VersaTuner - tuning software for Mazdas
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Exhaust Issue - pre-cat
  1. #1
    Registered Member
    02 Protege LX, 03 P5 (x2), 09 Miata, 07 Mazda3, 13 Fit, 09 Ody
    Join Date
    Aug 2013
    Location
    MD
    Posts
    106
    So, got some issues with rust and where the bolts attach has rusted off and I have a leak...
    I was able to 'crack' all the bolts.
    Well... broke this one off...
    Whomever put this on put a different sized nut...
    in between 13mm and 14mm ... ???
    Is this nut supposed to come off? Or is it welded on and you just screw into it?
    So... question time..
    1) What parts do I need? I'd like to get all new nuts and bolts? Is there a piece (like a gasket) that fits in between the two where it is leaking?
    Looks like there is a gasket on the other end closer to the engine.
    2) Can I just take this one piece off without dissembling the rest of the exhaust? It looks like I can, just want to make sure.
    3) Are those nuts in the last pic supposed to come off?
    4) What SAE size is in between 13mm and 14mm? I don't have any SAE sockets. So, I'll need to get one.
    Thanks
    13 Fit | 09 Ody | 09 Miata | 07 Mazda 3 | 03 Protege5 | 02 Protege
  2. #2
    Registered Member NaturalFlavored's Avatar
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    577
    Yes they can come off. The cat can come off from the header and the downpipe. I've taken mine apart when I was taking it off for a aftermarket header.
    With rust it's not going to be easy you might have to drill into it if you can't get a socket on it for it to come apart.
  3. #3
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,099
    Quote Originally Posted by smetzger View Post
    Those nuts may have been 14 mm but shrunk due to rust loss.
    I had some 14 mm bolts on my strut that were so rusted the 14 mm was loose and striped it, so I hammered a 13 mm on it.
    You may need to use a visegrip on them.
    I've found that the original Vise Grip brand by Irwin work way better. The cheaper visegrips are crap and the jaws get all sloppy and falloff the bolts.
    You may need to cut them off and a grinder with a cutoff wheel can work, if you can fit it in there.
    A Dremel tool with a cutoff wheel will work too for tighter spots but it's slower going.
    13 mm is slightly bigger than 1/2"
    The Diagram Dude
  4. #4
    Registered Member
    Join Date
    Aug 2013
    Location
    MD
    Posts
    106
    Well since the bracket holding the front bolts rusted completely off and the back nuts have to come off... I don't need to worry about that weird sized one. Which is good because 17/32 = 13.5mm. Amazon and ebay didn't have any 17/32 deep sockets.
    I'll have to get under their later this week and see if I can break free those back nuts.
    Looking at parts... many do not have that middle bracket
    https://www.rockauto.com/en/moreinfo...430264&jsn=375
    How important do you think it is?
    FYI - this is my 02 LX with 311k miles, burns 2 qts of oil every 4000 miles and has lots of rust.
    I am thinking just get the cheapest pipe because the pipe will most likely far outlast the rest of the car.
  5. #5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,099
    I hear that.
    This is what I did. I didn't spent any money.
    There's a donut style metal gasket in there too.
  6. #6
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    577
    https://photos.app.goo.gl/BeX4RrSiobARBLXMA
    I have mine for sale still in tact, no cracks. I'm selling for $20 plus shipping.
  7. #7
    Registered Member
    Join Date
    Aug 2013
    Location
    MD
    Posts
    106
    Quote Originally Posted by NaturalFlavored View Post
    pm sent
  8. #8
    Registered Member
    Join Date
    Aug 2013
    Location
    MD
    Posts
    106
    Quote Originally Posted by pcb View Post
    I hear that.
    That is pretty impressive. Cars are getting old, many of us are just keeping them alive. Maybe we should have a thread on "doing it wrong, but I don't care"
    The front rad support on the car was knocked in a little bit in minor accident. I have some 1" pieces of wood for spacers so the grill fits on.
  9. #9
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,099
    If I would've tried to replace that same part,
    (which obviously I should have done), I could well have ended up replacing my entire exhaust.
    Fricken Rust Turds !!
  10. #10
    Registered Member Regal Eagle's Avatar
    '02 Protege5
    Join Date
    Aug 2018
    Location
    The North South
    Posts
    17
    I do not want to thread-hijack but better that than start a whole new one so here goes;
    I bought a steel exhaust header and noticed that the post cat O2 Sensors' wire is grounded to the cat or the wire is attached to the cat so the wire doesn't move around as the cars in motion or to simply protect the wire from heat? Whatever the reason the wire is attached, not plugged in, in 2 places on the cat.
    My question is can I disregard the brackets that holds onto the post-cat O2 Sensor wire when I install my steel header? whatdo
  11. #11
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,099
    I would suspect that if the cat is fully grounded to the rest of the exhaust through bolts and nuts and continues to the engine ground and ECU you should be fine.
    If unsure, connect a ground wire.
    The "shield wire" needs a good ground.
  12. #12
    '02 Protege5
    Join Date
    Aug 2018
    Location
    The North South
    Posts
    17
    I've been spaying PB Blast on a few stubborn bolts on that exhaust so haven't been on here but thanks for the info.
    I was also reading about EGR Valve related threads on here and was considering deleting it but now I don't want to. Every modification I make to this car someones likely talked about it on here
  13. #13
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,099
    Quote Originally Posted by Regal Eagle View Post
    I've been spaying PB Blast on a few stubborn bolts on that exhaust...
    I'm not touching my exhaust unless I have to.
    I'd need PB sandblaster. lol
    ... Every modification I make to this car someones likely talked about it on here
    Yea, but it can be hard to find the info that might be hiding in a 15 year old thread.
  14. #14
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,099
    If by bracket, you mean this thing, then no, you don't need the bracket as a ground because the wire is insulated by plastic anyway.
    You may need the bracket to hold the wire out of the way though.
  15. #15
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    363
    Get a set of these https://www.lowes.com/pd/irwin-bolt-...IaAgZfEALw_wcB
    And one of these
    https://www.homedepot.com/p/TEKTON-3...B&gclsrc=aw.ds
    you'll thank me later. You'll probably have to replace all the nuts, but that's probably a good idea anyway looking at the rust.
Similar Threads
  1. corksport exhaust issue
    By NOTB4ME in forum Protege5
    Last Post: 07-14-2012, 04:24 AM
  2. Exhaust/Mounts Issue
    By mach'er in forum Protege5
    Last Post: 09-11-2008, 06:07 PM
  3. Vibrant exhaust rubbing issue.
    By Tonesteeno in forum Mazdaspeed Protege
    Last Post: 07-27-2008, 03:36 PM
  4. Corksport Exhaust Issue
    By Hypnotized in forum Mazdaspeed Protege
    Last Post: 04-25-2006, 08:33 PM
  5. exhaust hanging issue
    By 9ringer in forum Protege5
    Last Post: 01-25-2005, 07:55 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
