Results 1 to 7 of 7
Thread: AC compressor clutch replacement?
  1. #1
    Registered Member
    Join Date
    Apr 2019
    Posts
    3
    Hi there, I have a 2014 CX-5 Grand Touring. Does anyone know if it's possible to replace the clutch on the ac compressor without removing the whole compressor? I really don't want to have to pay to evacuate it the whole thing!
    Thanks,
    tim
  2. #2
    Banned Chris_Top_Her's Avatar
    Donated: $45
    CX Moderator
    '15 CX-5 Miata GT AWD w/Tech 2.5L
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,347
    Quote Originally Posted by taschmidt View Post
    Thanks,
    tim
    You CAN buy a kit for it. It's like $40. I replaced mine last month. The assembly was jacked, but I was able to buy a used compressor unit for $78. I put it in the recycle bin otherwise I'd take a look for you. However I will say that the space around that pulley area is VERY limited as it's close to the frame.
  3. #3
    Registered Member
    2019 CX5 Reserve AWD
    Join Date
    May 2015
    Location
    Delaware
    Posts
    809
    Thanks,
    tim
    You can do it on the CR-V so I'd be surprised if you couldn't on the CX-5. They probably use similar A/C systems.
  4. #4
    Registered Member
    Join Date
    Apr 2019
    Posts
    3
    Thanks for the info, @Chris_Top_Her! So where did you see a kit for $40? The best I saw after a brief search was ebay for $120...
    https://www.ebay.com/itm/NEW-A-C-Com...7/123021473837
    Why didn't the kit work for you?
  5. #5
    Donated: $45
    CX Moderator
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,347
    Apparently the $40 was actually older year mazda kits being mixed in with results. But I didn't even go that route because there are quite a few complete units from LKQ for under $80 on ebay.
  6. #6
    Registered Member
    Mazda cx5 sport 2013`
    Join Date
    Feb 2015
    Location
    newyork
    Posts
    80
    How did you make out my clutch make a sequel every time ac in gauges , i changed belt and watched not the belt .
  7. #7
    Registered Member
    Join Date
    Apr 2019
    Posts
    3
    In case anyone else is interested, you can in fact replace the clutch on the compressor without (fully) removing it. The refrigerant lines going to it are fortunately flexible enough that I was able to unbolt the compressor from the engine and move it enough to get at the compressor. Just be careful you don't let the compressor hang by those hoses, obviously you don't want too much tension on those.
Similar Threads
  1. Replies: 1
    Last Post: 09-05-2016, 05:07 PM
  2. AC Compressor replacement
    By dishe in forum Mazda3 Engine & Transmission
    Last Post: 08-09-2015, 04:09 PM
  3. AC Compressor Clutch Issue
    By DeCaro in forum Protege5
    Last Post: 03-31-2013, 04:11 PM
  4. Replies: 5
    Last Post: 03-31-2010, 09:07 PM
  5. Replacement A/C Compressor sources.
    By 1991Syclone in forum Mazda5
    Last Post: 12-12-2008, 03:10 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
