- RDX Aspec Adv.
why would you press it again and again? i'm guessing you don't know how this works..
you should actually try it.
once activated it stays on...so all you have to do is brake, rest, go, brake, rest, go...etc.
Only reason you would press the button again is to turn it off.
Also activates the ebrake automatically when you put it in park and turn the engine off.
Not how mine works. Each time you want to use it, you press the thing. Or am I doing it wrong?
1) Brake and fully stop.
2) Press button, and it results in brakes holding with foot off.
3) Go, and it automatically releases.
4) Stop, repeat 1-4 again as needed. Skipping step 2 in this sequence results in rear-ending someone, if you're so inclined and SBS or SBCDSXERS or whatever that hits the brakes for you is not working.
It's pointless.
