Mazdaspeed3 - Possible to change Adaptive Lens to Standard Headlights?
I have a set of standard Headlight lens that hopefully do not leak. I would like to replace the existing stock Adaptive Headlights out with the standard Mazda 3 (2011) headlights using standard bulbs. No problem fitting the standard headlight assemblies. THe question is - If I just swap to the standard ( not Adaptive) headlight wiring harness would there be any issues? There would be no ballast in this setup, so would I be able to run standard headlights and avoid all the trouble with the adaptives?
Any thoughts would be appreciated.
