Compare auto reliability with reliable results at TrueDelta.com!
Results 1 to 9 of 9
Thread: bars leaks- valve stem repair?
  1. #1
    Registered Member
    Join Date
    Mar 2019
    Posts
    2
    anyone have experience with bars leaks- valve stem repair.
    I am getting smoke at starts up and believe it is the valve stems.
    Nothing bad yet but I'm looking in to replaces the head with one from rock auto.
    anyways anyone had luck with this stuff.
    i wanna try something as i have to drive 400+ miles in a few weeks and dont want anything to go wrong.
    TIA for any help.
  2. #2
    Registered Member STudMUffin1177's Avatar
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham
    Posts
    190
    It might be your oil rings, these fsde engines have really weak rings that don't get a lot of oil and tend to seize up. I've had luck with using seafoam in the crankcase and gas tank to help clean up the Smokey start up. I do half in the crankcase and half in the gas tank, with a full tank. Then drive it for 200 miles and change the oil and filter.
  3. #3
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,836
    ^^^ What he said.
    Here's the big writeup about it.
    https://www.mazdas247.com/forum/show...l-acceleration
    The Diagram Dude
  4. #4
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham
    Posts
    190
    the guy with all the info.
  5. #5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,836
    Quote Originally Posted by STudMUffin1177 View Post
    Info, diagrams and pictures of my rusty P5.
    My rear caliper piston...
    Here's a picture of a piston with a seized oil ring.
    Thanks Mr Giggles for providing this picture.
  6. #6
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,836
    Quote Originally Posted by Driggs831 View Post
    I used bars radiator stop leak in my '83 GLC and it worked for me at the time (1985~1990)
    Stopped the leak.
    I remember it was weird because half the can was what looked like liquorice jelly beans ??
    Apparently, you can use oatmeal or pepper if you spring a leak while you're camping.
  7. #7
    Registered Member
    lolmsp
    Join Date
    Mar 2007
    Location
    757
    Posts
    5,135
    Quote Originally Posted by pcb View Post
    Stopped the leak.
    just how much pepper or oatmeal? taking notes for the camping trips this summer.
    03 MSP, 03 P5
  8. #8
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,836
    Quote Originally Posted by 323 View Post
    I have no idea. I've never done it.
    Apparenty it can really plug up your rad.
    But it can help you make it home if you stock up your car with lots of lake water..
  9. #9
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    324
    Any of the stop smoke, stop oil leak, etc. products are junk. They don't work. All they do is thicken the oil and slow it down a little, you could accomplish the same thing basically putting 20w50 in your next oil change.
    The head gasket repair, radiator repair, etc products do work as a short term fix. They contain carbon fibers, copper, or other materials that work similar to the green tire slime stuff to fill in small holes or cracks. I wouldn't trust it long term, but it'll get you through in a pinch until you can repair whatever has failed correctly. And yes, they can plug up the radiator. Especially the one with the sodium silicate (liquid glass). This is the same stuff we used during the "cash for clunkers" days to blow up engines. Some nasty stuff for sure.
    Regardless of what the issue is, bottom line, there's no "magic mechanic in a bottle" fix that is going to be reliable long term. If something has failed/stuck/leaks/cracked/etc. the only true repair is going to be replacing the failed part.
Similar Threads
  1. Anyone try Bar's Leaks Power Steering Repair?
    By Holiday in forum Protege5
    Last Post: 12-26-2017, 08:53 AM
  2. Valve stem seals
    By delboy in forum Mazda Protege
    Last Post: 01-14-2012, 07:44 PM
  3. what valve stem do i use?
    By Stock-Speed3 in forum Mazdaspeed3
    Last Post: 10-22-2007, 10:12 PM
  4. Valve stem guides?
    By Gavin in forum Mazda How-To
    Last Post: 04-27-2006, 09:56 AM
  5. Valve Stem Caps
    By bud_d in forum Mazda MP3
    Last Post: 07-10-2003, 01:34 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
