Page 5 of 36 FirstFirst ... 3456715 ... LastLast
Results 61 to 75 of 526
Thread: Dangerous cylinder deactivation trouble on 2018 CX-5 and 6 models
  1. #61
    Registered Member
    2014 CX-5 GT
    Join Date
    Dec 2013
    Location
    Lansdale, PA
    Posts
    1,969
    Quote Originally Posted by noderman View Post
    Your link does not work but you can easily search Mazda CX-5 on the site. I will say that the "issues" on that site read as if written by a group of 75 year old homeless men.
    2014 Silver Mazda CX-5 GT
    2017 Eternal Blue Mazda 3 Touring
    2018 Machine Grey Mazda CX-9 Signature
  2. #62
    Resident barbarian ColoradoDriver's Avatar
    Donated: $5
    2014 CX-5 Touring AWD
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    5,049
    Yikes, really sorry to hear of your problem OP. As someone who regularly pushes high RPM's accelerating, or going into manual mode (I don't have a sport mode in my 2014), this limp mode sounds downright dangerous and scary, and quite frankly I'm not sure I'd want the car anymore if it kept doing that. I hope wherever this leads and whatever you decide, that Mazda ends up making it right.
    So, just reading the posts, I will admit I don't fully understand what all these parts are. Is it safe for me to say the cause seems to be this rocker arm (I'm sorry I don't know what that is) is falling off, and the the CD screws with the oil pressure and creates the perfect environment for when you push to high RPMs, it goes into limp mode? Sounds like CD in and of itself while contributing to this happening, isn't the actual root cause. The faulty arm and/or design allowing it to fall off to begin with is. So while Yrwei is quick to call this a CD issue, would it be possible for this to happen without the CD? Does the CD just end up creating the right environment for this to happen? I guess what I am getting at is if a 2.5L SkyActiv NA without the CD (Gen 1s, and 2017's) also had this rocker arm fall off, would they never know? Seems odd.
    2014 CX-5 Touring AWD 2.5L | Jet Black Mica - 83k miles
    01/2013 build | 4/20/2013 delivery
  3. #63
    Registered Member
    Join Date
    May 2019
    Posts
    1
    The rocker arm falling off is in Mazda Service Alert No: SA-15/19 Issued 04/08/2019
    https://static.nhtsa.gov/odi/tsbs/20...59203-0001.pdf
  4. #64
    Registered Member
    Join Date
    May 2019
    Posts
    74
    Quote Originally Posted by ColoradoDriver View Post
    The cause of the rocker arm falling off is low oil pressure on the lifter during cylinder deactivation. This is due to the wrong programming in the PCM. My dealership told me that they were informed by Mazda that they had two suppliers of this PCM and one of the suppliers had the wrong program on theirs. If you have a 2106 CX-5 you do not have cylinder deactivation and I would say you have nothing to worry about.
  5. #65
    Donated: $5
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    5,049
    Quote Originally Posted by Go Hawks View Post
    Ah....that makes sense. Thanks for the clarification.
  6. #66
    Registered Member
    Join Date
    May 2019
    Posts
    74
    Quote Originally Posted by t.suv View Post
    Thanks for this info t.suv. So again I ask why is there no recall. My vehicle had this issue back in October of 2018. This bulletin is dated 4-8-19. And I know that my vehicle was number 19 that they knew of then. By the time I got my vehicle out of the shop they knew of 26 that had experienced this issue. Who knows how many now that have been reported? And who knows how many are out there with the issue but they haven't discovered it yet?
  7. #67
    Registered Member
    2013 Mazda CX-5 Sport FWD Auto
    Join Date
    Oct 2012
    Location
    FL
    Posts
    314
    Damn. Just changed the oil and rotated the tires on my mother in laws 2018. Wish I had read this thread and test drove/ floored it for grins and giggles. About ~12k on her odometer with primarily city driving. Not sure if she ever gets the opportunity to drive more spiritedly.
  8. #68
    Registered Member
    Mazda
    Join Date
    Sep 2018
    Location
    United States
    Posts
    22
    Can't Mazda disable CD to resolve this issue? I rather trade a couple MPG for peace of mind.
