Results 1 to 10 of 10
Thread: 2019 Oil Change - Fumoto Plug
  1. #1
    Registered Member
    Join Date
    Mar 2019
    Posts
    5
    Have a 2019 CX-9 with 4K miles. About to perform the 1st oil change. Was planning on installing a Fumoto valve; however, Fumoto website doesn't list a specific valve for the 2019 CX-9. Anyone installed a Fumoto Valve on a 2019 CX-9? Don't know if the overlying plastic cover will fit in place with Fumoto valve installed.
    Thanks for the help. Chad.
  2. #2
    Work in Progress sm1ke's Avatar
    Donated: $25
    2018 Mazda CX-9 Signature
    Join Date
    Dec 2016
    Location
    MB, Canada
    Posts
    1,368
    The plastic cover should not interfere with the valve. Skip to the 6-minute mark of this video:
    Since the drain plug is screwed in from the side and not from the bottom, it should not contact the cover when you reattach it. That said, even if it does, you could always just cut a hole to accommodate it, or take a heat gun to the plastic cover to soften and mold the plastic to accommodate the valve.
  3. #3
    Registered Member
    Mazda, 2016 CX-9 Signature
    Join Date
    Aug 2017
    Location
    California
    Posts
    17
    Just a quick comment about the video showing the oil change. It shows the OEM filter being replaced by a fram filter. Mazda stated to me that if something other than the OEM filter is used they will not warranty the motor. Mazda makes 2 filters that fit the 2.5. If you look at the OEM filter on the car you will notice the filter has 2 white strips. that is the filer for the turbo motor. The other filter has 1 strip. That filter is used on the non turbo motor. The filter for the turbo increases oil pressure at start up and warm up to help protect the turbo.
  4. #4
    Registered Member
    2019 CX9 GT AWD Sonic Silver
    Join Date
    Mar 2019
    Location
    Chicago area
    Posts
    11
    With all my cars I always bring my own oil and filter. I wonder if I should use the oem filter from the dealer for my first oil change. Whats everybody else doing?
  5. #5
    Donated: $25
    Join Date
    Dec 2016
    Location
    MB, Canada
    Posts
    1,368
    Quote Originally Posted by ntdouglas View Post
    Here's a notation I found in the owner's manual:
    If you elect to perform maintenance yourself or have your vehicle serviced at a location other than an Authorized Mazda Dealer, Mazda requires that all fluids, parts and materials must meet Mazda standards for durability and performance as described in this manual.
    I don't know what Mazda's standards are for durability and performance with regard to the oil filter, so I just use the OEM oil filters that I buy from my local dealer. To my understanding, there are 3 filters available, one made in Mexico, another made in Thailand, and another made in Japan. Apparently the "best" filter of the three is the Japan-made one, followed by the one made in Thailand.
  6. #6
    Registered Member
    Mazda CX-9 Grand Touring 2016
    Join Date
    Sep 2016
    Location
    Washington, the state
    Posts
    449
    Oil filters are one of the engine parts where the specs are not published. It's not like oil where the engine uses oil that meets industry standard specifications.
    Filter makers reverse engineer the original equipment filters. They may make a new filter to work with that engine, or they may take one from their catalog that they feel is close enough. In any case, if the filter causes engine damage the filter maker is always responsible. If any aftermarket item causes damage don't even think the warranty will cover that damage. I buy oil filters from the dealer (or maybe the same part number filter cheaper from an ebay or Amazon seller). If you use an aftermarket filter and have engine damage during the warranty period (unlikely but possible), it will be your job to prove to Mazda North America that the filter didn't cause it. Good luck.
  7. #7
    Registered Member
    Join Date
    Jun 2019
    Location
    Canada
    Posts
    1
    Quote Originally Posted by cpotter638 View Post
    I have been using Fumoto F106SX M14-1.5 XS series valve on my 2017 CX-9 GT since March 2018. No issues so far. The value is touching the plastic cover a little bit. Nothing to worry about.
  8. #8
    Registered Member
    CX-9, Mazda6
    Join Date
    Mar 2017
    Location
    San Diego
    Posts
    3
    I'm using the Fumoto F106N on both my Mazda6 and CX-9 (both 2016). The valve doesn't touch the cover at all. I tried the F106SX series at first, but it seemed too big and bulky to me so I swapped it for the F106N.
    I really like the N version as I can attach a plastic tube to the nipple and drain straight into an old 5 qt oil bottle. I've had the CX-9 one on there for almost 2 years and Mazda6 one one for just over 1 year and so far no issues with either.
    Edit: I always use the OEM filter. The MSRP for the CX-9 OEM filter is only ~$8.75 I think and is really high quality (especially the Tokyo Roki version, PY8W-14-302), so really no reason to buy aftermarket. I've heard that the Skyactiv filters have a special bypass or something that only one or two aftermarket filters (Wix I think?) replicate.
  9. #9
    Registered Member
    2016 Mazda Cx-9 Sport
    Join Date
    Jul 2018
    Location
    los angeles, California
    Posts
    23
    The valve fits under the plastic cover, my cx-9 is a 2016 but I got the 2017 version.... The 2019 is exactly the same as 2016-2019 so choose those.
  10. #10
    Registered Member
    Join Date
    Sep 2016
    Location
    Posts
    449
    Bypasses inside oil filters are common. Cold, thick oil can't move through the fine pores of the filter media without the risk of tearing the media, so a bypass valve lets it pass when a certain differential pressure is exceeded. WIX lists the bypass setting of their 57002 oil filter for our engines as having a bypass valve that opens at 11 to 14 psid...when the inlet pressure is 11 to 14 psi greater than the outlet, the bypass opens--maybe begins to open at 11 psid and is fully open at 14 psid. That's pounds per square inch differential; the difference between the inlet and the outlet, not the absolute pressure. It is more important that the engine get the full flow of oil from the oil pump than it is that the oil be filtered at that time.
Similar Threads
  1. Replies: 13
    Last Post: 05-30-2019, 10:57 AM
  2. Oil change/fumoto valve
    By cccx9 in forum CX-9 Engine & Transmission
    Last Post: 03-16-2016, 03:06 PM
  3. Fumoto Drain Plug Options
    By Boland01 in forum CX-5 Engine & Transmission
    Last Post: 06-10-2015, 05:42 PM
  4. Oil change with Fumoto-nipple
    By Rose Boy in forum CX-5 Engine & Transmission
    Last Post: 10-05-2014, 12:42 PM
  5. WTB: Dummy plug/change plug for p5
    By Demoniam in forum Completed Transactions
    Last Post: 10-21-2009, 05:14 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
