CorkSport.com is MAZDA PERFORMANCE!
Page 1 of 2 12 LastLast
Results 1 to 15 of 27
Thread: Sanity Check for P0171
  1. #1
    Comp Engineering Student Riot_Polizei's Avatar
    2002 Mazda Protege5
    Join Date
    Jan 2018
    Location
    Colorado
    Posts
    479
    Hello guys, as stated, this is a bit of a sanity check.
    Should I expect P0171 (system too lean) to come on more often if I have a cold air intake installed on the car?
    If so, I probably shouldn't be too concerned, but am still investigating other causes.
    2002 Mazda Protege5
    ■ Sunburst Yellow ■ Black Rear Valence ■ Injen Cold Air Intake ■ Racing Beat Catback Exhaust ■ Moog Front Endlinks
    ■ Megan Racing Rear Strut Tower Bar ■ Racing Beat Rear Sway Bar ■ Mazda6 Front Big Brakes ■ Foglight Deletes
    ■ OBX 4-1 Headers ■ MP3 ECU ■ VTCS-less Intake Manifold ■ Mishimoto Aluminum Racing Radiator + Fan Shroud
    ■ AWR Trailing Arms
    ______________________________
  2. #2
    ......................... i12drivemyMP5's Avatar
    Donated: $5
    323F
    Join Date
    Apr 2005
    Location
    Posts
    7,573
    I have an intake from vendor on here, 505zoom.......filter box sits over the hole into the fender well so it breathes from same place. I occasionally get this lean code, mostly in winter when air is colder/denser. There are no air leaks anywhere. My MAF is clean, washable dry-flo filter - no oiling. If I wait until it is warm/humid (like it is here most of time) then the code won't happen and passing inspection is no problem. Won't pop a code all summer/fall.
    This is my intake setup..................
  3. #3
    2002 Mazda Protege5
    Join Date
    Jan 2018
    Location
    Colorado
    Posts
    479
    Nice n'clean...
    Do you have a way to measure fuel trims, perchance? I want to compare, if possible
  4. #4
    Registered Member
    lolmsp
    Join Date
    Mar 2007
    Location
    757
    Posts
    5,228
    i'll add my experience here. Bought MSP in 2009. That CEL comes and goes even before and after my engine swap. During engine swap, car got all new seals and vacuum hoses and what not. CEL lasts for about a day or two. Maybe my car is just psycho like i12drivemyMP5's P5.
    03 MSP, 03 P5
  5. #5
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    I'm thinking weak fuel pump and dirty fuel filter.
    The Diagram Dude
  6. #6
    Registered Member
    lolmsp
    Join Date
    Mar 2007
    Location
    757
    Posts
    5,228
    no! you get that out of here right now.
  7. #7
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    368
    I don't know what the air flow rate is with the cold air intake vs. the OEM intake, but I would have to imagine it's a pretty significant difference. especially if you have exhaust, headers, etc. to push even more air flow through the motor.
    The stock fuel injectors are tuned and set up for the stock intake. If you're doubling the amount of airflow, it may be just borderline between where it kicks a code or does not kick a code. The stock ECU/Injectors is engineered and designed to work. There is a certain amount of headroom for safety, but once you start doing a certain amount of upgrades, it can bypass what the factory curves are able to support. Cold air is more dense, so would be more air to the fuel mix (leaner). This doesn't mean you're still not running lean when it's warmer. The ECU has a threshold of when it kicks a code. IT may just be that when it's warm, it's inside this threshold (barely) but the colder denser air is enough to put it over the threshold and kick the light. The only way to compensate would be to go with a little larger injector and/or fuel management system.
    But first, I would make sure your injectors are clean, fuel pressure is per spec, etc. Go through and do a full tune up, make sure the MAF/MAS is clean, etc. I definitely would not recommend running it hard or much with it being lean or bad things can happen.
  8. #8
    2002 Mazda Protege5
    Join Date
    Jan 2018
    Location
    Colorado
    Posts
    479
    I got some readings regarding my fuel trim, and it's not looking good. I only collected data while driving around, and not stationary.
    STFT was bouncing all around, but only rose above 8% at very low engine speeds (around 1.5krpms and lower, I believe). LTFT stayed at 25% (overwhelmingly lean trend). STFT had "normal" readings above 1.5-2kRPM readings, which ultimately points at a vacuum leak of some kind, and not necessarily a fueling issue.
    At least, it's been narrowed down, but damn I msy habe to rip open my IM again...
    (Note: will analyze this at stamdstill later)
  9. #9
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    Quote Originally Posted by Riot_Polizei View Post
    I could see a lack of fuel pressure causing those symptoms.
    At lower rpms, the engine is using less gas so the fuel pump can keep up but on average over time, your LTFT will be reduced.
    A fuel pressure test could be done but it's a bit of a chore.
  10. #10
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    Your pump may be able to put out ~30-36 PSI but perhaps not able to put out the 64-92 PSI when the ECU calls for it.
  11. #11
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    You could also check to see if your fuel pump is running almost nonstop, suggesting that it's having a hard time building pressure.
  12. #12
    2002 Mazda Protege5
    Join Date
    Jan 2018
    Location
    Colorado
    Posts
    479
    I just popped the hood and heard it myself--a small, unmistakeable hiss from around my IM.
    My VICS actuator was easily pushed open and seemed to hold no vacuum so now I know where to start digging
  13. #13
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    OK.
    I digress.
  14. #14
    Registered Member
    lolmsp
    Join Date
    Mar 2007
    Location
    757
    Posts
    5,228
    i got an empty slot for one last gauge. maybe it should be a fuel pressure gauge.
  15. #15
    2002 Mazda Protege5
    Join Date
    Jan 2018
    Location
    Colorado
    Posts
    479
    Found and fixed the culprit!
    When installing my IM, I did not properly torque down one/two particular bolts near the middle of the head. This, in turn, caused the IM gasket to collapse at the top and allow lots of air to flow in. Damn.
    A new gasket was dropped in, everything was torqued to spec according to the manual. No vacuum lines were damaged.
    Man, I gotta do things right the first time, or else I'll have a non-stop Mazda-induced aneurysm.
Similar Threads
  1. Sanity check on cx9
    By dhayes16 in forum CX-9 Lounge
    Last Post: 09-25-2017, 12:44 AM
  2. Check engine - P0171
    By PSUENGR in forum Mazdaspeed Protege
    Last Post: 05-21-2013, 11:21 PM
  3. ARP main stud kit catalog number? (sanity check)
    By dmention7 in forum Mazdaspeed Protege
    Last Post: 03-23-2011, 10:53 AM
  4. Pre-mod sanity check. Got questions!
    By TheRealDefman in forum Mazdaspeed3
    Last Post: 01-12-2009, 05:45 PM
  5. Looking for a sanity check...Selling my MS6 for a ??
    By jdub260 in forum Mazda6 Lounge
    Last Post: 09-07-2007, 09:19 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
