VersaTuner - tuning software for Mazdas
Page 1 of 2 12 LastLast
Results 1 to 15 of 27
Thread: Pinging!!
  1. #1
    Registered Member
    '02 Mazda Protege5
    Join Date
    Apr 2017
    Location
    Mount Kisco NY
    Posts
    76
    Pinging!!
    Today my engine started pinging. I hear it when I'm going uphill or if I accelerate after it shifts into 3rd or OD. I do have to be driving under 40 to actually be able to hear it over the road noise, so it's not that loud.
    Other posts have said to check the knock sensor. Is there a way to check it with a multimeter?
    I don't want to just throw parts at it blindly, I'd like to test each sensor with the multimeter if there is a way to do so. (like the MAF, O2, etc).
    I also read it could be a vacuum leak. in fact, last year i had ping, and it was cause of a cracked intake tube. I changed that and went away. so maybe there's air leaking somewhere else. Anyone have a diagram of all the vacuum lines?
    I have no CEL codes (which is good because my NY inspection is due -lol), but the other day I changed the VTCS solenoid (or whatever the one on the right is-white connector) because it had a P0660 code. Not sure if it's related.
    I suppose putting 89 octane in it will help, but that doesn't cure the underlying problem.
    car only has 86k miles and there are no other symptoms at all (runs like new). changed spark plugs, wires, and coils last year.
    is mild pinging going to damage the engine?
  2. #2
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,840
    The problem with the knock sensor is that it can test OK but still be crap.
    The accelerometer is suspended in a gell type stuff that dries up and oozes out but the circuit still tests good.
    Many people have reported goo dripping from the sensor.
    Here's the test for the knock sensor.
    It's just a test of resistance but not a good test of functionality
    If your knock sensor is crusty and gooey then it might be smart to replace it.
    The Diagram Dude
  3. #3
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,840
    I remember playing with my knock sensor about 5 or 6 years ago.
    I unplugged my sensor and connecting a resistor around 550 k ohms to see what the ECU would do.
    It did pop a code so I figure my sensor must be giving some output.
    But my sensor was dripping all kinds of goo so I figure it's not performing as good as it could.
  4. #4
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,840
    More info...
  5. #5
    Registered Member
    '02 Mazda Protege5
    Join Date
    Apr 2017
    Location
    Mount Kisco NY
    Posts
    76
    I ordered a new knock sensor because mine looks pretty gooey. lol. I also put some Seafoam in the oil and fuel. Those diagrams are very technical, but it looks like it says that if the knock sensor is bad the MIL won't illuminate unless the engine load is above 50% and it's up to temp. maybe I haven't met those conditions yet which is why i don't have any codes.
  6. #6
    Registered Member
    '02 Mazda Protege5
    Join Date
    Apr 2017
    Location
    Mount Kisco NY
    Posts
    76
    now that i think about it, I was driving up a steep hill and the pinging wasn't really there. I only heard it at light throttle. so maybe the knock sensor does work. oh, this is going to be fun to figure out. . at least it's getting warm out!!
    I also ordered a new code reader that reads live data and freeze frame data. every new job I have on this car I accumulate a new tool so that's cool haha
  7. #7
    Registered Member o.g.sk8er's Avatar
    Join Date
    Jul 2002
    Location
    los angeles, ca
    Posts
    1,574
    My car has pinged pretty much since day one. Chased it for years trying to find a cure. EGR, spark plugs, wires, IAC, timing.... Nothing. Seafoam seems to help temporarily, but always comes back. 70* or above and it pings a lot more. Idle has sucked too its entire life. I just live with it. Runs fine otherwise. *knock on wood*
    02 Protege 5
    Suspension:
    BC Coilovers; AWR endlinks; GT Spec front 4 point ladder bar; GT Spec rear V-Brace; GT Spec reinforcement panel; GT Spec rear strut bar; AWR trailing arms; Modded factory rear sway bar.
    Performance:
    MP3 ECU (not flashed); Unorthodox Underdrive Pulley; JDM MS flywheel (16lbs); Stock Air Box Mod with K&N drop in panel filter; 1sty Grounding Kit; TB Coolant Bypass Mod; 03 MSP Rear Axleback; Resonator Delete.
    Interior:
    Kartboy Short Shifter with Kartboy Bushings; DGM CF Gauge Bezel; DGM CF passenger side dash cover; Wink 5 Panel Mirror; CF Shiftknob; 4 inch shifter extension; Red Accent Lights; Super Bright LED's in the Gauge Cluster.
    https://www.youtube.com/user/ogsk8ermocc/videos
  8. #8
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    324
    Using a scope or reading live data and knock counts is the only way to see what th eknock sensor is really doing. I know on a lot of cars, if the knock sensor is bad, it will give a default of 13 counts (just using an arbitrary number) to prevent the computer from advancing timing too much. A failed knock sensor will hurt engine performance (due to retarded timing) and probably get worse fuel mileage, but it won't "Cause" pinging/knocking/preignition.
