Made in USA and Free Shipping on all orders shipped inside the US.
Results 1 to 4 of 4
Thread: Rear drivers side brake lock up
  1. #1
    Registered Member
    Join Date
    Mar 2019
    Posts
    1
    Hello,
    I recently bought a 2003 protege5 and I love it. Except I keep having an issue. The drivers side rear brake keeps locking up, to the point that it gets hot and is smoking.
    When I bought the car the same caliper was siezed (according to the mechanic who did the safety inspection) and he replaced the caliper. Shortly after, I had hot brakes on that specific brake, drivers side rear. I took it right back to the mechanic, he said everything was fine. But it continues to happen. After being stopped, shutting off the car and applying the parking brake, it seems to free up when I start driving again.
    I do have an intermittent abs and brake light that pops on quite often, but again the mechanic said he couldn't figure out why (I am going to look at the wheel sensors when I get a chance).
    Any ideas what would cause the brake to lock up intermittently and is it possibly related to the same issue causing the abs and brake lights? I will say everytime the brake has locked both the abs and brake lights have been off. Also, I think 2 out of the 3 times the brake has stuck it was raining. Just to reiterate the caliper is new, like a month old new. Thanks in advance for any ideas.
  2. #2
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,112
    Check your parking brake cable. It maybe seized.
    Make sure part number 11 rotates freely when you pull and release the lever.
    The Diagram Dude
  3. #3
    Registered Member Corphish's Avatar
    83 RX-7 Gsl, 2000 Mazda Protege LX, 2011 Mazda3 Sport i
    Join Date
    Aug 2016
    Location
    Baldwin, WI
    Posts
    355
    Id also check the caliper bracket could be bent!
  4. #4
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    368
    Perhaps the parking brake cable is sticking, and holding pressure on the pads?
Similar Threads
  1. Replies: 7
    Last Post: 06-11-2016, 07:18 PM
  2. Drivers side rear brake caliper
    By DRoyarcher in forum Protege5
    Last Post: 09-01-2015, 07:49 AM
  3. Drivers side front lock actuator
    By S80crewchief in forum Mazda5 How-To
    Last Post: 10-06-2014, 02:26 PM
  4. Replies: 1
    Last Post: 08-09-2011, 11:17 PM
  5. Drivers side rear door lock
    By S80crewchief in forum Mazda5 Accessories & Appearance
    Last Post: 04-01-2010, 12:05 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
