Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
Thread: 70.00.335 Firmware
  1. #16
    Registered Member Srad600's Avatar
    2016 CX-5AWD GT+Tech/ 2018 CX-9AWD GT
    Join Date
    Jun 2015
    Location
    Chino hills, California
    Posts
    696
    Quote Originally Posted by corvetteboy6988 View Post
    Great, can you please share how to? Do I use the Mazda tool box program I downloaded?
    The Mazda toolbox program can be used for Map updates, not system updates.
    For a good tutorial on managing system updates visit the link below:
    https://mazda3revolution.com/forums/...ml#post1859114
    That is the most comprehensive set of online directions available.
    Essentially you need to download the update.
    Go through the process to clear DTC codes.
    Load the update to the CMU
    Check to make sure the updates took.
    You're done.
  2. #17
    Registered Member
    2019 CX-9 Grand Touring
    Join Date
    Oct 2018
    Location
    Phoenix, AZ
    Posts
    73
    I took my CX-9 to the dealer yesterday for an oil change and tire rotation. I also asked that they update the system and provided them with the .335 version number. When they returned the car they said that everything had been done on the work order including the system update. Before I drove away I checked the version and it was still .100. I pointed this out to the service guy and he acted surprised, checked with the shop and thanked me for letting them know about the new version. He then took the vehicle back to the shop and applied the .335 version.
    I keep hoping that I'm going to find a competent dealer (any brand). Hope springs eternal but particularly when it comes to car dealers, for me anyway.
    Sheesh!
  3. #18
    Registered Member
    2019 CX-9 GT AWD
    Join Date
    Mar 2019
    Location
    SF Bay Area
    Posts
    14
    Just a shout out to other firmware update newbies-- I performed my first firmware update today on my '19 GT with no drama. I'm fairly technical but I do think it is straightforward if you follow the instructions that come with the update files (post #2 on this thread). Some details:
    • Was previously at v .100, an update I had the dealer do a week after picking up the car (because it wasn't done ahead of delivery as I had requested)
    • Used an 8GB USB stick that was formatted FAT32; I believe it was USB 2.0 but not 100% sure
    • Copied files onto the USB stick using a Mac; I deleted a couple of the invisible files but not all; seemed to work just fine
    • Took about 4 min from when I initiated the update until the progress bar displayed
    • Took about 30 min overall from start to finish
    Nothing new here, but just letting others who might have cold feet know that it's not too hard. I'd prefer if I could just pull in to my garage, connect to my home WiFi, and do an OTA update as my buddy with a new Subaru Ascent can do... oh well. My car is way better looking!
    Also noticed a June update to the maps, for those that use built-in nav:
    http://infotainment.mazdahandsfree.c...language=en-US
    A NEW MAP UPDATE WAS MADE AVAILABLE IN JUNE, 2019.
  4. #19
    Registered Member
    2016 Mazda CX-9 Grand Touring
    Join Date
    Jun 2008
    Location
    Grafton, Massachusetts
    Posts
    108
    Congrats on the update! I've updated mine a couple times now, including one to install CarPlay. No problems at all.
    I saw that my 3-year availability for map updates had arrived about the same time as that update came out so I figured I'd better grab it. I haven't noticed any real changes EXCEPT there are a few speed limit *errors* on my short commute now. I'm kind of bummed that I updated and now I have to look at "30mph" on my way in when the posted speed is (and has been) 45. :-/ YMMV
  5. #20
    Registered Member
    2020 CX-9
    Join Date
    Jul 2019
    Posts
    3
    Quick question. Has anyone tried installing a firmware that was for another region? Does it break anything?
  6. #21
    Join Date
    Jun 2015
    Location
    Posts
    696
    Quote Originally Posted by Majeed View Post
    I havenít tried it personally but there are reports that your radio tuner will no longer work correctly.
