Anyone having oil filter leak?
2014 CX-9 Touring
Ive change filter brands 3 times and I still get a leak a few weeks after I change the oil. It was just a drip but now its enough that its getting on the oil pan. Its a 2014 with 49k miles.
Gasket on the pickup might be worn out/smashed in If that is indeed where it is coming from
Did the old filter gasket get left behind on the oil change. If there's a double filter gasket there it will cause a leak. The only way to know for sure is to remove the filter and do a visual inspection. Make sure the old one is not stuck to the engine block.
