Page 5 of 7 FirstFirst ... 34567 LastLast
Results 61 to 75 of 94
Thread: GT-R oil overfilled
  1. #61
    Registered Member Anchorman's Avatar
    2019 CX-5 GT 184 2.2 diesel auto - Sonic Silver
    Join Date
    Jan 2016
    Location
    Derbyshire UK
    Posts
    2,559
    Quote Originally Posted by Buzzman12 View Post
    Now THAT made me laugh out loud.
    But really, you're right. I just don't see some guy in an assembly plant pouring oil into engines all day long for a living.
    I didnít realise this thread was still going. No, it wouldnít be Akemi in the plant, that would be down to an exact measurement by some computerised dispenser. If my post had been read correctly, it refers to the person at the dealership doing the pre delivery inspection.
  2. #62
    Join Date
    Jan 2016
    Location
    Derbyshire UK
    Posts
    2,559
    As long as the correct amount of oil is added, it is OK to be lower than the full mark. This is the risk of adding oil to the top mark......
    Attached Files Attached Files
  3. #63
    Registered Member CX-5um's Avatar
    13' CX-5 and 16' Mazda6 both Touring w/Tech/Bose
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    3,216
    Quote Originally Posted by Anchorman View Post
    "If a vehicle is driven lot of short trips". Not really the case for us fortunately.
  4. #64
    Registered Member
    Cx5
    Join Date
    Jan 2019
    Location
    Vermont
    Posts
    86
    Didnít realize this thread would annoy so many people. I was just interested in what other people were seeing and then figured Iíd share my update.
    Which is what I thought was the purpose of a forum like this.
    To be fair, I didnít expect it to be 5 pages.
  5. #65
    Registered Member
    Mazda CX 5 GT-R
    Join Date
    May 2019
    Location
    Occupied California
    Posts
    57
    I did the first oil & filter change on my 2019 GT-Reserve a couple of days ago at around the 1200 mile mark. I drained well over 5.25 quarts out as I refilled the 5 qt. jug of Castrol with the used oil almost to overflowing and then dumped at least another 1/4 quart into an empty laundry detergent jug that I use for oil to be recycled.
    I used a Mazda factory filter, pre-filled it making sure that the oil soaked into the pleats pretty well and then added the reminder of the 5 qt. jug of Castrol Edge 5W-30 and another 1/4 quart of Redline 5W-30 that I wanted to use up. I checked for leaks, buttoned everything back up and went out to run some errands. I put about 25 miles on it and checked the dipstick. It was halfway between the dots.
    The owners manual states the oil capacity, with filter change, is 5.1 quarts. It clearly is not. I added about another 1/4 quart to bring it up to the top dot on the dipstick. I have always kept my vehicles topped off, I don't like the idea of "anywhere between the min/max marks is OK".
  6. #66
    Work in Progress sm1ke's Avatar
    Donated: $25
    2018 Mazda CX-9 Signature
    Join Date
    Dec 2016
    Location
    MB, Canada
    Posts
    1,636
    Personally, this is what I go by.
    Green is where I want to be. Yellow is ok. If it's close to the low oil indicator, I'll add a bit of oil to bring it in the green. If it's close to the max oil indicator I just leave it alone. If its in the red, I fill/drain as required.
    My reasoning for this is because I treat it like a tolerance. I deal with tolerances a lot in my work, and being dead in the middle of the range is ideal, while being too close to either end can actually cause issues with operation. When dealing with oil, filling to the max line isn't going to be a problem in the overwhelming majority of cases. It just means that there's more to drain out and you're going to add a little more oil to get to the full mark.
    Attached Images Attached Images
  7. #67
    Registered Member
    Soon to be 2.5T CX-5
    Join Date
    Jul 2019
    Posts
    86
    Quote Originally Posted by DwightFrye View Post
    I'd much rather have mine "halfway between the dots" than the "top dot", but it's all good, I guess.
  8. #68
    Gen-1 Kodo Design 👌 ColoradoDriver's Avatar
    Donated: $5
    2014 CX-5 Touring AWD
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    5,217
    Quote Originally Posted by sm1ke View Post
    Agreed.
    Plus it just costs more to buy a 6th quart. It's not necessary unless you find you are burning excessive oil.
