Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Replace your coolant Mazda CX 5 CX3 Mazda 3 Mazda 6
  1. #1
    Registered Member
    Join Date
    May 2013
    Location
    Indonesia
    Posts
    152
    Talking Replace your coolant Mazda CX 5 CX3 Mazda 3 Mazda 6
    Good day peeps , just would like to share with you all. Thank you . Enjoy.
  2. #2
    Banned Chris_Top_Her's Avatar
    Donated: $45
    CX Moderator
    '15 CX-5 Miata GT AWD w/Tech 2.5L
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,169
    Thanks
  3. #3
    Resident barbarian ColoradoDriver's Avatar
    Donated: $5
    2014 CX-5 Touring AWD
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    5,020
    Quote Originally Posted by felixd View Post
    Thanks Felix! Very helpful!
    I have a ways to go on mine, but will keep this video in mind.
    2014 CX-5 Touring AWD 2.5L | Jet Black Mica - 83k miles
    01/2013 build | 4/20/2013 delivery
  4. #4
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,779
    Arrow Replace your coolant Mazda CX 5 CX3 Mazda 3 Mazda 6
    I'd try to clean up the inside of coolant reservoir with a long brush.
    And is there a coolant drain on engine block?
  5. #5
    Registered Member
    2013 Mazda CX-5 Sport FWD Auto
    Join Date
    Oct 2012
    Location
    FL
    Posts
    312
    Would you guys recommend flushing with distilled water between draining the old coolant and adding the new coolant? And if I remember right, the CX5 still holds old fluid in the block like yrwei is alluding to, correct?
  6. #6
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,779
    Quote Originally Posted by ruthrj View Post
    My 2000 BMW 528i and 1998 Honda CR-V both offer a coolant drain plug on cylinder block. There's no issue to do more complete drain on old coolant. Heater core is another place to hold some old coolant which can't be drained unless you disconnect heater core hoses.
    With engine coolant used to cool down ATF for our SkyActiv-Drive transmission, there'll be more old coolant stuck in the transmission cooler.
    Yes, I did fill distilled water at least once just try to dilute those old coolant inside of heater core.
  7. #7
    Registered Member
    CX-5 AWD GT
    Join Date
    Apr 2017
    Location
    Australia
    Posts
    99
    Donít forget to use FL22 coolant if the lid says so. Is not a general green coolant
  8. #8
    Registered Member
    2016 Mazda, CX-5 GT
    Join Date
    Dec 2013
    Location
    Magnolia TX
    Posts
    84
    Great video. Will be very helpful.
  9. #9
    Registered Member
    Join Date
    May 2013
    Location
    Indonesia
    Posts
    152
    Yes if you can get the FL22 , please purchase it .
  10. #10
    Registered Member
    Join Date
    Mar 2009
    Posts
    35
    Regarding flusihing with distilled water-
    You can just fill it up with distilled water and drain rinse repeat several times to get the block and various trapped coolers cleaned out. In order to get the correct ratio of full strength coolant to water we would need to know the TOTAL system capacity AND what you can drain out by simply removing the drain plug. from there it is simply a math problem.
    What makes your life worth living?
    2014 Grand Touring dirt bike/street bike hauler and grocery getter
  11. #11
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,779
    Quote Originally Posted by TTBadDog View Post
    This's exactly what I did when I replace the radiator on my 2000 BMW 528i few weeks ago. But I was lazy and I only fill-and-drained distilled water once.
    BMW has a drain hole on engine block, so as my 1998 Honda CR-V. Not sure if our Mazda CX-5 2.5L has one as that would help to drain the old coolant a lot more completely from engine block.
    The problem to me is every fluid capacity specified by Mazda is approximate. And from real-world experience true fluid capacities can vary a lot from specified capacities. Should I trust 8.1 US quarts of total capacity on engine coolant for US 2.5L?
  12. #12
    Registered Member
    Join Date
    Mar 2009
    Posts
    35
    Understood, doing the math would require we know the total capacity, I can measure what comes out. I suspect it would be close enoiugh. If I wound up at 0.40 or 0.60 concentration level you could just drain X out and add straight AF or Water to get there.
  13. #13
    Registered Member
    2018 AWD GT Premium Red/Black
    Join Date
    Feb 2017
    Location
    WA
    Posts
    671
    Quote Originally Posted by yrwei52 View Post
    Does Mazda sell full strength coolant?
  14. #14
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,779
    Quote Originally Posted by murky View Post
    Yes.
  15. #15
    Registered Member
    92 MX-3; 18 CX-5
    Join Date
    Jan 2019
    Location
    MN
    Posts
    48
    This information may be elsewhere in this forum. But, since I recently replaced a CX-9 water pump I was forced to become more knowledgeable about the FL22 coolant and options.
    For future readers here are the options that are currently available for FL22 coolant:
    OEM diluted Mazda part#: 0000-77-508E-20
    Mazda has a concentrate formula OEM: 0000-77-501E-02 but this can be tougher to find and appears on some sites to be discontinued.
    Ford (Motorcraft)diluted version: VC-10-A
    Ford (Motorcraft) concentrate: VC-10-A2 (specialty green)
    There are aftermarket options from Ravenol and Pentosin (and Zerex if you don*t care about the resulting color of the mix):
    Ravenol is available in both diluted and concentrate:
    Diluted: Ravenol J4D2091-1-10 HJC FL22
    Concentrate: Ravenol J4D2091-10 HJC FL22
    Pentosin Pentofrost A2 is a dark green concentrate that must be mixed with water. The nice thing about Pentofrost A2 is that it is available at some auto part stores and Rockauto for a much better price compared to most of the options above.
    The Zerex Asian formulas are also compatible and likely the same chemistry * but the color can be a challenge (blue or pink) unless you do a complete change. And, as far as I am aware, the Zerex Asian vehicle formulas are only available as diluted.
Similar Threads
  1. Replies: 0
    Last Post: 07-03-2014, 12:20 AM
  2. Replies: 2
    Last Post: 05-05-2013, 06:06 PM
  3. Mazda Won't Replace my VVT
    By swank_x in forum Mazda CX-7
    Last Post: 03-23-2011, 08:40 PM
  4. Engine Coolant in Mazda 3
    By Tronix102 in forum Mazdaspeed3
    Last Post: 10-01-2007, 06:09 PM
  5. For Mazda 3: How to replace the HID Bulb by myself?
    By yyz in forum Mazda3 Infotainment
    Last Post: 10-03-2006, 07:26 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
