CorkSport.com is MAZDA PERFORMANCE!
Results 1 to 9 of 9
Thread: Aftermarket intake/exhaust and fuel trims
  1. #1
    Registered Member
    '02 Mazda Protege5
    Join Date
    Apr 2017
    Location
    Mount Kisco NY
    Posts
    77
    So I'm not posting about a problem per se but rather out of general curiosity.
    I installed a short ram intake (from eBay) and an HKS hi-power muffler for my P5. I like the sound it makes, not sure if there's a noticeable power increase but they say maybe a 5-10HP increase total. so not much. I bought it to make it sound and look better anyway.
    I noticed on my scan tool my Fuel trims are elevated now. STFT is mostly in the single digits but will spike to double digits and the LTFT is consistently in low teens after resetting ECU from the scan tool. I saw a reading of 18% briefly too. This was while driving at various speeds/RPMs/Loads. There is no CEL however. prior to changing the intake the fuel trims were less than +/- 7% all around. So is that normal for an aftermarket intake? Will driving around for a few days will the ECU "learn" the new intake? or maybe I have a vacuum leak somewhere although I doubt it because i made sure the intake was on tight.
    I'm kind of new to fuel trims but it makes sense that a better intake system= more air being drawn into the engine = more fuel has to be added to compensate which adds the 5 or so horsepower, but the ECU is factory tuned to the stock intake so the O2 sensors have to pick up on the changes.
  2. #2
    31N007 KingOfSpades007's Avatar
    Mazda Protegé5
    Join Date
    Dec 2011
    Location
    Canton, MI
    Posts
    699
    LTFT is what the ECU "learns" over time as it realizes it has to continue adding or taking away fuel. As long as STFTs are low/ in the single digits when the car is at temp/ relatively steady state, I wouldn't be too worried. LTFT can be adjusted by the ECU to a certain point, so there's some room for changes (as you've seen, increased flow). I would be inclined to agree with you that, over the next few days/ weeks, the ECU should learn to work around the increased flow and trims SHOULD average out. If you're not fussed about radio presets, you could unhook the battery for 5-10 minutes and let the ECU reset itself/ relearn faster.
    It's interesting to see how different cars work with fuel trims. My Subaru has STFTs all over the place (within the mid-teens pretty consistently) and when I looked at first I thought I'd had a vacuum leak.
    I need a brain.
    2002 Protege5
    Performance
    TWM SS
    CS shifter bushings
    Fidanza flywheel
    Eibach springs
    Tokico Illumina 5 way adj. struts
    AWR MM (all 4)
    RE71R on Filk FTDs
    Visual
    JDM tails
    Mini H1 7.0 35W 4500K
    1996 Subaru Impreza Outback
    Winter beater
    1993 Ford Escort GT
    "The Rally-X Pig"
    That cone looked rather tasty...
  3. #3
    Comp Engineering Student Riot_Polizei's Avatar
    2002 Mazda Protege5
    Join Date
    Jan 2018
    Location
    Colorado
    Posts
    465
    Quote Originally Posted by wrathofpaul View Post
    Fancy that, I just went through an ordeal like this :^)
    When I fixed my fuel trim issue, which turned out to be a vac leak, my STFT and LTFT remained beneath the 8-10% threshold. Thus, a CAI/SRAI shouldn't affect your trims if installed properly. Granted, I never read these when I had the stock airbox.
    What do your STFT and LTFT readings look like at idle?
    EDIT: Also, I believe the CEL gets thrown only when you consistently exceed 18% LTFT several times in a row
    2002 Mazda Protege5
    ■ Sunburst Yellow ■ Black Rear Valence ■ Injen Cold Air Intake ■ Racing Beat Catback Exhaust ■ Moog Front Endlinks
    ■ Megan Racing Rear Strut Tower Bar ■ Racing Beat Rear Sway Bar ■ Mazda6 Front Big Brakes ■ Foglight Deletes
    ■ OBX 4-1 Headers ■ MP3 ECU ■ VTCS-less Intake Manifold ■ Mishimoto Aluminum Racing Radiator + Fan Shroud
    ■ AWR Trailing Arms
    ______________________________
  4. #4
    Mazda Protegé5
    Join Date
    Dec 2011
    Location
    Canton, MI
    Posts
    699
    I've got stock airbox. I can update later this evening as I have an Aeroforce gauge. Pretty sure STFT at temp hovers +/-6-7%. LTFT sits at +/-6-7% too. You hit the nail on the head though as far as what trims should hover around.
    -6.2 LTFT highest in either direction.
    +/-7 STFT highest in either direction.
    Stock motor/intake. Removed VTCS at the head and LIGHTLY portmatched.
  5. #5
    Registered Member NaturalFlavored's Avatar
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    537
    I can tell you that having a 4-1 header a CAI and lightly (can't stress enough lightly) ported intake, I took out the vtcs and plugged the hole I see I slight increase in power in High third and fourth gear. And a steady increase in fifth. I hit top end a little quicker 125mph.
    Depending on how I drive it, "like" racing from first to fifth I have no problem hitting 120+ but driving at 75 then downshifting and speed up I have a harder time hitting 120.
  6. #6
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    537
    I highly recommend getting A 4-2-1 header, I want one and they are extremely important for a NA build if you don't turbo (even light turbo). I'm still working on getting one.
  7. #7
    Registered Member
    '02 Mazda Protege5
    Join Date
    Apr 2017
    Location
    Mount Kisco NY
    Posts
    77
    the readings were pretty consistent throughout the RPM range. I checked it the next day and it was slightly lower. so I guess the ECU is indeed re-learning the fuel trims.
  8. #8
    Registered Member
    '02 Mazda Protege5
    Join Date
    Apr 2017
    Location
    Mount Kisco NY
    Posts
    77
    Quote Originally Posted by NaturalFlavored View Post
    Is that easy to install? I've seen some header setups with no pre-cat installed (unless it was relocated) and I doubt I would pass NY emissions in that case
  9. #9
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    537
    It's an easy swap, I'd recommend getting a non fouler online since it will look cleaner. The hardest part is making sure you get a header that has a egr valve connection that hooks up and then connecting them. Other than that it's an easy upgrade.
Similar Threads
  1. Damn this car! Fuel Trims high.
    By Spoolme in forum Mazdaspeed3
    Last Post: 07-04-2010, 10:25 PM
  2. Lean at idle and crazy fuel trims!
    By BudUMfan in forum Mazdaspeed3
    Last Post: 12-13-2009, 02:21 PM
  3. fuel trims all over the place?
    By R3B in forum Mazdaspeed3
    Last Post: 07-02-2009, 08:49 PM
  4. Stock Long Trim Fuel Trims
    By pwrful4 in forum Mazdaspeed3
    Last Post: 03-23-2009, 10:27 PM
  5. HKS fuel trims???
    By miller_time in forum Mazdaspeed3
    Last Post: 11-14-2008, 11:38 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