    2014 CX-5 Touring AWD 2.5L | Jet Black Mica - 84k miles
    01/2013 build | 4/20/2013 delivery
  9. #69
    Registered Member
    2018 CX-5 Sport
    Join Date
    Dec 2018
    Location
    NJ
    Posts
    471
    With CD it's probably best to have the oil on the full mark. It probably doesn't matter but can't hurt. Mine takes exactly 5 quarts plus 425cc's, using a measuring pitcher.
  10. #70
    Donated: $25
    Join Date
    Dec 2016
    Location
    MB, Canada
    Posts
    1,636
    Quote Originally Posted by MyFirstMazda View Post
    The GT Reserve comes with the 2.5T engine, which doesn't have CD. Even if it did, I don't think it would make any difference.
    Regarding oil changes, I don't bother measuring out how much oil to put back in. For one, I don't wait until the oil stops dripping from the drain. My oil changes would take forever if I did that. I give it a reasonable amount of time to drain, then I reinstall the drain plug with the new washer and move on. This means that there's always a very minimal amount of oil left in the pan, but the amount can vary. After one oil change I might need 5.25 quarts, after the next I might need only 5. I don't bother measuring it out because it can change - all that matters is that I get the oil level to where it needs to be, and that I remember that I'll need about 5 quarts for an oil change (plus one quart just in case I need more).
    Taking the time to drain as much of the oil from the pan as possible, measuring out oil in a pitcher, filling oil so that it reaches the max mark.. all of these steps don't hurt, but they are wastes of time IMO.
  11. #71
    Registered Member
    2019 CX-5 Reserve Eternal Blue
    Join Date
    Aug 2018
    Location
    Central Virginia, USA...the winding rural part
    Posts
    835
    I would not take the time to measure it out, but I've changed my own oil for years and can't imagine being dirty already, having all the supplies out there, pulling the dipstick, seeing that it's 1/2 quart low, then shutting the hood and walking away from it. Why not top it off? Isn't that one reason we do our own work rather than have some stranger do it?
    Plus I gotta think there are incremental benefits to adding that extra 10% (1/2 quart).
    edit to add: I would not dribble some in, wait for it to trickle down, check the level, and repeat until it was exact. But I'd estimate how under-filled it was and add that approximate amount.
  12. #72
    Donated: $25
    Join Date
    Dec 2016
    Location
    MB, Canada
    Posts
    1,636
    Quote Originally Posted by Avoidin Deer View Post
    Absolutely, you're totally right. In the end it's just preference. Nothing wrong with topping it off if you want to. But to me, "1/2 quart low" means 1/2 quart below the middle of the min max range. "1/2 quart below the max mark" is perfectly fine by me, I'll keep that 1/2 quart on the shelf for the next oil change, in case I need it for the next oil change.
  13. #73
    Donated: $5
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    5,217
    Except that it requires buying a 6th quart of oil if like me you usually buy a 5 quart jug. That's added expense for perceivable no benefit. 5 quart jug has always gotten mine "close enough" to the full mark. Hell if you buy a Mazda Moly 0w20 oil change kit from Med Center Mazda, they send you....5 quarts.
  14. #74
    Registered Member
    Join Date
    Aug 2018
    Location
    Posts
    835
    Quote Originally Posted by ColoradoDriver View Post
    Not to beat such a low-level issue to death (although that IS what the internet was invented for, and we're not allowed to discuss politics), but don't you think that extra 10% (1/2 qt on top of 5 qts) is buying you incremental lubrication/deferred degradation/cooling?
  15. #75
    Registered Member
    Join Date
    Jul 2019
    Posts
    86
    You can't buy anything with that extra 10% you just spent for nothing.
Similar Threads
  1. Overfilled CV Boots?
    By FukuokaKid in forum Mazda5 Engine & Transmission
    Last Post: 04-09-2019, 01:34 PM
  2. 2017 CX-9 Oil overfilled and interval
    By Staphwildman in forum CX-9 Engine & Transmission
    Last Post: 02-11-2019, 10:52 AM
  3. Dealer overfilled oil
    By JTNY in forum CX-5 Engine & Transmission
    Last Post: 09-21-2017, 08:23 AM
  4. Oil overfilled by dealer
    By zorobg in forum CX-5 General
    Last Post: 06-30-2014, 08:12 AM
  5. Oil overfilled from factory?
    By FrequentFlyer in forum Mazdaspeed3
    Last Post: 06-10-2008, 10:10 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
