Page 4 of 47 FirstFirst ... 2345614 ... LastLast
Results 46 to 60 of 696
Thread: Dangerous cylinder deactivation trouble on 2018 CX-5 and 6 models
  1. #46
    Registered Member
    2018 CX-5 Sport
    Join Date
    Dec 2018
    Location
    NJ
    Posts
    497
    Quote Originally Posted by joemazdacx5 View Post
    so I have a 2019 sport cx5 , how would I try and replicate this failure
    what steps to try and follow ?
    have cx5 in sport mode or normal mode ?
    cruise control on ?
    what speed ?
    then what , just give it gas ?
    just wondering , If I should be complaining to mazda about 'CD' ..
    thanks
    You can't complain about CD if it hasn't failed. It sounds like he was cruising at 55 mph or so in sport mode and pushed the pedal to the floor to get it to exceed 5K rpms. So try that if you want
  2. #47
    Registered Member
    2018 CX-5 Sport
    Join Date
    Dec 2018
    Location
    NJ
    Posts
    497
    I'm calling this BS. I will change my mind if he comes back with pictures.
  3. #48
    Registered Member
    Donated: $5
    CX-5 GT
    Join Date
    Aug 2014
    Location
    Ontario
    Posts
    543
    cruise control on ?
    what speed ?
    thanks
    Quote Originally Posted by MyFirstMazda View Post
    My guess is that some engines were not assembled correctly or bad parts were used, in order for a rocker to fall off. The spring tension will keep it in place. Maybe a spring broke. And it blows my mind that an engine can run with a rocker sitting under the valve cover somewhere and the valve stuck open. Did you hear any loud noise at any point come from the motor?
    The affected valve stays closed all the times. The second valve does all the work in this case. At low speed that's enough of air for stoichiometric ratio. At WOT the air flow is not sufficient, hence the limp mode.
  4. #49
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,077
    Arrow Dangerous cylinder deactivation trouble on 2018 CX-5 and 6 models
    I agree with yugrus. When rocker arm fell off the valve would stay closed by the pressure from valve spring. And the other intake valve for cylinder #4 is still functioning and the engine runs fine at lower RPM.
  5. #50
    Registered Member
    17 Mazda 6 GT
    Join Date
    Apr 2017
    Location
    Ontario, Canada
    Posts
    606
    I was thinking this right from the initial post.
    I would like to see some proof before jumping to conclusions.
    Pictures, copies of the service documentation from the dealer when the engine was replaced, etc.
    This sounds like something Mango would come up with to discredit Mazda.
  6. #51
    Structural Member shadonoz's Avatar
    Donated: $5
    2017 CX-5 GT AWD Tech
    Join Date
    Oct 2017
    Location
    State of Jefferson - southern Oregon
    Posts
    2,329
    So what we need is for every 18 and 19 NA owner to go out and floor it at 4k and report back.
  7. #52
    Registered Member
    Join Date
    May 2019
    Posts
    74
    You obviously havenít read the whole thread. To understand what is happening go back and read the whole thread. No springs broke. These are hydraulic lifters. The problem is with the cylinder deactivation.
  8. #53
    Registered Member
    Join Date
    May 2019
    Posts
    74
    My wife and I could have died. Do not call bs. Call the Mazda dealership in Pasco Washington. I have a lot better things to do than make up stuff to randomly post on a Mazda forum. I am trying to get the word aout about this so maybe it will save a life. If you choose to disregard that is your option but DO NOT call me a liar!
  9. #54
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,077
    Quote Originally Posted by shadonoz View Post
    Honestly I can't imagine someone can come up a fake story about a fallen rocker arm on cylinder #4 in such detail. Coincidentally just 9 days ago there's another report by jjm86m with exactly the same symptom and the same error code of misfire on cylinder #4.
    IMO the report by OP is legit.
  10. #55
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,077
    Quote Originally Posted by Go Hawks View Post
    This's a Mazda forum and you shouldn't be surprised when you write a negative post some people here would choose to bury their head in the sand and defend Mazda's reputation to death. Just post some evidence and they'll have nothing more to say.
  11. #56
    Registered Member
    2014 CX-5 GT
    Join Date
    Dec 2013
    Location
    Lansdale, PA
    Posts
    2,001
    I believe you. Cars fail. I don't know if this is a big issue or not. There are close to 200K of these on the road and I have not heard many mentions of this. Yours honestly is the first.
    2014 Silver Mazda CX-5 GT
    2017 Eternal Blue Mazda 3 Touring
    2018 Machine Grey Mazda CX-9 Signature
  12. #57
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,077
    Quote Originally Posted by dougal View Post
    No, his is the second in recent days.
    There's another report just 10 days ago with exactly the same symptom and the same error code of misfire on cylinder #4.
    18' CX5 Limp Mode at Redline
    Most CX-5 owner won't push their engine over 4,000 rpm, hence the symptom won't show even if one of the the intake rocker arms on cylinder #4 has dislodged.
  13. #58
    Registered Member
    Join Date
    May 2019
    Posts
    74
    Here is my Service report from them changing my engine
    Attached Images Attached Images
  14. #59
    Registered Member
    Join Date
    May 2019
    Posts
    74
    hopefully you guys can open that so all of you doubters out there will understand this is not a joke. I sincerely hope none of you have to experience this. I can't emphasize enough how important this is. You may be driving around with this problem as we speak. the only way you will know is if you get the RPMs high enough and maintain them for a bit. If the rocker is off your car will go into limp mode. They will need to reflash your PCM to the correct logic and obviously address your engine issue.
    Thank you to all of you out there who have been believing me and backing me up.
  15. #60
Similar Threads
  1. A simple question for 2018 Mazda6 with cylinder deactivation owners
    By obrt in forum Mazda6 Engine & Transmission
    Last Post: 06-29-2019, 11:20 AM
  2. Maintenance on these newer 2018/2019 models
    By doesntmatterz in forum CX-9 General
    Last Post: 12-09-2018, 12:25 AM
  3. Cylinder deactivation
    By sjbraun55 in forum CX-5 General
    Last Post: 03-10-2018, 10:57 PM
  4. KF CX-5 with Cylinder Deactivation coming to EU
    By Jedi54 in forum CX-5 General
    Last Post: 11-18-2017, 12:56 AM
  5. 2018 MPG - FWD and AWD Models
    By Triton46 in forum CX-5 General
    Last Post: 05-03-2017, 02:22 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
