Results 1 to 5 of 5
Thread: 2017+ AWD Differential Fluid Change
  1. #1
    Registered Member Lbear's Avatar
    2017 CX5 AWD Touring
    Join Date
    Oct 2008
    Posts
    917
    Anyone got good pics/how-to for replacing the 2017+ AWD differential fluid?
  2. #2
    Registered Member
    cx5 gt +pp 2018
    Join Date
    Dec 2018
    Location
    arizona
    Posts
    291
    Dont have pics but it seems easy.
    Here are the official instructions.
    for the rear differential
    1. Place the vehicle on level ground.
    2. Remove the filler plug. (at the rear near top side)
    3. Remove the drain plug (at the rear near bottom) and drain the differential oil into a container.
    4. Install a new washer and the drain plug, and tighten.
    Tightening torque
    4053 Nm {4.15.4 kgfm, 3039 ftlbf}
    5. Add the specified differential oil from the filler plug (at the rear top side) until the level reaches the brim of the plug hole.
    6. After filling with differential oil, perform oil level inspection.
    7. Install a new washer and the drain plug, and tighten.
    Tightening torque
    Capacity (approx. quantity): 0.45 L {0.48 US qt, 0.40 Imp qt}
    for the transfer case in front
    1. Remove the front under cover No.2..
    2. Remove the drain plug (at the bottom of the transfer case) with the washer.
    3. Drain the oil into a suitable container.
    4. Tighten the drain plug with a new washer.
    Tightening torque
    4058 Nm {4.15.9 kgfm, 3042 ftlbf}
    5. Remove the oil level plug (on the side above) with the washer and add the specified amount and type of oil through the oil level plug hole until the level reaches the bottom of the oil level plug hole.
    6. Tighten the oil level plug with a new washer.
    Tightening torque
    Capacity (approx quantity): 0.45 L {0.48 US qt, 0.40 lmp qt}
  3. #3
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,957
    Arrow 2017+ AWD Differential Fluid Change
    Quote Originally Posted by cz5gt View Post
    For gen-2 CX-5 AWD, the specs say the rear differential gear oil capacity is 0.39 US quarts, not 0.48 quarts that's for gen-1 CX-5. But in reality, we may need up to 0.75 US quarts if we "add the specified differential oil from the filler plug (at the rear top side) until the level reaches the brim of the plug hole".
  4. #4
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,957
    Quote Originally Posted by Lbear View Post
    This thread is for gen-1 CX-5 but it should be applicable to gen-2 CX-5 other than rear differential gear lubricant capacity.
    Rear Diff and Transfer Case Fluid Change: tools parts and links
  5. #5
    Join Date
    Oct 2008
    Posts
    917
    Are the drain plug gaskets for Gen 2 the same as in Gen 1?
    I assume Gen 2 uses the Mazda Long Life Hypoid Gear Oil?
Similar Threads
  1. when to change rear differential fluid?
    By jdmarsh in forum CX-5 Engine & Transmission
    Last Post: 08-04-2019, 08:49 PM
  2. Replies: 2
    Last Post: 07-28-2016, 10:52 PM
  3. How to change "Rear" Differential fluid ?
    By kulkarnipb in forum CX-9 Engine & Transmission
    Last Post: 07-15-2016, 12:07 PM
  4. Rear differential fluid location
    By makan.dm in forum CX-9 How-To
    Last Post: 01-18-2015, 06:27 PM
  5. rear differential fluid
    By dondagun in forum CX-9 Engine & Transmission
    Last Post: 12-30-2013, 06:56 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
