Page 2 of 7 FirstFirst 1234 ... LastLast
Results 16 to 30 of 105
Thread: Signature mpg
  1. #16
    Registered Member erhayes's Avatar
    Donated: $10
    Mazda CX-5 FWD Touring
    Join Date
    Jan 2007
    Location
    Cape Coral, FL.
    Posts
    2,857
    My on-board were within +/- 3%. Frequently the on board showed lower mpg, so after 5 or so tank fill I now just use the on-board computer. Ed
  2. #17
    Registered Member
    Donated: $25
    Join Date
    Apr 2019
    Posts
    52
    This is interesting. I wouldn’t mind the MPGs everyone is getting at all if Mazda had put an 18 gallon tank in the cx5 instead of a 15 gallon tank.
  3. #18
    Registered Member
    2019 Mazda CX-5 Signature
    Join Date
    Jun 2019
    Location
    Austin, Texas
    Posts
    7
    I'm only on my 2nd tank ever and I question the quality of the gasoline the dealer put in the first tank, but I did do the math on the first fill up, though not "precisely", and it was in the ball park for with about 240 miles on 13 gallons, so 18.x was close enough. I'll do the math on the next couple tanks, but with variations in where the gas pump kicks off (especially filling up at 100+ degrees the vapors often cause the pump to kick off way early) there is always fudge factor to the calculations.
    The power is a bit addictive, but for this second tank I haven't been pushing it as much. I think the main issue is the bajillion degrees it is inside the car after sitting in the sun in 100 degree weather. So the AC and vented seats are running full blast for each 20 minute drive. And every stop-and-go event, the engine is running higher RPMs to drive the AC, plus running its own cooling fan, etc.
  4. #19
    Registered Member
    2015 Mazda CX-5 Touring FWD
    Join Date
    Jun 2012
    Location
    Charlotte NC
    Posts
    186
    After 200 fill ups my 2015 CX5 Touring at the pump average is 28.1, the dash average is 28.4. The difference is negligible. Averages are kind of high due to a lot of Interstate travel. I have tried Premium, and alcohol free tankfuls. They are not worth the extra money that they cost. Lowest average was 21.3, highest was 34.2.
  5. #20
    Registered Member
    Join Date
    Apr 2019
    Posts
    17
    Quote Originally Posted by kone View Post
    We are totally loving our Signature! Beautiful and fun car.
    I'm wondering what others are seeing for mpg?
    We haven't seen >23 mpg yet.
    3000 miles. Right at 23 MPG. My daily commute is a combination of stop/go and 65MPH+ stretches. I think the stop/go is what is keeping the MPG down.
    I was able to get ~27MPG with my previous vehicle, a BMW Z4 28I, but that required 91 Octane. With the CX-5 I'm using 87 Octane which is currently about 20% Cheaper than 91 Octane, so I'm coming out roughly equal.
  6. #21
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,965
    Arrow Signature mpg
    Quote Originally Posted by alexm9999 View Post
    I was able to get ~27MPG with my previous vehicle, a BMW Z4 28I, but that required 91 Octane. With the CX-5 I'm using 89 Octane which is currently about 20% Cheaper than 91 Octane, so I'm coming out roughly equal.
    Mazda says you can run 87-octane gas perfectly fine on 2.5T or you simply just waste your money.
    Quote Originally Posted by shadonoz View Post
  7. #22
    Registered Member
    Join Date
    May 2019
    Location
    Belleair Beach, Florida
    Posts
    70
    Quote Originally Posted by yrwei52 View Post
    Actually, it just says below 87 could damage your engine. From the manual:
    "Fuel with a rating lower than 87 octane (91 RON) will negatively affect the emission control
    system performance and could also cause engine knocking and serious engine damage."
    I guess my definition of "perfectly fine" reaches a little higher than yours. I don't consider better performance a waste of money. Otherwise I'd be driving something else.
  8. #23
    Registered Member
    Join Date
    Apr 2019
    Posts
    17
    My mistake. I meant to say I*m running 87 octane. I did try a tank of 91 but didn*t notice a difference in performance.
