Made in USA and Free Shipping on all orders shipped inside the US.
Results 1 to 7 of 7
Thread: Tire Pressure Monitoring on a 2016
  1. #1
    Registered Member
    2016 Mazda 6
    Join Date
    Apr 2019
    Location
    Central Ohio
    Posts
    16
    Can someone please confirm the 2016 Mazda6 uses the ABS wheel speed sensors to indirectly monitor tire pressure?
    I'm planning to have the wheels powder coated and may remove the tires myself. I don't want to damage the TPMS modules if they exist. From the owner's manual and looks of the valve stems, it sure seems there are no pressure modules.
    Thx
  2. #2
    Registered Member
    Join Date
    Mar 2010
    Posts
    14
    All cars sold in the US are mandated by the government since 2007 to have TPMS.
  3. #3
    Registered Member
    2016 Mazda 6
    Join Date
    Apr 2019
    Location
    Central Ohio
    Posts
    16
    Quote Originally Posted by dagrimey1 View Post
    Yep. But that doesn't answer the question on whether there is a pressure sensor or it utilizes the ABS sensors. The ABS sensor method works by measuring the tire rotations per minute. If air pressure changes, the number or RPM of the wheel will change and provide an alert.
  4. #4
    Registered Member
    Join Date
    Mar 2010
    Posts
    14
    Just remove them, not familiar with Gen 3 6s but every TPMS sensor I've dealt with was in the wheel and you just loosen up the nut holding them on and slide them out. If you don't want to have a tire place do it for you as you got to have the tires removed any ways.
  5. #5
    Registered Member
    2016 Mazda 6
    Join Date
    Apr 2019
    Location
    Central Ohio
    Posts
    16
    You seem to be missing the question - it is "is there a pressure sensor, or not". I'm guessing not, and it's not a huge deal for me either way, but thought I'd throw it out there.
  6. #6
    out the fast lane b*#@! silla3's Avatar
    09 mazda 3s
    Join Date
    Nov 2005
    Location
    Katy, Tx.
    Posts
    342
    Sorry, late to the party but you probably already know answer, no sensor in wheel...
    Abs module/speed sensor reads tpms
  7. #7
    Registered Member ceric's Avatar
    2017 Mazda CX-5 GT, 2016 Mazda6 iGT, 2014 Mazda3 sGT hatchback
    Join Date
    Jan 2008
    Location
    Northern California
    Posts
    4,371
    Mazda went back to in-wheel monitoring from 2017+.
    For 2016 and earlier models, ABS sensors are used.
    The latter gives more false alarms, but mine has been OK since new.
    I got a '16 Mazda6 and '17 CX5. The difference begins at '17.
    Check your OM.
    2016 Mazda6 iGT + Tech Pkg
    ....Sonic Silver Mica / Parchment
    ....Soul Red Metallic / Almond
Similar Threads
  1. 2016 Mazda CX-9 Tire Pressure Monitoring System
    By Stryker medic in forum CX-9 Wheels, Tires, Brakes & Suspension
    Last Post: 01-08-2018, 01:32 PM
  2. Question on Tire Pressure Monitoring System
    By satwar in forum CX-9 Wheels, Tires, Brakes & Suspension
    Last Post: 04-24-2013, 12:32 AM
  3. Replies: 0
    Last Post: 10-03-2007, 11:18 PM
  4. Tire Pressure Monitoring System (TPMS) FAQ
    By dajiggalo in forum Mazda3 Wheels, Tires, Brakes & Suspension
    Last Post: 08-26-2004, 02:39 PM
  5. how does the tire pressure monitoring work?
    By eting_pro5 in forum Mazda3 Lounge
    Last Post: 02-08-2004, 08:49 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
