VersaTuner - tuning software for Mazdas
Results 1 to 8 of 8
Thread: Vibration from front??
  1. #1
    Registered Member
    02 Protege LX, 03 P5 (x2), 09 Miata, 07 Mazda3, 13 Fit, 09 Ody
    Join Date
    Aug 2013
    Location
    MD
    Posts
    106
    So, I have some fairly extreme vibration from the front.
    - Shocks are fairly new and everything seems tight.
    - Does not seem to be any sticking brake calipers
    I put the car up on jack stands and ran it up to 35mph.
    The left wheel rotates slower than the right wheel.
    1) Is this normal?
    2) Could this be caused by CV? There is a small amount of grease seeping from inner boot, but no tears.
    3) Sticking caliper could be issue here, but the brakes don't get hot. Any other possible causes?
    13 Fit | 09 Ody | 09 Miata | 07 Mazda 3 | 03 Protege5 | 02 Protege
  2. #2
    Registered Member Big Ds mp5's Avatar
    2002 Mazda protege5
    Join Date
    Jun 2013
    Location
    San Antonio TX
    Posts
    74
    Yes the faster wheel is normal. Ever do a burn out in it and most likely you'll get the one wheel peel maybe you lost a wheel weight and it unbalanced now or could also be engine mounts
  3. #3
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    Quote Originally Posted by smetzger View Post
    1) Is this normal?
    Yes. You can slowly stop one wheel and the other wheel will spin up. (unless you have an LSD differential)
    Yes. A bad CV joint will rumble or vibrate the car.
    A bad outer CV joint tends to "click" at slow speeds with the steering wheel cranked.
    3) Any other possible causes?
    Front bearings.
    Take your car out on a back road and get it up to speed. Slowly weave from left to right and see if that affects the sound (it comes and goes a bit)
    If the sound changes, it's almost certainly front bearings.
    The Diagram Dude
  4. #4
    Registered Member Corphish's Avatar
    83 RX-7 Gsl, 2000 Mazda Protege LX, 2011 Mazda3 Sport i
    Join Date
    Aug 2016
    Location
    Baldwin, WI
    Posts
    355
    Id check by doing a tire rotation and moving the suspected wheel to the rear and try again.
  5. #5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    When my front bearings went bad, the car was kinda humming /rumbling/vibrating.
    The sound filled the whole cabin and I could barely tell that it was coming from the front.
    I too jacked up my car and ran it at idle in 4th or fifth gear then stopped one wheel at a time to check for vibration.
    That worked and I found the bad bearing.
    I forget what side it was and just did both bearings.
    Doing front bearings is a huge PITA for our car. Everything tends to be seized.
  6. #6
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    364
    I did both of my front wheel bearings in a few hours. There's some nice things about living in the south
    I'd check the tires first. Out of balance tires will vibrate, and can be quite bad depending on how out of balance they are. I recently threw a weight in one of my rear tires and couldn't drive over about 45mph it was so bad... They balanced all 4 tires and rides smooth as glass now.
    CV axles CAN cause a vibration, though not as common. And any kind of a driveline vibration you will USUALLY (though not necessarily 100%) but 98% of the time you'll have the vibration while you're accelerating, but if you let off the pedal and coast it will go away. The other 2% is generally when it's worn past the point and it will do it all the time.
  7. #7
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    Quote Originally Posted by pb4ugotobed View Post
    That and you are/were a mechanic with the tools skills and experience to get it done.
    I spent a week doing mine.
    I come from the backwoods where you use a big rock if you don't have a sledgehammer.
  8. #8
    Join Date
    Aug 2016
    Location
    Baldwin, WI
    Posts
    355
    Quote Originally Posted by pcb View Post
    I too have a shop and this took about 2 hours for both. I even had some rust issues.
Similar Threads
  1. Front end vibration
    By MikeyP1990 in forum Mazda Protege
    Last Post: 12-05-2013, 10:44 AM
  2. Front Hood Vibration
    By kelvincheu in forum CX-5 Lounge
    Last Post: 11-15-2013, 02:19 PM
  3. MP3 front end vibration and pulling to the right
    By bmacster in forum Mazda Protege
    Last Post: 12-21-2012, 11:13 PM
  4. Front end vibration?
    By ganzhimself in forum Protege5
    Last Post: 09-17-2009, 11:10 PM
  5. weird vibration on front right
    By southernstyle in forum Mazda3 Lounge
    Last Post: 07-03-2009, 01:56 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
