Page 4 of 4 FirstFirst ... 234
Results 46 to 60 of 60
Thread: Drive Belt tensioner leaking at 40,700 miles per dealer
  1. #46
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,378
    Arrow Drive Belt tensioner leaking at 40,700 miles per dealer
    Quote Originally Posted by CX-5um View Post
    Its a long story. Start here: https://www.mazdas247.com/forum/show...ensioner/page4
    Replaced under warranty @17 miles.
    Long story short, replaced again later....along with new water pump and belt. Got push back from dealership. Had to get Mazda involved.
    I'm on second Tensioner on Mazda6. Original one on CX-5.
    Edit: Tensioners are known to give out around the 30k mark on Mazda6's for some reason. Source= Mazda6club forum and myself. Hence why lifetime warranty parts is something I'm looking for. Also want to provide my findings to others for help.
    So on your Mazda6, your belt tensioner failed at 17K miles (definitely not at 17 miles! ), and failed again at 30K miles. Your Mazda6 was still under new car warranty when the tensioner failed at the 2nd time. Why MNAO needed to get involved? Did you request a new water pump suspecting it might cause the repeated failures on belt tensioner?
  2. #47
    Registered Member CX-5um's Avatar
    13' CX-5 and 16' Mazda6 both Touring w/Tech/Bose
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    2,939
    Quote Originally Posted by yrwei52 View Post
    So I was in for an oil change. Dealer called and said they saw coolant (green) residue. Did not believe them so I took car home and did self inspection. Sure enough there was residue near the water pump gasket and tensioner was leaking.
    Probably a good reason to check those tensioner...but.....water pump has its own belt. Were they related? I'm not too keen on drive belt systems so not sure.
    Anyhow I'm not sure why but they said it was not covered under warranty. Maybe their angle was that the tensioner (non covered part) going bad caused the water pump to go bad. Only explanation I could think of. I did not waste time go back and forth with them. 1 call to Mazda USA and they called the dealership and approved the work. 2 belts. Tensioner. Water pump with new gasket covered under warranty. Did it need all that? Probably not. Was I wanting all that? Yessir!!!
    Going back to the Tensioner......> wasn't there someone here who was told it was not covered under warranty?
  3. #48
    Registered Member PatrickGSR94's Avatar
    2014 Mazda CX-5 Touring
    Join Date
    Aug 2016
    Location
    Memphis TN area
    Posts
    444
    Quote Originally Posted by finch204 View Post
    Ah it was CX-5um
    When mine was replaced, I think my CX-5 was just around the 40K mile mark, so not that old. Patrick, you seem to have an older CX-5 though, so its possible that Mazda will just deem it as a wear and tear item, so they might not be of help at all.
    like I was saying, I do all my own work anyway. In 20+ years of car ownership I have never paid a shop for any work other than alignments and tire mount/balance. And especially not a $tealership. Haven't even set foot on the dealer lot where we bought our 2014 since we purchased the car in 2016.
    I forgot to check the tensioner last night, but if there appears to be a problem I'll take care of it. Still gotta get that $150 worth of transmission fluid run through the system one of these days.
    1994 Acura Integra GSR - 368K miles, a few mods
    2014 Mazda CX-5 Touring - 88K miles, the family hauler!
  4. #49
    Registered Member
    Donated: $15
    2016.5 CX 5 Touring AWD, 2015 SCION XB
    Join Date
    Mar 2013
    Location
    ABE area, Pennsylvania, USA
    Posts
    1,346
    Yeah, me. Not covered under remaining power train warranty once your 3 year/36k mile bumper to bumper has expired.
  5. #50
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    2,939
    Quote Originally Posted by madar View Post
    Damn Madar...that sucks. How's your updated tensioner so far?
    Man, having a hard time finding instructions for removing and installing new tensioner with torque specs.
  6. #51
    Registered Member
    2014 mazda cx-5 touring FWD
    Join Date
    Dec 2015
    Location
    midwest
    Posts
    107
    For instructional info go back to page #1 ,post #12 in this thread .Also search function may help.Torque specs? Good luck getting a torque wrench in there.Good and tight by hand is sufficient.The nut and bolt only take a 12mm wrench. Jmaz
  7. #52
    Registered Member
    Donated: $15
    Join Date
    Mar 2013
    Location
    Posts
    1,346
    You'll have to ask the guy that bought the car, I traded it in a few years ago for a 2016 model. Hopefully this tensioner will last longer
  8. #53
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    2,939
    Quote Originally Posted by Jmaz View Post
    Thanks. So yours wasn't covered too huh?
    I actually played/test fitted a 12mm wrench in and actually broke free the top tensioner bolt. Not hard actually. I retightened and would guestimate 1/4 turn afterwards.
    My plan is to allocate a 3-hour time block and access via the wheel well since I also want to change the water pump stretch belt while in there. I already purchased OEM belts and tensioner at total $144. Extra time spent if finished early is to clean up the are I guess...and a can of beer.
  9. #54
    Registered Member tibimakai's Avatar
    Join Date
    May 2013
    Location
    Los Angeles-San Dimas, USA
    Posts
    2,653
    Good luck, with this job, it is not a fun one. I was cursing a lot, when I did it.
  10. #55
    Registered Member
    Donated: $15
    Join Date
    Mar 2013
    Location
    Posts
    1,346
    You might want to do a search on here about changing that stretch belt. I think some one said there was some kind of tool to make that change a little easier.
  11. #56
    Resident barbarian ColoradoDriver's Avatar
    Donated: $5
    2014 CX-5 Touring AWD
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    4,544
    Quote Originally Posted by tibimakai View Post
    I just ponied up the money to have a shop do it after I looked at what was all involved to do it myself.
    2014 CX-5 Touring AWD 2.5L | Jet Black Mica - 80k miles
    01/2013 build | 4/20/2013 delivery
  12. #57
    Registered Member
    Donated: $15
    Join Date
    Mar 2013
    Location
    Posts
    1,346
    Quote Originally Posted by ColoradoDriver View Post
    It's nice to save money and DIY, but sometimes it's just not worth it.
  13. #58
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    2,939
    Assuming you have wheel well access the instructions for replacing both belts don't look too hard. http://www.mcx5.org/drive_belt_remov...2_0_-1644.html
    The tensioner itself could be removed/replaced from top of engine (2.0 skyactiv engine in a cx-5 engine has more room )or via wheel well. 2 bolts hand tightened.
  14. #59
    Join Date
    May 2013
    Location
    Posts
    2,653
    Smart decision. I'm all for diy, but this type of job is no fun. I may have even scratched the pulley with a screwdriver, when I was removing the belt. I have used it, to pry off the belt. Most likely, this will bite me later on.
  15. #60
    Registered Member
    2013 Mazda CX-5 Sport FWD Auto
    Join Date
    Oct 2012
    Location
    FL
    Posts
    211
    Yikes, a screwdriver? The directions recommend using a rag or towel or something if I remember right between the pulley and the belt. Granted, itís cramped in there but has anybody done that method with success?
Similar Threads
  1. Replies: 6
    Last Post: 11-30-2018, 10:28 PM
  2. leaking belt tensioner
    By madar in forum CX-5 Engine & Transmission
    Last Post: 07-22-2018, 07:11 PM
  3. Replies: 0
    Last Post: 10-11-2012, 03:45 PM
  4. Where to get a belt tensioner?
    By ERABBIT23 in forum Mazda6 Engine & Transmission
    Last Post: 12-30-2010, 04:48 PM
  5. 17K miles = New Serpentine Belt Tensioner
    By Stamperman in forum Mazdaspeed3
    Last Post: 11-06-2008, 10:05 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
