Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Thread: Brakes Longevity
  1. #1
    Registered Member
    2017 Mazda CX-5 Grand Touring
    Join Date
    Jul 2017
    Location
    Wisconsin
    Posts
    329
    Brakes Longevity
    Hello,
    I know this can vary greatly, but Iím curious at what mileage you all have had to change your brake pads? Iím only at 16k on my 2017, so I most likely have Some time yet.
    Anyway, just curious.
  2. #2
    Registered Member
    2016 Mazda, CX-5 GT
    Join Date
    Dec 2013
    Location
    Magnolia TX
    Posts
    84
    I drive mostly highway. At last 60%. Changed mine at 75K. Fronts had at least 30% left but rears were maybe 10% left.
  3. #3
    Registered Member erhayes's Avatar
    Donated: $10
    Mazda CX-5 FWD Touring
    Join Date
    Jan 2007
    Location
    Cape Coral, FL.
    Posts
    2,795
    All suburban driving with my 2014 CX5. 48,000 miles and not even close to changing pads. Ed
  4. #4
    Registered Member
    CX5 GT-R
    Join Date
    May 2015
    Location
    South-Central US
    Posts
    7,442
    Quote Originally Posted by Jman136 View Post
    Hello,
    I know this can vary greatly, but I*m curious at what mileage you all have had to change your brake pads? I*m only at 16k on my 2017, so I most likely have Some time yet.
    95k or so on my 2015.
  5. #5
    Registered Member
    Join Date
    Jul 2017
    Location
    Wisconsin
    Posts
    329
    Quote Originally Posted by Unobtanium View Post
    Wow, these pads last along time!
  6. #6
    Registered Member tibimakai's Avatar
    2014 Mazda CX-5 Touring
    Join Date
    May 2013
    Location
    Los Angeles-San Dimas, USA
    Posts
    2,681
    50k still OK.
  7. #7
    Registered Member
    CX5 GT-R
    Join Date
    May 2015
    Location
    South-Central US
    Posts
    7,442
    The rotors don't in my case. By 50K they were annoying
  8. #8
    Registered Member
    2013 Mazda CX-5 Sport FWD Auto
    Join Date
    Oct 2012
    Location
    FL
    Posts
    253
    63k on my 2013, brakes still doing fine.
  9. #9
    Registered Member
    Join Date
    Jul 2017
    Location
    Wisconsin
    Posts
    329
    At what mileage did they warp?
  10. #10
    Registered Member
    CX5 GT-R
    Join Date
    May 2015
    Location
    South-Central US
    Posts
    7,442
    40-50. At 60 I began thinking about replacing them. At 95K or so the pads dictated it.
  11. #11
    Registered Member
    Join Date
    Jul 2017
    Location
    Wisconsin
    Posts
    329
    Is it common for these rotors to warp? I love my CX, but I absolutely hate the brakes. I wish they gripped more and quicker like our Subaru does though.
  12. #12
    Registered Member
    CX5 GT-R
    Join Date
    May 2015
    Location
    South-Central US
    Posts
    7,442
    Replace the pads with stoptech. Get ready for dust and grip.
  13. #13
    Join Date
    May 2013
    Location
    Posts
    2,681
    They warp, if you brake for to long on a steep downhill. Try downshifting in cases like that and avoid using the brakes, for prolonged periods. They heat up a lot and they deform.
  14. #14
    Registered Member Anchorman's Avatar
    2019 CX-5 GT 184 2.2 diesel auto - Sonic Silver
    Join Date
    Jan 2016
    Location
    Derbyshire UK
    Posts
    2,493
    Friction material wear rises exponentially with temperature so the hotter you run them the quicker they will wear out. The same goes for the disc but a disc that wears due to heat rarely warps. In fact, the pad tends to true the disc. Disc run out isn*t usually the result of warping which is the same as a warped record, it is a condition called DTV (disc thickness variation) so the warping is out of phase on each side. That tends to happen when the temperature is on the low side and mileage is high. Some of the wear debris from the pad is transferred onto the disc which means the pad runs on debris for part of a rotation and cast iron for another. It*s the cast that wears and that causes DTV. Friction material need temperature to work properly as temperature wears away the resin system and exposes the abrasives that create friction. The healthiest brakes will be those that see frequent temperature excursions as they constantly get conditioned and keep the disc healthy. They might need changing at 20000 miles with a ratio of two sets of pads to one set of discs. Really hard driving will reduce that but once you get in excess of 50000 you get into sleepy pads and DTV problems.
  15. #15
    Resident barbarian ColoradoDriver's Avatar
    Donated: $5
    2014 CX-5 Touring AWD
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    4,873
    My rears were done around 54k miles.
    Just did my fronts a little while ago...so 75k+? They were technically still good, but were wearing unevenly, so I had them replaced along with lubricating everything again, and getting the rotors turned.
    2014 CX-5 Touring AWD 2.5L | Jet Black Mica - 82k miles
    01/2013 build | 4/20/2013 delivery
Similar Threads
  1. CX-5 Longevity
    By gunguy05 in forum CX-5 Lounge
    Last Post: 09-23-2016, 10:03 AM
  2. All about CX-5 longevity
    By buyingconstant7 in forum CX-5 Lounge
    Last Post: 10-15-2015, 12:07 AM
  3. Longevity
    By mikey1981 in forum Mazda CX-7
    Last Post: 08-02-2007, 05:23 PM
  4. LSD Longevity?
    By tschanrm in forum Mazdaspeed Protege
    Last Post: 02-23-2007, 07:11 AM
  5. Longevity
    By clownphish in forum Lounge
    Last Post: 01-29-2004, 07:16 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
