CorkSport.com is MAZDA PERFORMANCE!
Results 1 to 7 of 7
Thread: How often brake pads needs to be inspected - every 2 yrs or 30k?
  1. #1
    Registered Member
    mazda
    Join Date
    Sep 2017
    Location
    norcal
    Posts
    113
    Not fluid flush
    My Acura Integra needs brake fluid flush every 3 yrs. In that process they inspect the brake by removing it.
    M5 has long life fluid - so how often should have brake inspected on M5?
  2. #2
    2012 CR Mazda5 Touring 90210's Avatar
    2012 Mazda5 Touring
    Join Date
    Mar 2011
    Location
    Los Angeles
    Posts
    1,376
    My Integra GSR has 577k miles on it. Bought it new. I brake flush every 60k miles.
    My Mazda5, font brake pad 72k miles. Rear still original. Car has 118k miles. Flushed it once.
    My race cars i flush yearly
  3. #3
    Registered Member
    2012 Mazda5 Sport AT
    Join Date
    May 2008
    Location
    IN
    Posts
    519
    I drain and fill my brake fluid every year. It takes under an hour and costs like $10. I also lube the caliper guide pins and check the rest of the brake components. I put new rotors and pads on all four corners around 75k or so (I forget the exact number) and am at 127k right now.
    Completed mods: 15% tint all around | Class I trailer hitch | JKS Rear Spoiler | OEM bumper guard | OEM roof rack | Thule 872XT fairing | Hella Supertone Horns
  4. #4
    Registered Member
    Mazda 5
    Join Date
    Apr 2018
    Location
    Hong Kong
    Posts
    127
    I would like to flush my brake fluid, any step by step procedure?
  5. #5
    Registered Member
    2012 Mazda 5
    Join Date
    Sep 2014
    Location
    Epping, NH
    Posts
    20
    I give the pad thickness a look every time I rotate the tires which is 7500 miles. The also get checked annually during state inspection.
    Still have the original pads at 108k. I'm planning on replacing them in about a month when it warms up a bit here.
  6. #6
    Registered Member
    2013 Mazda5 Sport
    Join Date
    Feb 2016
    Location
    United States
    Posts
    10
    Replaced my pads around 60K. Check them each time I rotate tires. I tend to do them a bit on the early side though. Try to avoid doing any repairs in the winter. Cold weather makes things harder to do.
  7. #7
    Registered Member
    2012 Mazda 5 Touring WP, '18 Passat SE w/Tech, '17 Polaris 570
    Join Date
    Oct 2012
    Location
    Bensenville, IL
    Posts
    15
    I did my fronts @ 30K, Fronts & Rears @ 60K and I did Brembo pads With Stoptech rotors the 2nd time around. Now @ 92K looks like I still have about half life left on the pads.
Similar Threads
  1. Replies: 30
    Last Post: 11-17-2013, 12:27 PM
  2. CX-9 brake job - changing front brake pads
    By jediwebdude in forum CX-9 Wheels, Tires, Brakes & Suspension
    Last Post: 02-05-2010, 06:28 PM
  3. Replies: 10
    Last Post: 10-02-2008, 12:48 PM
  4. Changed rear brake pads; parking brake woes
    By vkeks in forum Protege5
    Last Post: 12-26-2007, 01:54 AM
  5. I inspected my brake rotor and...
    By WhitewaterPearl in forum Mazda5 Wheels, Tires, Brakes & Suspension
    Last Post: 12-01-2005, 11:52 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
