Made in USA and Free Shipping on all orders shipped inside the US.
Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
Thread: Pinging!!
  1. #16
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    I dunno ??
    This is all I've got.
    Maybe replace your fuel filter ?
    The Diagram Dude
  2. #17
    Registered Member
    '02 Mazda Protege5
    Join Date
    Apr 2017
    Location
    Mount Kisco NY
    Posts
    77
    i'll figure it out and when i do i'll update here. in the mean time i guess i'll put 93 gas in it
  3. #18
    Registered Member katapaltes's Avatar
    2003 Protege5
    Join Date
    Mar 2009
    Location
    Dallas, TX
    Posts
    166
    Pinging!!
    I ran a Celica so low on oil once that it sounded like it was pinging. Check the oil?
    Protect boys (and the men they become) from harm: www.luckystiff.org (my website)
  4. #19
    Registered Member
    '02 Mazda Protege5
    Join Date
    Apr 2017
    Location
    Mount Kisco NY
    Posts
    77
    SOLVED!! so last week I had changed one of those solenoids above the intake manifold, the one with the green connector, because i had a p0660 code. apparently that was related to all the pinging and power loss because the day after is when it started. and just now I went and swapped the solenoids on the green and white connectors. and now everything is fine. the knock sensor code may have been a weird coincidence. so those solenoids are for the VICS/VTCS but I don't know how that caused pinging but i don't care cause its fixed. also, maybe that new solenoid was defective but its fine so whatever. There's a bunch of those vacuum solenoids on that car (I count at least 4) . are they all the exact same part?
  5. #20
    Registered Member
    lolmsp
    Join Date
    Mar 2007
    Location
    757
    Posts
    5,228
    yes they are the same part as far as i know
    03 MSP, 03 P5
  6. #21
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    They're all the same but different.
    The electrical connector, vacuum tube orientation, and mounting clips could be different.
    Rockauto lists these two solenoids as the same valve.
    Everybody has a different name for them and rarely call it what the FSM calls it.
    It always best to check the posted picture and compare it to what you have.
    Here's what the guy who owned my parts car did.
    The connector wouldn't fit because the electrical tabs were spaced different, so it wouldn't plug in directly.
    I'm pretty sure the VICS and VTCS solenoids are exactly the same. (plug and play)
  7. #22
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    Here's some diagrams from the FSM.
    You can see how the PRC solenoid is slightly different.
  8. #23
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    Quote Originally Posted by wrathofpaul View Post
    ... and just now I went and swapped the solenoids on the green and white connectors. and now everything is fine. also, maybe that new solenoid was defective but its fine so whatever...
    If you swapped the solenoids and one of them is defective, you may throw a VTCS code now.
    It might take a while for the code because certain engine conditions have to be met to throw the code.
  9. #24
    Registered Member
    '02 Mazda Protege5
    Join Date
    Apr 2017
    Location
    Mount Kisco NY
    Posts
    77
    the new one is now on the VICS connector (the white one). that explains why the engine sounded louder. VTCS actuation depends on temperature right? the engine was sounding like it does when i first start driving on a cold morning... except it was warmed up. then i swapped the solenoids and it's fine. so the valves were either stuck open or stuck closed, possibly screwing up the fuel ratio and causing knocking. i can't wait till my OBDII analyzer arrives. i want to see the live data while everything works so i have a baseline. the VTCS code i had before didn't actually set off the CEL... i assume that means it would pass inspection... but decided to fix it anyway then all this happened lol
  10. #25
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    ... VTCS actuation depends on temperature right? ...
    Yes but for some reason, the ECU doesn't monitor
    the circuit until the engine is warm and revving above 3000 RPM ?
    Perhaps to see if it has shut off ?
    ... the VTCS code i had before didn't actually set off the CEL... i assume that means it would pass inspection... but decided to fix it anyway then all this happened lol
    If they just look to see if the CEL is on and maybe sniff your tailpipe your probably OK but if they plug into your OBDll port then they will find it.
    You might be OK if it's not enough to turn on the CEL.
  11. #26
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    368
    Quote Originally Posted by pcb View Post
    Can I get it in a can that has a screw on lid ?
    Is it safe to add to your gas or engine oil ?
    No, it is designed to hook into the fuel rail. I've never tried to put it in gas or anything, don't think I would want to. It's pressurized so will spray everywhere if you try to "open" it. Plus it's some pretty strong stuff, don't know what it would do to the tank or lines or filter or etc. You hook the can to the fuel rail and disable the fuel pump. The car runs on the can until the can is empty. Then you just hook the fuel line back up to the rail.
  12. #27
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    I'll stick with the Seafoam then.
    Luckily it's on sale for $10 a can this week.
    I'm gonna pickup a few.
Similar Threads
  1. Pinging...wah?
    By CF_KoiFry in forum Protege5
    Last Post: 10-31-2013, 12:36 AM
  2. Help with Pinging?
    By delavp5 in forum Protege5
    Last Post: 07-27-2010, 01:48 PM
  3. Pinging in your MS3
    By fastgascar in forum Mazdaspeed3
    Last Post: 05-21-2008, 04:09 PM
  4. Pinging?
    By newprot5fan in forum Protege5
    Last Post: 07-02-2007, 02:55 AM
  5. i think i'm getting pinging
    By kicker22705 in forum Mazdaspeed Protege
    Last Post: 12-04-2006, 02:48 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
