In Memory of Member 1338
Results 1 to 6 of 6
Thread: 02 protege5 alignment issues?
  1. #1
    Registered Member
    Join Date
    Mar 2019
    Posts
    5
    I bought an 02 protege5 a couple months ago. It's a 5 speed and has 246 xxx km on it.
    It had new tires when I bought it. I've driven it approximately 1900km since I bought it and I'm experiencing excessive tire wear on the front tires. The tire wear is on the inner edge of both front tires and it's about an inch and a half thick line of wear. The rest of the tire is fine, but the inside is almost out of tread already. The steering seems fine. Wheel is straight and the car doesn't veer off on its own. I've jacked the front up and given the tires a wiggle. They get a little play in and out on the top and bottom of the front tires. But it's not much. Very minimal. Maybe a 1/4 - 3/8 inch in and out.
    Another thing I noticed is a rotating howling sound when you get the vehicle up to 80km an hour. We thought it was the rear right wheel bearing, but I put a new one in last night and that hasn't fixed the problem. It sounded like that's where it was coming from, but maybe it was both sides, and the sound was just echoing in the vehicle making it difficult to pinpoint.
    My questions. Do you think this vehicle just needs an alignment, or is there reason to believe it will need parts to get a proper alignment completed..?
    What cost am I looking at for the alignment?
    Could the howling sound be due to the front tire wear?
    Any help appreciated. Thank you.
  2. #2
    Registered Member NaturalFlavored's Avatar
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    582
    Well if you look under there and see if anything is bent or broken. But every alignment shop is different, call around and check out the prices. It costs me$70 for an alignment.
  3. #3
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    If you have worn bearings, ball joints or tie rod ends then an alignment is pointless.
    Lift your car and check all those components. A pry bar between the ball joint and control arm can help.
    If you have any movement AT ALL on the ball joints then they need to be replaced.
    (Rockauto has the entire control arm including the ball joint for cheap.)
    The howling may be the other side or even the front bearings.
    My whole car was rumbling when my front bearing went out. I couldn't tell what side it was coming from.
    Take your car out for another drive and get it up to speed when the howling starts and slowly weave from right to left and back and see if the noise comes and goes.
    If it does, there's a good chance its a bearing.
    The Diagram Dude
  4. #4
    Registered Member
    Join Date
    Mar 2019
    Posts
    5
    Thanks guys. I'm going to be checking the ball joints and tie rods tomorrow, and probably swapping the new rear bearing onto the other side to see if I can pinpoint the problem. I suspect it's the front bearings at this point. Probably need to be replaced and have an alignment after that.
  5. #5
    Registered Member
    Join Date
    Mar 2019
    Posts
    5
    Would it be correct to assume worn front bearings would be causing the tire wear?
  6. #6
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    Really worn front bearings can introduce some slop in the wheel but all three work together to create a loose wheel.
    1/4" of play in the wheel is actually a lot. Toe in for our car is 2mm +/- 4mm.
    Replace all your worn out parts before the alignment.
    Your car is towing out by quite a bit to wear your tires like that or they are just so sloppy they don't track straight.
    PS... Doing front bearings is a huge PITA for our car.
Similar Threads
  1. Alignment/Balancing Issues?
    By Need4Speed3 in forum Mazdaspeed3
    Last Post: 07-14-2011, 10:07 PM
  2. alignment issues
    By leorules27 in forum Protege5
    Last Post: 11-09-2010, 01:53 AM
  3. Alignment issues?
    By BADFISH6 in forum Mazda6 Wheels, Tires, Brakes & Suspension
    Last Post: 11-08-2008, 09:35 PM
  4. Alignment Issues!
    By Mr. 4500 RPM in forum Protege5
    Last Post: 07-27-2005, 05:04 AM
  5. Alignment issues...
    By BlueMonsta in forum Mazda Protege
    Last Post: 02-19-2004, 04:42 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