    Sent from my iPhone using Tapatalk
  7. #22
    Registered Member
    Mazda 3 2.000cc F/L AT SDAN TOURING 2020
    Join Date
    Aug 2019
    Location
    Colombia
    Posts
    4
    Quote Originally Posted by Srad600 View Post
    You're done.
    on 2019aug16th I wrote:
    I followed this step by step, but committed a pair of mistakes and I'm worried if not completing the whole process might affect my Mazda 3 year 2020 operation.
    I have the 70.00.100 4A N version and I wanted to upgrade to 70.00.335 4A N, so I downloaded the "cmu150_ADR_70.00.335C_update.up" file and copied it to a 8GB USB stick previously 32 FAT formatted from https://my.hidrive.com/share/hsodpqja.l#$/Mazda_Firmware/4A%20N%20%28ADR%29/70.00.335C%204A%20N%20all%20MAZDAs
    My first mistake: I forgot to unpair two bluetooth devices before starting the whole process described at https://my.hidrive.com/share/hsodpqja.l#$/Mazda_Firmware/4A%20N%20%28ADR%29/70.00.335C%204A%20N%20all%20MAZDAs
    My second mistake: I didn't get off the car (step 7) but instead stayed inside and I moved something, so the alarm started to beep.
    On step 13 (System Update packages search), I received a message that no Update Software was found on the USB stick.
    I couldn't finish the process then.
    Should I be worried? Step 6 says "internally clear earlier set DTCs in CMU"
    Thank you very much in advanced for your prompt response.
    On 2019aug19th I editted:
    Quote Originally Posted by HeuristicAL View Post
    I am also experiencing the same thing. Any help would be super appreciated!
    I removed the room fuse for 6 minutes and started the whole process again, using a checked USB 32 FAT formatted and verifying the downloaded file (just followed the full, complete instructions) and now I have correctly installed the 70.00.335 firmware on my Mazda 3.
    I'm not willing to buy the hardware yet and try to install it, in order to use Iphone Car Play or Android Auto, because it seems very expensive and not so easy to install.
    I just wonder if I could download the Mazda Navigation software to a blank SD and make it work.
    Last edited by edmejia; 08-19-2019 at 06:10 PM. Reason: already solved the problem
  8. #23
    Registered Member
    Join Date
    Aug 2019
    Posts
    1
    Quote Originally Posted by edmejia View Post
  9. #24
    Registered Member
    Join Date
    Aug 2019
    Location
    Colombia
    Posts
    4
  10. #25
    Registered Member
    Join Date
    Aug 2019
    Location
    Colombia
    Posts
    4
    How can I enable touchscreen while driving on 70.00.335 firmware version Mazda 3?
    How can I disable the speed limit restriction for using the radio while driving? I have a passenger as copilot, the touchscreen doesn't work; it does, only below 5km/h which has no sense for another person trying to change radio stations in example.
    I've just installed firmware version 70.00.335 and I found some videos that have the instructions for lower versions, pressing 3 buttons and the pressing during 20 seconds the clear option at the screen but doesn't work with this version.
  11. #26
    Registered Member
    2018 CX9 Sig
    Join Date
    Oct 2018
    Location
    DC Metro
    Posts
    102
    If memory serves me correctly each SD card is specifically linked to the vehicle.
    Peace and blessings,
    Azeke
  12. #27
    Registered Member
    Join Date
    Aug 2019
    Location
    Colombia
    Posts
    4
    Quote Originally Posted by Azeke View Post
    Azeke
    Thanks! it seems so; I'll continue using Waze on my mobile phone then.
Similar Threads
  1. New firmware
    By Tonysmommy444 in forum CX-5 Infotainment
    Last Post: 08-21-2018, 01:39 PM
  2. Firmware
    By Jman136 in forum CX-5 General
    Last Post: 08-20-2017, 11:43 AM
  3. Firmware Upgrade?
    By jayenomics in forum CX-5 General
    Last Post: 08-10-2015, 04:27 PM
  4. firmware yes or no
    By Int3grity in forum Mazda CX-7
    Last Post: 02-28-2007, 09:20 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
