Compare auto reliability with reliable results at TrueDelta.com!
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: driver headlight not working, need help
  1. #1
    Registered Member
    Join Date
    Apr 2019
    Posts
    6
    Lightbulb driver headlight not working, need help
    My 2003 P5 driver side headlight is out and I am wondering what the cause can be. I have already changed out the bulb (not the issue) and have checked the fuses (none of them blew out). Is there anything else I can check to see what my issue is?? Thanks in advanced
  2. #2
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,237
    You might need a new adaptor.
    They get all burned up and crispy.
    A lot of guys here on the forum have problems with the bulbs burning out two or three times a year.
    The Diagram Dude
  3. #3
    Registered Member STudMUffin1177's Avatar
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham
    Posts
    321
    When I was driving my p5 daily I ate up headlights about once a month and had to get all new adapters for my driver side because crispiness
  4. #4
    Registered Member
    Join Date
    Apr 2019
    Posts
    6
    my issue is with the main headlight and that part doesnt look like the one for the main. its the light where you have to twist it and then pull it back. is there an adapter for the main headlight also? sorry for the noob questions... im a yung P5 owner haha
  5. #5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,237
    The bulb that you twist then pull out is the high beam bulb.
    The low beam has the adaptor and is held in by a wire spring thing.
    The spring clip is a PITA to deal with and it's really hard to get in there to replace the bulb.
    You'll get good at changing the bulb because you might have to do it every month. lol
  6. #6
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    380
    p5 headlights suck. I buy in bulk. My current driver's headlight is about a year old now and still going good. sometimes I get one that lasts. Sometimes They last a few weeks or a couple months. MY sequoia has had the same headlights for the 10 years we've owned it. I don't get it lol That's probably why the previous owner added one of those cheap HID conversion kits...
  7. #7
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham
    Posts
    321
    A year on one bulb?!?! That's gotta be a p5 record right there
  8. #8
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,237
    I've had my car 9 years now and I'm only on my third set of bulbs.
    I don't drive much but I drive with all my lights on all the time.
    (I did the mod where all lights turn off with the ignition.)
    I'm guessing that my yearly undercoating/oil spray has kept all my grounds conducting properly so that my ECU gets proper voltage readings and isn't turning the alternator up and down creating voltage spikes.
    (Krown sprays all wires and connectors.)
  9. #9
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    380
    Quote Originally Posted by pcb View Post
    I don't think that has anything to do with my headlights. The only rust anywhere on my car is a little bit on the hood from where rock chips are, and that's just a little surface rust. I just think it's a crappy design. I just got tired of spending $15/bulb on the nice sylvanias and ordered a 10 pack of bulbs on ebay for like 8 bucks. Funny thing is they last longer than the good bulbs lol
    My headlight woes are over though now, I bought a new truck yesterday so p5 is up for sale. nothing wrong with the car, but not much point in keeping it, i'm the only one in the house that can drive a stick lol
  10. #10
    Registered Member
    Join Date
    Apr 2019
    Posts
    6
    yeah its the high beam bulb.
    my issue is that I already replaced the high beam bulb but for some reason when i reinstalled it that the light wont turn on. ive checked the fuse and its fine and I even switched the right side bulb to the left side and the bulb is not the issue. im thinking it might be a grounding issue or maybe the wire is cut somewhere but Im not sure where to look to further diagnose the issue
  11. #11
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,237
    You might have a bad bulb socket.
    Try to test for power on the wires feeding it.
  12. #12
    Registered Member katapaltes's Avatar
    2003 Protege5
    Join Date
    Mar 2009
    Location
    Dallas, TX
    Posts
    166
    Use dielectric grease when installing bulbs in the P5 and your problems will be over - or at least greatly reduced. I was replacing every year until I started using it.
    Protect boys (and the men they become) from harm: www.luckystiff.org (my website)
  13. #13
    Registered Member NaturalFlavored's Avatar
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    601
    I just replace my bulbs every December. Haha I drive my car all the Time so I have to replace them. I put on an average of 11k a year
  14. #14
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    601
  15. #15
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    380
    Quote Originally Posted by NaturalFlavored View Post
    The first 3 years I owned the car I put about 120k miles on it. The last year and a half I owned it I changed job duties and work from home, I might have put 10k miles on it but I don't think it was even that much. Most of that was just driving to the airport and back.
Similar Threads
  1. Working on the Driver
    By CorkSport Blog in forum CorkSport
    Last Post: 06-19-2018, 12:40 PM
  2. Headlight not always working
    By Scott P in forum CX-9 General
    Last Post: 07-20-2016, 07:01 PM
  3. Replies: 6
    Last Post: 12-10-2011, 10:07 AM
  4. Replies: 1
    Last Post: 09-22-2011, 08:38 PM
  5. Passenger headlight not working.
    By 1991Syclone in forum Mazda5 Infotainment
    Last Post: 10-28-2008, 11:50 AM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
