Made in USA and Free Shipping on all orders shipped inside the US.
Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
Thread: Sanity Check for P0171
  1. #16
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,836
    Quote Originally Posted by 323 View Post
    i got an empty slot for one last gauge. maybe it should be a fuel pressure gauge.
    I'm thinking if you've got a new fuel filter and a high performance fuel pump you shouldn't need to worry about fuel pressure.
    If I could have one gauge I'd probably pick an engine coolant temp gauge.
    Our stock dummy gauge never goes beyond the halfway mark so I'm not in the habit of looking at it.
    If I overheat I might not check it till I see steam from under the hood.
    (did that on my GLC... warped my head)
    Sad part is I have an OBDII scanner that could set off an alarm if I go beyond a set temperature but I haven't bothered to glue my cellphone to my dash.
    The next gauge I might get is an oil pressure gauge.
    The stock sensor doesn't trip the oil light until the pressure is between 2-4 PSI.
    That might be enough pressure if you're idling but not of your racing, especially if you're sucking bubbles from your sump at high speed and high RPMS.
    The Diagram Dude
  2. #17
    Registered Member
    lolmsp
    Join Date
    Mar 2007
    Location
    757
    Posts
    5,135
    Quote Originally Posted by pcb View Post
    fuel system is still the original. my mechanic friend said leave it alone if it isn't showing problems. gauges i got so far are boost/vac, wideband, oil temp, oil pressure, and a slot for one more.
    03 MSP, 03 P5
  3. #18
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,836
    fuel system is still the original. my mechanic friend said leave it alone if it isn't showing problems..
    I guess that makes sense. But if you wait for problems, you're probably going to have to replace your fuel pump too.
    I'm on my original fuel pump swapped into my new high pressure fuel filter.
    Fuel pumps can be expensive.
  4. #19
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,836
    This is what my filter media looked like after 15 years. (I cut open my old filter).
    I think it used to be white ?
  5. #20
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,836
    The people in Chile take the best care of their cars.
    Every two years.
  6. #21
    Comp Engineering Student Riot_Polizei's Avatar
    2002 Mazda Protege5
    Join Date
    Jan 2018
    Location
    Colorado
    Posts
    413
    Yo PCB, don't digress yet!
    After driving around today, believe it or not, P0171 came back on (after I drove it hard for a somewhat extended period of time--was in a cruise). Only thing is, my STFT stayed where it should the whole time and never jumped above 10% or so. It appeared that my LTFT was bouncing from 2.3 to 25%, so clearly some issue is still afoot. When I was done driving hard and gently drove the thing home, no codes came on, and I had nominal levels.
    Looks like my fueling system is indeed part of the problem!
    2002 Mazda Protege5
    ■ Sunburst Yellow ■ Black Rear Valence ■ Injen Cold Air Intake ■ Racing Beat Catback Exhaust ■ Moog Front Endlinks
    ■ Megan Racing Rear Strut Tower Bar ■ Racing Beat Rear Sway Bar ■ Mazda6 Front Big Brakes ■ Foglight Deletes
    ■ OBX 4-1 Headers ■ MP3 ECU ■ VTCS-less Intake Manifold ■ Mishimoto Aluminum Racing Radiator + Fan Shroud
    ______________________________
  7. #22
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,836
    Quote Originally Posted by Riot_Polizei View Post
    I got some readings regarding my fuel trim, and it's not looking good. I only collected data while driving around, and not stationary.
    STFT was bouncing all around, but only rose above 8% at very low engine speeds (around 1.5krpms and lower, I believe). LTFT stayed at 25% (overwhelmingly lean trend). STFT had "normal" readings above 1.5-2kRPM readings, which ultimately points at a vacuum leak of some kind, and not necessarily a fueling issue.
    At least, it's been narrowed down, but damn I msy habe to rip open my IM again...
    (Note: will analyze this at stamdstill later)
    I was wondering what kind of readings would be expected if it was a fueling issue ??
  8. #23
    2002 Mazda Protege5
    Join Date
    Jan 2018
    Location
    Colorado
    Posts
    413
    A fueling issue from P0171 is a little less cut-and-dry. If your STFT is overall lean, and your STFT doesn't drop with the throttle being held at 1.5kRPM and 2kRPM (while LTFT remains high), then it could be one of several fueling components. You're then looking at your FPR, injectors, and fuel sending unit.
    Even then, it could even be a misfire that didn't trip the misfire code yet, or spark plugs on their way out.
    Vacuum leaks are somewhat simpler to diagnose given the noise they make and their impact on STFT and LTFT.
  9. #24
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,836
    OK thanks.
    Now all I have to do is remember that.
    Maybe I'll cut and paste it to my thread. lol
  10. #25
    Registered Member
    lolmsp
    Join Date
    Mar 2007
    Location
    757
    Posts
    5,135
    sweet. Riot you can come diagnose mine now lol. jk
  11. #26
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,836
    Let Me Fix It Boss !
    https://youtu.be/WAiHyioDzTg
    Lol
  12. #27
    2002 Mazda Protege5
    Join Date
    Jan 2018
    Location
    Colorado
    Posts
    413
    Would if I could to help :^)
    What's up with it?
Similar Threads
  1. Sanity check on cx9
    By dhayes16 in forum CX-9 Lounge
    Last Post: 09-25-2017, 12:44 AM
  2. Check engine - P0171
    By PSUENGR in forum Mazdaspeed Protege
    Last Post: 05-21-2013, 11:21 PM
  3. ARP main stud kit catalog number? (sanity check)
    By dmention7 in forum Mazdaspeed Protege
    Last Post: 03-23-2011, 10:53 AM
  4. Pre-mod sanity check. Got questions!
    By TheRealDefman in forum Mazdaspeed3
    Last Post: 01-12-2009, 05:45 PM
  5. Looking for a sanity check...Selling my MS6 for a ??
    By jdub260 in forum Mazda6 Lounge
    Last Post: 09-07-2007, 09:19 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
