Last Post: 08-11-2005, 09:09 PM
  4. Wheel Weight??
    By Familia323 in forum Mazda Protege
    Last Post: 06-13-2003, 05:15 PM
  5. wheel weight?
    By KBicknel in forum Mazdaspeed Protege
    Last Post: 02-28-2003, 04:19 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