  9. #24
    Registered Member
    Join Date
    Jul 2007
    Location
    North Carolina
    Posts
    47
    After putting 2400 miles on my 2019 my average is showing 25.4. As a test I monitored a trip from Charlotte NC to Clover SC (25 miles) driving as easy as I possibly could in light traffic and was able to average 35 mpg on the trip computer. I couldn*t come close to driving like that everyday but it was interesting to see how you could improve the 25 mpg figure. Also I have been running 89 non ethanol gas.
  10. #25
    Registered Member
    2019 CX-5 Sig Soul Red
    Join Date
    May 2019
    Location
    NY
    Posts
    45
    Quote Originally Posted by St1ngy View Post
    "............... I guess my definition of "perfectly fine" reaches a little higher than yours. I don't consider better performance a waste of money. Otherwise I'd be driving something else.
    Totally agree....
  11. #26
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,965
    Arrow Signature mpg
    Look at the power graph I posted above. You don't get "better performance" with higher octane gas unless you rev your engine over 4,000 rpm. And Mazda says this in the published power curve:
    ADDITIONAL HIGH-RPM PERFORMANCE IS POSSIBLE WITH HIGHER OCTANE.
    * To prevent unnecessary spending on premium fuel, both power ratings are published
  12. #27
    Registered Member
    Join Date
    Jun 2019
    Posts
    5
    I live in SoCal, a lot of stop and go. I*ve been using 91 Costco gas, the dash ranges from 20-23 mpg.
  13. #28
    Registered Member
    Join Date
    May 2019
    Location
    Posts
    70
    So, what's your point? If I wanted economy, I'd get some econo-box.
    With my other car I'd spend $1-2K in mods to add 20-30 more HP. Here, I just need to push a different button on the pump and pay a few bucks more.
    Around here, you have a hard time finding 91 octane, so I usually alternate between 87 (or 89) and 93 when topping at 1/2 tank. SO it's probably more diluted than pure 91.
  14. #29
    Registered Member
    Join Date
    Dec 2018
    Location
    IL
    Posts
    365
    I've run both 87 and 93. I would probably need a stopwatch to tell if there's any difference from 0-60, because I didn't feel it. The main advantage of the turbo is the low end torque, which is the same no matter what octane you use. Since 93 is about 60 cents a gallon more than 87 here, and I'm not tracking the vehicle, it's kind of a no brainer for me. If the price was say, 20 cents apart, it would probably be different.
    Just to be clear, I am not criticizing you for running higher octane. If you spend enough time above 4k RPM, it's probably worth it.
  15. #30
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,965
    Arrow Signature mpg
    Quote Originally Posted by Sig cx-5 View Post
    This's exactly the point, which is also Mazda's design goal of its SkyActiv-G 2.5T. When 2.5T just came out and used in gen-2 CX-9 in 2016, Mazda claimed the 2.5T is designed mainly for low-end torque which is suitable to heavy CX-9. Its research indicates most car owners won't rev the engine over 4,000 rpm, hence the relatively smaller turbo charger on 2.5T will run out of the breath over 4,000 rpm.
    Since the power and torque are exactly the same under 4,000 rpm between octane 87 and 93 gas, so unless you spend enough time above 4,000 rpm, you don't get better performance.
Similar Threads
  1. Moved From 2017 Signature to 2018 Signature In 4 Months
    By Guest2018 in forum CX-9 General
    Last Post: 12-23-2017, 12:16 AM
  2. signature
    By xitoxic in forum Lounge
    Last Post: 03-21-2012, 10:32 PM
  3. New Signature....
    By MSP4EVER in forum Lounge
    Last Post: 06-24-2004, 01:28 AM
  4. My New Signature
    By MSP4EVER in forum Pics & Builds
    Last Post: 05-31-2004, 04:55 PM
  5. new signature
    By jersey_emt in forum Pics & Builds
    Last Post: 03-04-2004, 05:57 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
