Made in USA and Free Shipping on all orders shipped inside the US.
Results 1 to 4 of 4
Thread: Stuck Clutch After Engine Change
  1. #1
    Registered Member
    Join Date
    Apr 2019
    Posts
    5
    I changed the engine in my 06-3. Everything is in, the wires too, the axles. My current problem is that the clutch release fork is engaged, as if the clutch pedal was floored. The pedal does go to the floor just tapping on it, and has to be be returned by hand. Fluid is full. I'm gonna try to lever it back into position. It will suck if I end up having to remove the transmission again after all the work... Crossing my fingers that someone will offer advise and this is something that I'll be able to solve with the engine and tranny in place.
  2. #2
    Registered Member
    Join Date
    Apr 2019
    Posts
    5
    Slave cylinder is bad, but it is bad because the clutch release collar seems to be off. I took the rubber "gasket" that the release fork goes through, and it looks like there's a tiny bit of space to meddle with a flathead screwdriver or something similar, to try to move it into position. We'l see.
  3. #3
    Registered Member concept's Avatar
    2014 Mazda3 S GT auto, 2008 MX5 6-speed
    Join Date
    Mar 2009
    Location
    San Diego
    Posts
    1,652
    Be persistent and don't give up.
    2014 3S GT, Deep Crystal Blue, Eibach Pro-Kit, Enkei PF01s, Koni Sports, Pirelli P ZERO ALL SEASON PLUS tires, 225/45/18
    2008 MX-5 Touring (Mazdaspeed CAI, HIDs, Progress/Koni Sports/Racing Beat sways, SST Magnaflow muffler and tips)
  4. #4
    Registered Member
    Join Date
    Apr 2019
    Posts
    5
    Thank you for the encouragement, Concept. I will keep on. I'll try to turn both wheels today, while having the transmission on first gear. I want to confirm that the transmission actually gets movement from the flywheel. It should, but I just feel that I need to confirm before I take the whole thing down again.
Similar Threads
  1. clutch pedal stuck
    By mstep in forum Protege5
    Last Post: 04-29-2013, 06:43 PM
  2. Replies: 3
    Last Post: 01-31-2013, 12:39 PM
  3. Clutch pedal stuck...??? Help!!!
    By gsmooth in forum Protege5
    Last Post: 01-16-2011, 03:55 PM
  4. Clutch pedal getting stuck?
    By Jack Rot in forum Protege5
    Last Post: 03-02-2010, 02:37 AM
  5. Replies: 12
    Last Post: 09-28-2007, 10:41 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
