CorkSport.com is MAZDA PERFORMANCE!
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: 2002 Protege 5/Familia sport 20
  1. #1
    Registered Member
    Join Date
    Mar 2019
    Posts
    10
    Does anyone know where I can purchase roof molding for a 2002 Mazda familia sport 20 or if a US model 2002 Mazda Protege 5 roof molding would fit the Japanese model?
  2. #2
    Registered Member STudMUffin1177's Avatar
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham
    Posts
    190
    I think you might be screwed if your trying to buy new moldings, I've looked and havnt found them anywhere. You might be able to find them used but most end up breaking when they get removed because they are so brittle. I dont think the roof area got any changes between the US and Japanese models so it should fit unless I'm an idiot
  3. #3
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,840
    Just an FYI.
    I believe the Canadian version is different.
    Apparently the roof rack was strictly an option when it was new and Mazda had a contract with Thule to supply them.
    The connections for it are built into the roof and all Canadian P5's had them.
    I'm pretty sure the filler strips fit all models of P5 and I think they're still available.
    The Diagram Dude
  4. #4
    Registered Member
    Join Date
    Mar 2019
    Posts
    10
    Im starting to believe that...I've been searching for weeks with no success on the following sites:
    I've either gotten it's listed on our site but not available, or simply no response as to if its in stock.
    Quote Originally Posted by STudMUffin1177 View Post
  5. #5
    Registered Member
    Join Date
    Mar 2019
    Posts
    10
    Any idea where I can find the filler strips?
    Quote Originally Posted by pcb View Post
    Just an FYI.
  6. #6
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,840
    I've been checking Amazon, eBay and OEM parts suppliers but nothing yet.
  7. #7
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,840
    I did find these but they are meant to be installed on top of your original moldings (like tape) so if you've got no moldings at all they won't work but if you've just got old ones that look bad this may work for you.
  8. #8
    Registered Member
    Join Date
    Mar 2019
    Posts
    10
    I actually have no moldings at all.
    I still currently have the metal pieces from the OEM roof racks still installed, however the plastic parts became brittle and broke apart.
  9. #9
    Registered Member Anzi's Avatar
    2002 Protegé5 manual
    Join Date
    Feb 2018
    Location
    SF Bay Area, California
    Posts
    115
    Quote Originally Posted by hezron View Post
    That was the case on my black car when I bought it, but the one I was replacing had no cracks in the roof moldings or rack, so I swapped them around. From what I can tell, they get brittle easily
  10. #10
    Registered Member
    Join Date
    Mar 2019
    Posts
    10
    Same here.
    I thinking of alternatively having someone make a fiberglass molded strips to replace it.
  11. #11
    Registered Member grffn's Avatar
    Donated: $8.08
    '02 P5
    Join Date
    Jan 2017
    Location
    Hawaii
    Posts
    213
    I've just gotten mine and installed them the other day.
    I ordered mine from JP Parts via https://www.facebook.com/jppartsintl/
    He even shipped them with all the hardware. Try and get in contact with him and I'm sure he'll find a set for you.
  12. #12
    ......................... i12drivemyMP5's Avatar
    Donated: $5
    323F
    Join Date
    Apr 2005
    Location
    Posts
    7,562
    I just scored a plastic rack filler cap piece new from an online dealership. They even had to send a replacement due to shipping damage making it unusable. IIRC they still had the filler strips available/listed......I have strips to eliminate rack but not sure if I have all the hardware for them but not letting go of them either. Try scoping out oemmazdaonline.com which is Corey Fairbanks Mazda in Longwood, FL......................here is link to the filler strip (molding) & cover/clips......
    https://www.oemmazdaonline.com/v-200...rior-trim-roof
    Says available and this is where I got rack strip filler cap from........ordering me 2 of the clips I think I'm missing to swap in filler strip if removing rack mounts completely.
  13. #13
    Registered Member
    Join Date
    Mar 2019
    Posts
    10
    Thanks!!! i will definitely check him out!
  14. #14
    Registered Member
    Join Date
    Mar 2019
    Posts
    10
    I will check with them, the last site i checked also had it (filler strips) up on there site but no longer had it in stock, which was quite disappointing. I find that the caps and clips are easy to source, the strips are a problem.
    Quote Originally Posted by i12drivemyMP5 View Post
  15. #15
    Donated: $5
    323F
    Join Date
    Apr 2005
    Location
    Posts
    7,562
    Those showed $62 somethin each and showed available...............shows left and right
    https://www.oemmazdaonline.com/oem-p...ItMGwtbDQtZ2Fz
Similar Threads
  1. My "JDM" 2002 Protege 5/Familia Build
    By Android 6 in forum Protege5 Builds
    Last Post: 12-22-2018, 10:04 AM
  2. Familia Sport 20 4wd
    By Vigilante in forum Want To Buy
    Last Post: 10-21-2015, 02:26 AM
  3. Familia Sport 1.5 VVT 5 door.
    By Mazdabeans in forum Mazda Protege
    Last Post: 11-07-2011, 08:57 PM
  4. The Mazdaspeed Familia Sport 20...
    By StuttersC in forum Other Mazdas
    Last Post: 11-20-2002, 01:50 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