  9. #69
    Structural Member shadonoz's Avatar
    Donated: $5
    2017 CX-5 GT AWD Tech
    Join Date
    Oct 2017
    Location
    State of Jefferson - southern Oregon
    Posts
    2,068
    Thanks for posting that.
    Debris and contamination? The plot thickens.
    REPAIR PROCEDURE
    1. Remove the valve cover and inspect for any rocker arms that are broken or have fallen off, especially inthe cylinder deactivation area (cylinders 1 and 4). Refer to SA-041/18 if found.
    2. Remove the front and rear oil control valves for cylinder deactivation and inspect the oil control valvesand cylinder head port for contamination or debris (see photo).If contamination or debris is found, photograph your findings and place the solenoid and debris inseparate plastic bags for collection. Mark on each bag the location where contamination was found,then contact Hotline for instructions on creating a case where you can attach the photos
  10. #70
    Registered Member
    2018 CX-5 Sport
    Join Date
    Dec 2018
    Location
    NJ
    Posts
    445
    Here is my Service report from them changing my engine
    I now believe you now, thanks for that image. I agree, it should be a recall for all models with the faulty CD/PCM setting. And if they can't identify the ones with the bad PCM setting then all of them need to be recalled.
  11. #71
    Registered Member
    2018 CX-5 Sport
    Join Date
    Dec 2018
    Location
    NJ
    Posts
    445
    In the pictures, the debris looks like grease.
  12. #72
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,793
    Arrow Dangerous cylinder deactivation trouble on 2018 CX-5 and 6 models
    hopefully you guys can open that so all of you doubters out there will understand this is not a joke. I sincerely hope none of you have to experience this. I can't emphasize enough how important this is. You may be driving around with this problem as we speak. the only way you will know is if you get the RPMs high enough and maintain them for a bit. If the rocker is off your car will go into limp mode. They will need to reflash your PCM to the correct logic and obviously address your engine issue.
    Thank you to all of you out there who have been believing me and backing me up.
    Your repair invoice should silent those doubters right there. The service alert document from NHTSA should further prove there's a major issue on Mazda's cylinder deactivation system. I'm glad my hunch was correct and changed my mind getting a new 2018 CX-5 purely because Mazda suddenly added this problematic cylinder deactivation feature to its NA 2.5L starting MY 2018!
  13. #73
    Registered Member
    Join Date
    May 2019
    Posts
    74
    Quote Originally Posted by MyFirstMazda View Post
    MyFirstMazda I am glad you believe me now. Thank you.
  14. #74
    Registered Member
    2018 CX-5 Sport
    Join Date
    Dec 2018
    Location
    NJ
    Posts
    445
    Thank you for posting this very important issue.
  15. #75
    Registered Member
    Join Date
    May 2019
    Posts
    74
    Quote Originally Posted by yrwei52 View Post
    yrwei52 I believe you made the right choice in not buying the 2018. Mine is on a 3 year lease with 2 years remaining. I have tried to get out of the lease by moving up to the new CX-5 reserve with the Turbo at the same dealership that I bought the 18 at but it is going to cost me an arm and a leg to get out of it. So I wait for a couple years and hope that the new engine and PCM actually fixes the problem. So far so good but we will see. If nothing else I would like to see Mazda at least change the logic that puts the car into limp mode at those higher RPMs. That may make the car safer at least. But I have argued that point ad nauseam with Mazda and can't seem to make them change it.
Similar Threads
  1. A simple question for 2018 Mazda6 with cylinder deactivation owners
    By obrt in forum Mazda6 Engine & Transmission
    Last Post: 06-29-2019, 11:20 AM
  2. Maintenance on these newer 2018/2019 models
    By doesntmatterz in forum CX-9 Lounge
    Last Post: 12-09-2018, 12:25 AM
  3. Cylinder deactivation
    By sjbraun55 in forum CX-5 Lounge
    Last Post: 03-10-2018, 10:57 PM
  4. KF CX-5 with Cylinder Deactivation coming to EU
    By Jedi54 in forum CX-5 Lounge
    Last Post: 11-18-2017, 12:56 AM
  5. 2018 MPG - FWD and AWD Models
    By Triton46 in forum CX-5 Lounge
    Last Post: 05-03-2017, 02:22 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
