Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 56
Thread: Spark plug change interval confusion
  1. #16
    Registered Member
    16.5 CX-5 GT AWD w/Tech BRMica
    Join Date
    Oct 2015
    Location
    Dirty South
    Posts
    2,081
    Quote Originally Posted by Unobtanium View Post
    Changed mine around 80, or so? Ran the same. Same mpg. Plugs looked fine. plugs gapped within 0.001 of spec. Waste of money.
    Agreed.
  2. #17
    Registered Member
    Join Date
    Oct 2015
    Location
    Dirty South
    Posts
    2,081
    OP, run from your current stealership, and take it as a warning sign to stay away from all of them if at all possible...
  3. #18
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,703
    Arrow Spark plug change interval confusion
    Quote Originally Posted by 19sandyman View Post
    Do you happen to know the correct gap and torque spec? I believe the correct torque is 12-14 pounds.
    Spark plug manufactures usually don't recommend gap adjustment on iridium plugs.
    Quote Originally Posted by sergeyv View Post
    Workshop manual shows different plug on the pic though.
    Specification
    Spark plug type
    PE01-18110, PE02-18110
    Perhaps they're different from those in early models and 2016 has a different plug.
    Furthermore,
    Spark plug gap (PE01-18-110, PE02-18- 110)
    Standard: 0.751.10 mm {0.0300.043 in}
    New spark plug (reference): 0.750.85 mm {0.0300.033 in}
    Spark plug gap (PE5R-18-110, PE5S-18- 110)
    Standard: 1.051.40 mm {0.04140.0551 in}
    New spark plug (reference): 1.051.15 mm {0.04140.0452 in}
    I have never experienced any difference in ignition by installing a good NGK/Denso spark plug instead of OEM one. I've always used iridium or double iridium.
    Quote Originally Posted by jellyfish11 View Post
    Tightening torque
    1520 Nm {1.62.0 kgfm, 1214 ftlbf}
  4. #19
    Underutilized Member shadonoz's Avatar
    Donated: $5
    2017 CX-5 GT AWD Tech
    Join Date
    Oct 2017
    Location
    State of Jefferson
    Posts
    1,879
    Does anyone know of any other make/model that requires iridium plugs be replaced as soon as 40k? Seems way low.
  5. #20
    Registered Member RepeatMazda's Avatar
    '16.5 CX-5 Touring AWD
    Join Date
    Feb 2018
    Location
    IL
    Posts
    105
    Quote Originally Posted by NelsonLewis View Post
    Agreed.
    Really? Preventative maintenance is considered a waste of money? Do you notice a change when changing the oil, air filter, diff fluid, coolant, etc.? No of course not.
    If you do preventative maintenance and notice a performance difference, it means you went beyond the point that, that component or fluid was intended to last. Meaning you were running sub-optimally prior to the maintenance being completed.
    Quote Originally Posted by shadonoz View Post
    Alfa calls for 30k mile intervals on my the 2.0T Giulia.
    • 2016.5 CX-5 Touring AWD
    • 2018 Alfa Romeo Giulia Ti Sport Q4
  6. #21
    Registered Member
    Join Date
    Oct 2015
    Location
    Dirty South
    Posts
    2,081
    Quote Originally Posted by RepeatMazda View Post
    Yes, REALLY! He's saying he could've went to 100k easily, and I agree, however, I'll buy the NGKs and do it myself, so who knows when I'll change em, won't be before the 60k mile warranty is up, that is for sure... Don't get me started on preventative maintenance...You've got fools around here changing ATF at 15k miles, and every 15-30k thereafter...Comical. I'll run mine until I trade it in at 100k most likely, not a worry in sight...
    I have a car I change the spark plugs on at every oil change. Granted, it puts out almost 300hp p/liter to the wheels, and yes, you can damn sure tell when you don't... Cost me less than $8...lol
  7. #22
    Registered Member concept's Avatar
    2014 Mazda3 S GT auto, 2008 MX5 6-speed
    Join Date
    Mar 2009
    Location
    San Diego
    Posts
    1,550
    Feel lucky, I change my Turbo cars plugs every oil change...
    So every 7500 miles you change the plugs?
    2014 3S GT, Deep Crystal Blue, Eibach Pro-Kit, Enkei PF01s, Koni Sports, Pirelli P ZERO ALL SEASON PLUS tires, 225/45/18
    2008 MX-5 Touring (Mazdaspeed CAI, HIDs, Progress/Koni Sports/Racing Beat sways, SST Magnaflow muffler and tips)
  8. #23
    Registered Member
    Join Date
    Oct 2015
    Location
    Dirty South
    Posts
    2,081
    Quote Originally Posted by concept View Post
    Actually, every 3k (only car I do 3k mile oil changes on, if it makes it t0 3500-4k, who cares ). Cost $8, wtf not, plus, it's basically a given with the tune on the car...
    Granted, if I had a Skyactiv 2.5T, I'd roll with the 40k miles, but idk, I couldn't keep one stock, so I'm sure more frequent plug changes would be in order...lol
  9. #24
    Resident barbarian ColoradoDriver's Avatar
    Donated: $5
    2014 CX-5 Touring AWD
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    4,828
    Who here is changing their ATF at 15k miles? Methinks you over exaggerate.
    2014 CX-5 Touring AWD 2.5L | Jet Black Mica - 82k miles
    01/2013 build | 4/20/2013 delivery
  10. #25
    Registered Member
    Join Date
    Oct 2015
    Location
    Dirty South
    Posts
    2,081
    Quote Originally Posted by ColoradoDriver View Post
    Nope ,sure didn't...
    I've seen 15k, 30k, and 43k on here, with every 15-30k thereafter... All comical as all get out...Hopefully you can blame it more on gullible fools and stealerships more than preventative maintenance concerns...lol
  11. #26
    Join Date
    Feb 2018
    Location
    IL
    Posts
    105
    Over maintenance =/= preventative maintenance
  12. #27
    Registered Member
    Join Date
    Oct 2015
    Location
    Dirty South
    Posts
    2,081
    A stealerships dream come true...
  13. #28
    Join Date
    Feb 2018
    Location
    IL
    Posts
    105
    You're too dense to reason with. Hope you have a peachy day!
  14. #29
    Registered Member
    Join Date
    Oct 2015
    Location
    Dirty South
    Posts
    2,081
    I am actually eating a peach as I read this, how appropriate, thanks!
  15. #30
    Donated: $5
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    4,828
    Umm I think he agreed with you there Nelson in calling it overmaintenance.
Similar Threads
  1. Spark plug change from the Dealer- can this be right ??
    By tstex in forum CX-9 Engine & Transmission
    Last Post: 01-04-2014, 02:40 AM
  2. Reset ECU after spark plug change?
    By BADFISH6 in forum Mazda6 Engine & Transmission
    Last Post: 11-11-2009, 06:17 PM
  3. Spark plug change for Mazda 2
    By Kenfalzon in forum Mazda2 Lounge
    Last Post: 12-27-2008, 11:20 AM
  4. Spark Plug Change Causes Misfires
    By BettermanNZ in forum Protege5
    Last Post: 08-13-2007, 08:56 PM
  5. Spark Plug Gap Confusion... wtf?
    By crackerjakx in forum Mazdaspeed Protege
    Last Post: 02-20-2007, 01:49 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