    Spark plugs, cleaning the injectors, throttle body, etc. will usually cure the preignition, as long as it isn't being caused by an intake leak or something of the sort.
    https://www.amazon.com/Genuine-Toyot.../dp/B00C392ZGS
    This is hands down the best stuff on the market for cleaning fuel injectors. You just hook a can up to the fuel rail, remove the fuel pump relay so the fuel pump is disabled, and start the car. The car runs of of the cleaner for around 15 minutes and dies when the can is empty. Then just hook the fuel line back up, plug in the relay, and go. Seafoam, BG, or no other detergents on the market can come even close to comparing with how well this stuff works. There is a tool kit that you screw the can into, that comes with all of the attachments to use the can.
    To give an example, back when I worked for the dealer, we had the BG guys come in. They were boasting about their 44k product, and had some test kit to show how much stronger and better it was than seafoam. They put their cleaner in a test tube, and added drops of something and when it turned from purple to clear (or something like that, this was along time ago) it showed how strong the detergents were. Seafoam took 4 or 5 drops. 44k took like 15 drops. I told them their stuff was crap, and the Toyota EFI can is the only thing I would ever use, so he tested that.....
    He got to about 50 drops and it was still bright purple. So he shot in a squirt and when it was still purple, said "is this stuff even legal?" LOL
    Ive had cars come in pinging, stumbling, barely running at all. Run a couple cans of the Toyota stuff through them, and they purr like a kitten and run like new afterwards.
  9. #9
    Join Date
    Jul 2002
    Location
    los angeles, ca
    Posts
    1,574
    hmmm...I'm intrigued. I might just try this stuff.
    It wont blow up my car since its a Mazda will it?
  10. #10
    Registered Member
    '02 Mazda Protege5
    Join Date
    Apr 2017
    Location
    Mount Kisco NY
    Posts
    76
    Well so I literally was on my way home after passing NYS inspection and the check engine light comes on. lol. and it's throwing a P0325 code... so I guess it's the knock sensor after all. at least It happened AFTER they issued a new sticker lol
  11. #11
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    324
    Quote Originally Posted by o.g.sk8er View Post
    It's just detergents, i've used it in all sorts of cars. I don't know what our fuel fitting looks like because i've never messed with it on my car, but the tool comes with a variety of different screw-on and clip-in fittings for the fuel rail. OTC makes the parts for Toyota, i'm sure they have a more "universal" kit to cover all the other different fittings.
  12. #12
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,840
    Quote Originally Posted by pb4ugotobed View Post
    I might consider it for $20-$30 CAD especially if you just need a few drops compared to Seafoam but I'm not spending $143 a can for it.
  13. #13
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    324
    Quote Originally Posted by pcb View Post
    It's a pressurized can that you hook to the fuel rail. You use the entire can, but won't need to do it again for another 100k miles or so (unless you locally have really crappy gas...)
    Try your local dealership, they should carry it. IT may not ship international because it's a pressurized can of chemicals.
  14. #14
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,840
    Can I get it in a can that has a screw on lid ?
    Is it safe to add to your gas or engine oil ?
  15. #15
    Registered Member
    '02 Mazda Protege5
    Join Date
    Apr 2017
    Location
    Mount Kisco NY
    Posts
    76
    OH MY GOD so I changed out the knock sensor, and the check engine light went away, but it's still pinging! and I noticed the engine sounds different at certain RPMs under load and also there seems to be a slight loss of power... like it takes forever to get up to redline if I floor it (it's automatic). but it's not running rough or anything... i'm stumped
Similar Threads
  1. Pinging...wah?
    By CF_KoiFry in forum Protege5
    Last Post: 10-31-2013, 12:36 AM
  2. Help with Pinging?
    By delavp5 in forum Protege5
    Last Post: 07-27-2010, 01:48 PM
  3. Pinging in your MS3
    By fastgascar in forum Mazdaspeed3
    Last Post: 05-21-2008, 04:09 PM
  4. Pinging?
    By newprot5fan in forum Protege5
    Last Post: 07-02-2007, 02:55 AM
  5. i think i'm getting pinging
    By kicker22705 in forum Mazdaspeed Protege
    Last Post: 12-04-2006, 02:48 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
