Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 42
Thread: Tires
  1. #16
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,512
    Arrow Tires
    Quote Originally Posted by Sig cx-5 View Post
    Radial T/A's?
    That's the last BFG tires I had. They looked good on my '79 Bandit TransAm. I guess I didn't know they were still making tires, as no one ever mentions them in threads like this.
    BFGoodrich Advantage T/A Sport LT 225/55R19 is Crossover/SUV Touring All-Season tire which is fairly new but has been listed in my 2nd comparison table.
    Although BFGoodrich Advantage T/A Sport LT is now rated #1 out of 30 in Tire Ratings Charts on Crossover/SUV Touring All-Season tires from TireRack.com which overtook the previous Michelin Premier LTX®, but it has only 156K reported miles from customers, comparing to Premier LTX's 7M miles. We shall wait and see.
    Based on specs on BFGoodrich Advantage T/A Sport LT, I personally don't like the "700 B A" UTQG, lower 44 psi maximum inflation pressure, and heavier 30 lbs. tire weight.
  2. #17
    Registered Member
    CX5 GT-R
    Join Date
    May 2015
    Location
    South-Central US
    Posts
    7,312
    Quote Originally Posted by yrwei52 View Post
    It also performs absolutely dismally in the rain, and I'd never buy them.
    https://www.tirerack.com/tires/tests...y.jsp?ttid=229
    Just look at that wet pavement stopping distance!
  3. #18
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,512
    Arrow Tires
    Quote Originally Posted by Unobtanium View Post
    Didn't check the test results performed by TireRack but only mentioned good initial customer reviews with caution.
    I agree with you the test results are not good in almost EVERY category on BFGoodrich Advantage T/A Sport LT, not just in wet test track!
  4. #19
    Registered Member
    CX5 GT-R
    Join Date
    May 2015
    Location
    South-Central US
    Posts
    7,312
    The wet track test was troublesome to me, though, as it was exceptionally pathetic, and wet roads are something I have where I live, as I am sure they do in Plano.
  5. #20
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,512
    Arrow Tires
    Yep, we just got 2.49" of rain yesterday and 1.05" today. Definitely won't consider BFGoodrich Advantage T/A Sport LT. General AltiMAX™ RT43 is performed much better in every category and cheaper!
  6. #21
    Registered Member
    Mazda CX-5
    Join Date
    Dec 2015
    Location
    Chattavegas
    Posts
    366
    Checking tread depth is easy. Look for the wear bars to be flush with the tread.
    '06 MX-5 6MT, Custom Sprung Ohlins, Tomei LSD
    '16.5 CX-5 T AWD w/more Soul
    IBA/COG Desmoquattro for pleasure
  7. #22
    Registered Member
    Mazda CX-5
    Join Date
    Dec 2015
    Location
    Chattavegas
    Posts
    366
    X
  8. #23
    Registered Member concept's Avatar
    2014 Mazda3 S GT auto, 2008 MX5 6-speed
    Join Date
    Mar 2009
    Location
    San Diego
    Posts
    1,536
    If you search for tires on tirerack.com by entering your make, model, and trim, you will see that the Pirellis are recommended. I have found that Pirelli as tire brand make some excellent tires. I am running with their P-Zeros on my 3 and they are the best tires I've ever had.
    2014 3S GT, Deep Crystal Blue, Eibach Pro-Kit, Enkei PF01s, Koni Sports, Pirelli P ZERO ALL SEASON PLUS tires, 225/45/18
    2008 MX-5 Touring (Mazdaspeed CAI, HIDs, Progress/Koni Sports/Racing Beat sways, SST Magnaflow muffler and tips)
  9. #24
    Grand Poobah tex2670's Avatar
    2012 CX-9 GT AWD, Copper Red/Sand
    Join Date
    Mar 2012
    Location
    Philly
    Posts
    1,141
    Quote Originally Posted by DG_1234 View Post
    No matter which the tire model-brand I replace at about 30K miles (even if the tires still have lots of remaining wear life).
    What's your rationale behind this?
  10. #25
    Registered Member kdaug's Avatar
    2018 Mazda CX-5 GT AWD non-Tech
    Join Date
    Mar 2014
    Location
    Fredericton, NB, Canada
    Posts
    239
    Quote Originally Posted by Jman136 View Post
    Hello,
    At what mileage did you replace your OEM tires on your CX-5? I*m currently at 15k miles, and am thinking about putting some Pirelli*s on. My tires still seem like they*re in OK condition, and was just wondering what type of mileage I could get out of these?
    If you did replace them, what did you go with? What would you recommend?
    Thanks all!
    Check the sticker on any Pirelli tire. It clearly says, at the bottom of the sticker:
    TO MAINTAIN VEHICLE DYNAMICS AND LOAD CARRYING CAPACITY, REPLACEMENT
    TIRES MUST ALWAYS HAVE A LOAD INDEX AND SPEED RATING THAT EQUALS OR
    EXCEEDS THAT OF THE ORIGINAL EQUIPMENT TIRES OF THE VEHICLE
    I asked my COSTCO tire rep about this as I too was considering Pirelli's when my Toyo's wore out on my first CX-5. He suggested that this might be an issue at some tire dealers should a Pirelli fail on your vehicle, BUT, COSTCO offers their own in house warranty(not backed by Pirelli in this case) and they would totally warranty using an H rated tire on a V rated CX-5. If you are sold on the Pirelli you should check with your tire dealer on how/if they would warranty H rated Pirelli's on your CX-5.
    In the end I went with the V rated Michelin Premier LTX in the OEM 225/55/19 size and absolutely loved them.
  11. #26
    Join Date
    Mar 2009
    Location
    San Diego
    Posts
    1,536
    Was the load rating similar between the Pirellis and the OEMs? Those are most likely the most critical numbers.
    A V-rated tire is capable of 149 MPH. Is the CX5 2.5 non-turbo capable of exceeding 130 MPH (H-rating)?
    I believe 130 MPH is a sustained speed rating that has a safety factor, allowing brief bursts of speed beyond 130.
  12. #27
    Resident barbarian ColoradoDriver's Avatar
    Donated: $5
    2014 CX-5 Touring AWD
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    4,707
    Quote Originally Posted by tex2670 View Post
    Money burning a hole in his pocket?
    2014 CX-5 Touring AWD 2.5L | Jet Black Mica - 81k miles
    01/2013 build | 4/20/2013 delivery
  13. #28
    Donated: $5
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    4,707
    Quote Originally Posted by concept View Post
    I believe the top speed of a CX-5 is 120 MPH.
  14. #29
    Registered Member Kaps's Avatar
    Donated: $15
    CX-5 Touring 2016.5
    Join Date
    Aug 2016
    Location
    Lewisville North Dallas Suburb
    Posts
    2,086
    As much as I hate the Altimax for mushy feeling their wet performance is good.
    Official Defender of Zamdatm
  15. #30
    Donated: $5
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    4,707
    Quote Originally Posted by Kaps View Post
    You need to add a couple of PSI of air.
Similar Threads
  1. Replies: 1
    Last Post: 09-16-2015, 05:57 AM
  2. Replies: 0
    Last Post: 07-08-2013, 08:13 PM
  3. Replies: 15
    Last Post: 01-25-2013, 02:25 PM
  4. Replies: 5
    Last Post: 11-18-2010, 08:46 AM
  5. Stock Speed 3 Bridgestone tires for sale. 3 tires. 3000 miles on them.
    By Andrade08 in forum Completed Transactions
    Last Post: 05-30-2008, 10:19 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
