VersaTuner - tuning software for Mazdas
Results 1 to 4 of 4
Thread: code u0101 how can i fix?
  1. #1
    Registered Member
    Join Date
    May 2019
    Posts
    2
    Exclamation code u0101 how can i fix?
    hi I have a 2008 mazda 5 with 69,000 miles, the problem is the reverse not responding sometimes it make a strong shift 2nd to 3rd shift, in the 2014 the old owner replaced the tcm with the code u0101
    so I don't know if the problem id the tcm again. I appreciate some ideas for fix the problem so thanks for any help and tips to fix
  2. #2
    Registered Member
    2012 Mazda 5
    Join Date
    Apr 2013
    Location
    Vancouver
    Posts
    704
    Most likely a TCM failed.
    Check first for good power and ground going to it.
    80% it is just a complete transmission control module failure if power and ground ok. Dealer or mechanic shop can troubleshoot the module to be 100% sure but the cost to do it might be the same as the cost of doing a replacement yourself.
    If you know how to find the TCM, then you can probably remove and replace it and there is no special flashing of it or programming. You pretty much buy the unit, and install it. It should only cake a couple of hours.
    I see on ebay you can send in your TCM for $199 to have it repaired, or used for $250-$300 or a new for about $500
  3. #3
    Registered Member
    Join Date
    May 2019
    Posts
    2
    thanks i considering that option on ebay
  4. #4
    Registered Member
    2012 Mazda 5
    Join Date
    Apr 2013
    Location
    Vancouver
    Posts
    704
    Quote Originally Posted by siul View Post
    Check that you are getting a good ground first on that module to be sure, with time, rust can build up around the grounds and cause similar issue, lost communication with TCM. (as per the code you provided)
Similar Threads
  1. weird problem 2010 mazda5 error code u0101 and a few other u codes
    By rat240 in forum Mazda5 Engine & Transmission
    Last Post: 02-18-2017, 08:16 PM
  2. 2009 mazda 5 error code U0101 transmission
    By cghms3 in forum Mazda5 Engine & Transmission
    Last Post: 02-26-2016, 02:15 PM
  3. New guy with a question U0101
    By mcaswe in forum Mazda5 Engine & Transmission
    Last Post: 02-21-2016, 10:58 AM
  4. U0073 U0101 P2187 Check Engine Light ??
    By mattbrace in forum Mazda CX-7
    Last Post: 01-01-2014, 03:08 AM
  5. CELís P2089, U0100, U0101, U0140, AND U2064
    By cobblepots in forum Mazdaspeed3
    Last Post: 08-08-2011, 06:57 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
