Compare auto reliability with reliable results at TrueDelta.com!
Results 1 to 3 of 3
Thread: where does the blue wire in the aftermarket antenna adapter hook up to
  1. #1
    Registered Member
    Join Date
    Apr 2019
    Posts
    2
    so i just installed a aftermarket carplay sterio,
    2 things currently dont work
    the steering controls which i dont care about thanks to the HEY SIRI capability
    and the AM/FM channels
    i think the reason for the AM/FM issue is that i wired the blue wire on the after market antenna hookup incorrectly
    this is the one i bought https://www.amazon.com/gp/product/B071CK6W66
    does anyone know where the blue wire is supposed to be hooked up to (i wired it manually wire to wire using a wiring diagram)
  2. #2
    Registered Member
    2012 Mazda 5
    Join Date
    Apr 2013
    Location
    Vancouver
    Posts
    724
    From someone one Mazda 6:
    The mysterious blue wire should go to a 12-volt source that is only active in the accessory or run key positions.
    It supplies power to the RF amp module for the antenna wires, I just wired it to the red ignition wire behind the radio.
    Not sure same one the 5.
  3. #3
    Registered Member
    Join Date
    Apr 2019
    Posts
    2
    Quote Originally Posted by Vasy View Post
    thanks , that makes sense
Similar Threads
  1. Radio Antenna Adapter
    By needmovies in forum CX-5 Infotainment
    Last Post: 11-08-2015, 03:34 PM
  2. Do I need an antenna adapter for an aftermarket radio?
    By chapel in forum Mazda5 Infotainment
    Last Post: 10-29-2012, 12:34 AM
  3. Ipod Adapter finding the power wire
    By rapter in forum Mazda Protege
    Last Post: 01-11-2009, 01:07 AM
  4. Need adapter wire for RCA plugs
    By Pmpkinhead in forum Mazdaspeed Protege
    Last Post: 01-13-2006, 03:29 AM
  5. Can someone tell me how to hook up a remote wire?
    By hawaiiannights in forum Mazda How-To
    Last Post: 10-26-2003, 04:42 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
